Question about Water Heaters
User manual for GROHE 34221000 Chrome Grohtherm 2000 Two Handle Thermostatic Shower Mixer, LP Systems
3 Suggested Answers
pipesster
  • 20 Answers
SOURCE: Grohe valve Grohtherm Thermostatic Rough 34-126
The thermostatic stop is set too low. Havent set a grohe before but most other thermostatic shower valves work similar. pull off the handle(however a grohe handle comes off . . ) there should be a notched ring or stop which keeps the handle from going all the way hot. pull out the ring and turn it a few teeth hotter put back and reinstall handle try water temp and adjust again if necessary.
Posted on Jan 25, 2010
  • 122 Answers
SOURCE: my thermostatic mixer shower will not turn off
he probably put it together wrong.
there is usually a blue gasket inside for testing purposes, if that is not removed, the valve will not turn off.
Posted on Aug 15, 2010
Why is there no hot water, only cold water coming out the mixer valve?
Sounds like the screen is plugged or the check stop is not working correctly
May 28, 2014 | Grohe Grohtherm Thermostatic Rough-In...
I have what appears to be a Grohtherm in the shower in my new house and the water does not get hot enough. I have it set at 110 and it is on the verge of being to cold to take a shower. How do I fix...
unount the cartridge and clean it, probably there is some sand in it.
if that wont work uoy must trade the thermostat, if stillis in garantee good, if not that will expensive.
good work.
Feb 15, 2011 | Grohe Grohtherm Thermostatic Rough-In...
My thermostatic mixer shower will not turn off
May 12, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
Little hot water flow with Grohe 1000 grohthern
Yes it sound like you have blockage in the mixer .
Jan 17, 2018 | Grohe Grohtherm Thermostatic Rough-In...
I need to clean the filter on my grohe shower how do I do this
Use a flat head screw driver and unsrew the brass fitting remove the temperature spindel and wash out. Re install the same way and test.
Feb 19, 2010 | Grohe Grohtherm Thermostatic Rough-In...
Grohe valve Grohtherm Thermostatic Rough 34-126 I turn the mixer to full hot but the temperature remains tepid. All the other faucets in the
Jan 23, 2010 | Grohe Grohtherm Thermostatic Rough-In...
Hot water not as hot from rain head as other outlets
i'm quite sure you shower valve has an adjustment on handle that allows more hot water into the mix,........it will tell you how in the paper work that came with the valve,....good luck, cracklin joe
Jan 06, 2010 | Grohe Grohtherm Thermostatic Rough-In...
Water Heaters Logo
293 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
