HP 1610 All in one alignment failed. Also getting cartridge jam messages which seemed to be fixed after following posts on this site......now can't align new color cartirdge and won't print in color. Thank you
  • Anonymous Mar 01, 2009
    I am having almost the same problem, except it's my black ink that won't print. Also, I found a little spring, about 3/4 inch long, laying under the cartridge holder.
  • Lynda Simpson Mar 01, 2009
    Sorry, also, I have a 2610, I did replace both of my cartridges with OfficeMax remanufactured cartridges, and I'm still having the same problem.
    Genius:
  • 2,120 Answers
Replace black also.
Posted on Jan 25, 2009
Will not copy
This means one of the cartridges is defective, they cant align if they cant print. What i did to fix this problem is insert 2 working cartridges and get it to align properly, even if they are low on ink, then lift the cover and the cartridges will move to the center. When this happens pull the power cable out, then insert the full non functioning cartridge. Plug the power cable back in. I tried this with a color cartridge, the color cartridge was non functioning but i was able to print in black. Basically you align the cartridges and then swap them so the printer thinks they are still aligned. The color still doesnt work and it is probably a defective color cartridge.
Apr 20, 2013 | HP Officejet 7210 All-In-One InkJet...
My Hp 1610 All in One Printer-Scanner-Copier does not print and when copying the paper comes blank
Try replacing the cartridges and make sure when you install them you remove the plastic on the bottom. Sounds like it may be silly but in this fixes a lot of problems with these printers. I would even get new cartridges even if the old ones aren't empty to eliminate that as a factor. From there I would run through all the diagnostic and alignment programs associated with printer. If that all fails (I know this is a site about fixing things) but a new printer that uses the same cartridges is the way to go I wouldn't invest a lot of time in this when a new one with new cartridges is 40 dollars.
Mar 08, 2011 | HP PSC 1610 All-In-One InkJet Printer
HP OfficeJet 6110 All-In-One
go to hp.com, support and troubleshooting, type in your pirnter model number and download the user manual. follow the direction to disassemble the printer. you might not need to disasseble the printer, if you can see the jammed paper.
follow the direction and clean the roller and the printer head.
it should work.
Oct 05, 2008 | HP Officejet 5610 All-In-One InkJet...
Allignment of new cartridge takes a very, very long time with garbled message on screen
My guess is that either the cartridge isn't compatible with the product or there's an issue with the electrical contact between the cartridge and the print carriage. I found a document at HP's web site that addresses both of these issues. After clicking on the following link, review Solutions 3 and 5 to see if either one helps. There's a link on that page after Solution 3 that lets you check the print cartridge compatiblity.
Slow printing solutions
Post back your results. Good luck.
Sep 26, 2008 | HP PSC 1610 All-In-One InkJet Printer
Remove and checl color cartridge
The problem most likely is with the electrical contact between the color cartridge and print carriage. Even if you've replaced the cartridge, if the contacts on the carriage are still dirty, it won't make a good connection with the new cartridge and the error message will still appear.
Fortunately, the HP web site has a solution posted at the following link:
Cleaning Cartridge and Print Carriage Contacts
Good luck.
Sep 04, 2008 | HP PSC 1610 All-In-One InkJet Printer
Cartridge alignment
It seems a problem with the carriage of the printer
printer needs to be replaced
Apr 21, 2008 | HP OfficeJet 6110 All-In-One InkJet...
CARTRIDGE WONT ALIGN
The following error message appears on the LCD panel1.gif on top of the printer after you insert a cartridge: Press enter to align cartridges . You press Enter , but the error message does not go away. The printer will not print. Solution To bypass the cartridge alignment, do the following:
  1. Press and hold the Setup button.
  2. Press the Options button. The printer should be ready to print.
If the print quality is unacceptable after bypassing alignment, follow the steps below until the error is corrected.
Feb 13, 2008 | HP PSC 2210 All-In-One InkJet Printer
122 people viewed this question
jasbo
jasbo
