Why does my stereo do this and how can I fix this problem, no matter how many times I turn it off and turn it on, the same thing happens and it won't stay on
    New Friend:
OK DO YOU HAVE A CD STUCK IN THE CD PLAYER
Posted on Jan 18, 2013
TDM 900 not starting keeps Flooding
Hi, Anonymous and the usual suspects are:
1. Dirt or other foreign matter between float valve and its seat.
2. Float valve sticking.
3. Float valve and/or valve seat worn or damaged.
4. Float misadjusted.
5. Float cracked, leaky or damaged.
6. Excessive "PUMPING" of hand throttle grip.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
KTM Flooding won start Why
Won Start Just Turns Over And Backfires Fixed
Yamaha 2002 TDM900 Service Manual
OEM parts for Yamaha
Yamaha TDM900 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Feb 08, 2014 | 2004 Yamaha TDM 900
My right side speakers have stopped working fully. When I set it to only right side, i have sound, but it is extremely low no matter how loud I turn it up. It also doesn't matter if it is set to just...
Could be worn volume-control (potentiometer), dust/oxidizing on wiper-track of same control.
Buy contact-cleaner spray,such as Servisol, McKenic, Kontakt or similar.
If linear slider-type volume, attach tubular nozzle/guide thingy to spray head, squirt cleaner into slot while zooming back & forth (stereo OFF).
This scrubs the contacted surface while cleaning.
If rotary type, remove stereo, open cover, locate volume control, squirt into control while dialling up and down.
Allow a few minutes to evaporate (quick dry spray is best).
Oct 11, 2017 | 2008 Hyundai Elantra
It became only while the car was idling, now it's anytime, anywhere, and never on a consistent basis. The engine simply dies, turns itself off. When it happens, the check gauges light comes on. Nothing...
is your stereo the OEM (factory original) model? Does the car have a factory-installed anti-theft system? If the answer to both is Yes, you may have a logic conflict since many anti-theft systems go to and through the car's stereo. If you still have the original owner's manual, check the section on anti-theft or security systems. It may list a reset procedure that returns the system to factory defaults. If you have an aftermarket anti-theft system, you may have to disable it until troubleshooting and repair processes have been accomplished. Incidentally, by the car sitting without a battery for five years, all E-prom programming may have been degraded or lost. As for the volume increasing, some GM/Delco radios have a volume compensation feature that increases volume levels as speed increases.
Oct 10, 2013 | 1997 Pontiac Firebird
Motor won't engage. I turn the throttle and get a clicking sound, but nothing happens. We've charged the battery for about 4-6 hours, but the light stays red, never turns green. Help?!!
sounds like the battery is bad and not taking charge.replace battery attemp again if not then check for fuel, spark and compression.then c wat happens or wats not working any motor no matter how small or big has to hv those three things to run. hope this helps.
Jul 08, 2012 | Electric Razor Pocket Rocket Ride-on...
Panasonic DVD-S31 won't play sound
Did you change the audio cable, "just to rule out" If it won't work on the Tv or stereo, there probably is a audio processor problem, or a issue with the laser pickup assembly, to repair this kind of problem would not justify the cost.
Apr 12, 2012 | Panasonic DVD-S31S DVD Player
I put a new car stereo and system in my car. Now the parking lights won't turn off. Is this a security mode on the car? Or is it from the wiring? It is a 2006 Kia Spectra EX.
Usually the brown wire is for illumination. If you have supplied power to this wire some how it will keep these lights on. If you got wiring schematics with the stereo recheck your work.
May 07, 2011 | Kia Spectra Cars & Trucks
Honda Accord 1995 Stereo and Clock
it sounds like you have shorted out the stereo. i had a jensen stereo that the display went out on an i checked all the same things that you did an it still wouldnt work. you may could take it apart an look at the circuit board an see if there is a burnt spot or a wire popped free from the board. for future advice always disconnect your battery. i hope this may help
Oct 23, 2008 | 1997 Honda Accord
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
