Question about Onkyo TX-SR506 Receiver
No volume control for Zone 2 on the TX-SR506?
I cannot find any way to control the volume of Zone 2 without using the remote. Is there any way to do it?
  • Anonymous May 20, 2009
    Can only control volume for second 2 from remote
5 Suggested Answers
  • 4234 Answers
SOURCE: Buzzing/vibration noise from ONYKO TX-SR506 unit
If the unit is under warranty, DO NOT open it up. Bring it in for an exchange or warranty service. Explain that the unit makes noise during use and it will be serviced. This could be as simple as a bad connection in the power supply area and you are hearing oscillations or it could be a defective power transformer. Either case will be covered under warranty so there should be no charge to you.
Keep us posted.
Dan
Posted on Feb 17, 2009
SOURCE: What remote control code does the Onkyo TX-SR304 use?
From: http://www.comcast.com/remotes/universal.html - only worked for me when I had AUX setup with 30135
Unlocking Volume Control For A Single Device (Individual Volume Unlock):
  1. Press a desired mode key where you want volume to be unlocked (e.g., AUX) and controlled within its own mode.
  2. Press and hold SETUP until the selected mode key blinks twice, then release SETUP.
  3. Enter 9- 9- 3 and then press VOL- once. The mode key will blink four times confirming unlock.
    If desired, repeat steps I to 3 (of this section) for each device that you want volume to be unlocked.
Now, after you select a device that has volume unlocked (e.g., AUX), pressing VOL , VOL-, or MUTE will control the device's volume only in its own mode.
Posted on Apr 15, 2009
easyq
  • 144 Answers
SOURCE: TX-SR506 Bi-Amping
If you select bi-amping the device will use a second amp for your rear speakers, this indicates that in your setup menu you probably have deleted the rears (set to None). Try to find the settings for your rear speaker in your setupmenu and see if they are selected in normal operation.
If all fails, see if you can reset teh device back to factory settings, sometimes software can get confused after using for a while. Resetting should than fix most problems.
You can also check and see if there is maybe a software update available for your device, loading and installing is explained in either the file or on manufacturers site.
Posted on Apr 17, 2009
SOURCE: zone 2 volume control
Sounds like the Zone 2 amp was set to external, see below for instructions on setting it back up.
How do I setup Zone 2 on the RX-V661 Using the internal power amp.
Setting the RX-V661 remote control to operate Zone 2
1. Using a ballpoint pen or similar object and press the Code set
button. The Transmit indicator on the remote should flash twice.
2. Using the numerical key pad on the remote and key in 9992, the
Transmit indicator should flash.
You will now need to assign the receivers internal amp for Zone 2.
1. Set the remote control selector to AMP. Selector is on side of remote.
2. Press the Set Menu Button.
3. Arrow down to Manual Setup.
4. Press the Enter button.
5. Arrow to the Sound Menu option and press Enter.
6. In the Sound Menu arrow to Speaker Set and press Enter.
7. Arrow to the EXTRA SP ASSIGN and select ZONE2. This may require using LEFT or RIGHT arrow.
8. Press the Return button to exit out and return to the Manual
Setup.
Posted on May 24, 2009
  • 4234 Answers
SOURCE: i have a onkyo tx-sr506 receiver that turns it self off
This unit is in protect mode. This means that a problem was detected and the unit has shutdown to prevent further damage. The most common cause of this is failed output transistors. Plan on $20-$40 for parts for this repair.
Dan
Posted on Nov 04, 2009
My Onkyo TX-SR506 plays cable and CD inputs to zone 2, but DVD won't play. Everything is connected according to the manual and I assigned zone 2 output correctly. What gives?
How are your cable and cd inputs hooked up? Analog connections? Alot of receivers cannot send an audio signal from hdmi inputs to zone 2.
Feb 06, 2013 | Onkyo TX-SR506 Receiver
Should i use an amplifier with the txsr506. i dont know if im doing anything right with the receiver. i feel like its two low on volume
It HAS amplifiers. You don't daisy-chain amps.
Get the manual and take some of the gueswork out of the process. Set it up and come back with specific questions.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR506-Receivers-manual/id/13748ci477/t/2/
Jul 05, 2011 | Onkyo TX-SR506 Receiver
Need code for dish network remote control for onkyotx- sr 506
HeyRodney_tu176, my name is Mike Houston of DISH Network and I was going over yourpost and wanted to give you the codes for your Onkyo TX-SR506 7.1 Receiver. The Codes willbe; 660, 642, 662 and 678. I will send a link to help with these steps, http://www.dishnetwork.com/SupportSection/remote-setup.
Apr 11, 2011 | Onkyo TX-SR506 Receiver
Volume is stuck on max. The pot does not seem to be the issue. I do not have a remote. Tried to connect other remotes but unable to find a code that will work. Machine is new to me. Bought it for...
Do you have the manual and have you thumbed through it?
retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR700-Receivers-manual/id/365ag223/t/2/
It always puzzles me when someone fixates on the remote when a unit has front-panel controls. You say "The pot does not seem to be the issue." Does that mean it is ineffective or is it faultless in your estimation?
The HUGE volume knob (#16 on page 8) controls volume (in the main zone), too.
If your complaint involves speakers on Zone 2, the up/down arrows at #22 on page 8 apply.
Feb 26, 2011 | Onkyo TX-SR700 Receiver
I have an onkyo tx-sr506 and the system shuts off as I turn up the volume. It doesn't get very loud (barely audible) before shutting off.
Check speakers for distorted or dead drivers . Disconnect and repair. receiver will blown if not disconnected.
Mar 15, 2010 | Onkyo TX-SR506 Receiver
What is the remote control code to control the TX-SR506 from an ATT Uverse remote
hi i have here a couple of codes for Onkyo you could try them 5002, 5018, 5073, 5074, 5075, 5076, 5077, 5078, 5079, 5080, 5081, 5082, 5084, 5085, 5086, 5087, 5130, 5131, 5140, 2006, 2219, 2220, 2318, 2410
hope this help! goodluck!
Nov 24, 2009 | Onkyo TX-SR506 Receiver
Denon AVR 1609 volume Zone 2
Logitech recommends that zone 2 is controlled using device mode on your Harmony remote. Controlling zone 1 and zone 2 simultaneously within activities may lead to the AV Receiver turning on and off unexpectedly as you switch between activities. For example, if you try to turn on zone 2 within an activity, it may turn on or off zone 1 and vice versa. Controlling zone 2 in device mode will prevent this from happening.
Aug 07, 2009 | Denon AVR588 Receiver
Can't find a remote code for my onkyo rc-710m to control my dish network vip722k satellite/dvr receiver
Remote code will work but be sure you have VIP remote address set on 1. See page 56 of VIP manual or instructions on changing remote address.
Jul 25, 2009 | Onkyo TX-SR506 Receiver
TX-SR506 Bi-Amping
Sep 15, 2008 | Onkyo TX-SR506 Receiver
Onkyo TX-SR506 Receiver Logo
134 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Dennis McCollum
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
