Cannon MG3100 printer keeps printing very small not filing up the paper
yooperbud
  • 8637 Answers
SOURCE: cannon printer feed paper
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 26, 2009
  • 13 Answers
SOURCE: printer not printing
find the maintance section of your print driver display ( far right of the display ) should see a maintance tab.
do a cleaning cycle or a deep cleaning cycle and see what happens. it should start printing.
if necessary make up a solid single color block on a windows word doc using the squares make them no line perimiters and do a black blue red and yellow about 1/2 inch tall and 7 inches wide
as a test pattern. the color that doesnt print is clogged
in the future try not to let the inks run completly dry before they are replaced.
if that doesn't help use isoprople alcohol 91proof on a cotton swab or clean cloth and let the print head soak in it for 5 minutes and try again.
Posted on Feb 21, 2009
  • 13 Answers
SOURCE: Samsung ML 2010 won't paper feed
Lift up the front of the machine a couple of inches. I put a small bo under it. The paper then feeds slightly downhill.
Worked for me.
Posted on Mar 08, 2009
komguy
  • 2306 Answers
SOURCE: I can only print one sheet, then the paper stucks.
Samsung is a reliable brand, but they have had problems with the vendor for the exit sensor. When it goes bad the paper comes part way out of the exit and jams. The part is less than a dollar, and you might find it at www.precisionroller.com
Posted on Jan 22, 2010
pineworks
  • 4041 Answers
SOURCE: My cannon pixma ip 1600 keeps giving an error
Hello there
You may not see a paper jam, so this is worth trying.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
Why does the printer keeps having a paper jam fault on final exit slot?
It sounds like the exit sensor is sticking, so the printer doesn't know the paper has exited & throws a jam.
Aug 24, 2014 | Cannon Office Equipment & Supplies
Canon mg3100 printer is printing blurry
Could be paper quality problem, moisture on paper or the most likely is you need to clean the ink port.
Jul 31, 2014 | Canon Office Equipment & Supplies
Label print problem making in MS word
You need to set up the paper print size for the Cannon. It may be a different print height and width.
Feb 27, 2014 | Canon LASER SHOT LBP-2900 Printer
Canon pixma mg3100
check to see if the ink cartridge is in properley
Jan 28, 2014 | Office Equipment & Supplies
How do I clean the print head on my cannon
Go to your local office supply store and by Ink Jet Cleaner paper. It will come in a small package and the paper will feel like thin, hard felt, and will come with instructions on how to clean your ink jet printer.
Sep 17, 2013 | Canon PIXMA MX432 Office All-In-One Inkjet...
My cannon MP160 pixma keeps telling me there is a paper jam when there is no paper in it, it will copy and give me color tests printed out but if i try to print a doc. It says E# paper jam
Hello thanks for using fixya
Actually you are facing E3 error, E3 error is mostly because of paper jam. their may be small bit paper jam in side
There are some "micro-sensors" that detect a paper jam. There will be tiny piece of paper, or a lump of dust, inside those sensors, thus "tripping" the sensor and saying you paper jam.
To solve it
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
If you become sure that now really there is no paper, dust or foreign objects then
Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If still problem exist then best & final option is to just contact to any Canon service provider.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Feb 07, 2011 | Canon PIXMA MP160 All-In-One InkJet...
How can you keep the printer from jamming up paper with every print everytime I go to print a paper the paper jams in the printer, I checked for jammed paper but dont know how to reset it
reset printer
check if there is any paper (small bits) stuck in the printer which could be blocking the sensor or the rollers
also check if the paper is not damp?
realign printer heads using the software if it offers the function?
Oct 16, 2010 | Cannon Office Equipment & Supplies
Printer quit printing
my black cartridge is not printing it has ink
Feb 05, 2010 | Cannon i70 Printer
Need help setting printer to print regular size
On your printer, there might be a button saying Enlarge/Reduce. Keep hitting it until you get 100%. Good Luck.
Nov 15, 2008 | Cannon Canon i960 Photo Printer
95 people viewed this question
jasbo
jasbo
