Cannot boot my laptop: Toshiba Satellite A210-19T
  • 32,281 Answers
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Posted on Jan 19, 2013
SOURCE: Toshiba satellite a105 s4004 cannot boot
if the recovery disk would not run to load the program than your hard drive is probably bad have you been into the machine and seen the hard drive have a look at the front where the wires plug in and there is a slot for jumpers to select the hard drive function make sure its set for master only. most hhard drives will not have a jumper for master setting if there is a jumper make sure its set right .
Posted on Dec 08, 2007
rockitman187
  • 2559 Answers
SOURCE: my toshiba satellite wont boot from cd rom
Press F12 while booting
Posted on Jan 23, 2009
Geekman
  • 32281 Answers
SOURCE: diplay will not boot up toshiba satellite laptop
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Jun 08, 2009
pumpkinman
  • 1144 Answers
SOURCE: I have a toshiba satellite L20-181 it keeps rebooting
go into F12 AND DISABLE IT
Posted on Oct 08, 2009
  • 152 Answers
SOURCE: need help with toshiba dynabook satellite 1801
Toshiba bios password removal process is meant for use on Toshiba laptops that you own or have had permission from the rightful owner to remove the password. If any of these processes are done incorrectly it may result in complete system failure or permanent system damage (you've been warned!).
Some Toshiba bios passwords can be reset using the Key Disk.exe utility, to do this you need a 1.44Mb floppy disk. Format the disk using Windows and then with a hex editor, change the first five bytes of the second sector to 4B 45 59 00 00.
Then put the floppy into your machine and boot it up, you'll be asked for a password, just press Enter. Then when you're asked to set the password, type Y then Enter, this will get you into the bios configuration where you can then type in a new password.
Aside from the KeyDisk, you can build a parallel Loopback plug, this is a simple device that plugs into the parallel port of the machine and removes the password when you boot it up.
To make it you will need a 25 pin DB25 plug, take the plug apart and join these pins using some old cable;
Pins: 1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15, and 18-25
Plug it into your parallel port and boot up your machine, the password should be removed as soon as it boots.
Note: This will work on majority of older Toshiba's (1995 – 2002) and obviously only ones that have a parallel port.
Posted on Apr 28, 2010
How can i go in boot option
Normally when you power on your Toshiba Satellite laptop it attempts to boot the operating system installed on its hard drive.
In some instances you may want to boot the Satellite laptop from a different device, such as an operating system installation CD or a USB drive.
The boot order doesn't have to permanently be set to the hard drive.
It's possible to access the boot order before the operating system loads and change which device is set to boot first.
Turn off the Toshiba Satellite laptop.
Turn it back on immediately and wait for the "press the F2 key to enter Setup" entry to show up on the screen.
Press the "F2" key to access the Toshiba Satellite's BIOS menu.
Use the right arrow key to navigate to the BIOS tab labeled "Boot."
Scroll down to the option labeled "Boot Priority" and tap Enter.
Check through the list of devices and locate the specific device you want to use to Boot your Toshiba laptop, such as "CD-ROM," "USB" or "LAN."
Highlight the name of the device in the list and then tap Enter to make it the top boot priority.
Use the right arrow key again to scroll over to the "Exit" BIOS menu.
Tap the down arrow key to highlight the "Save and Exit" option.
Press Enter to save the new boot order and restart your Toshiba Satellite laptop.
Repeat the procedure when you want to change the boot order back to its original setting.
How to boot your Toshiba PC from CD-ROM, LAN, or diskette
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletin.jsp?soid=403623
Toshiba support
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=ex&bbid=bb42&url=&dialogID=111194172&stateId=1%200%20111190763
Aug 02, 2013 | Toshiba Satellite 2415-S205 Notebook
Can't get Toshiba Satellite L775 to boot past "windows is loading files" screen
I assume you are doing a System Restore/Recovery? Have you removed the HDD and tested it? Perhaps the Recovery files are corrupt/missing? A bit more info needed.
Jul 03, 2013 | Toshiba Satellite L655-S5160 Laptop PC...
How to change disk controller in bios on Toshiba Satellite A135-s2276?
Hello here is the homepage:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1596141&
You need this for the drivers.
And you can downlaod a manual
Press the "F2" key to access the Toshiba Satellite's BIOS menu. Use the right arrow key to navigate to the BIOS tab labeled "Boot."
Read more: How to Change the Boot Order for a Toshiba Satellite ' eHow.com http://www.ehow.com/how_6383103_change-boot-order-toshiba-satellite.html#ixzz2Cn6HdU2k
Turn on or restart your computer and watch for a message during the post about a particular key, usually Del or F2, that you'll need to press to ...enter SETUP. Press this key as soon as you see the message.
Go to boot and select the boot order.Use F4 or F5 to change.
First boot device: Cd/dvd drive
Second: the harddrive.
Leave the bios and save the settings.
Place your windows cd in the drive and reboot.
Now you can install windows again.
Good luck
Nov 20, 2012 | Toshiba Satellite A135-S2276 Notebook
How to go the bios setup on toshiba i3 laptop satellite l650 in order to boot from drive
Try pressing the F1 or F2 key several times as the Toshiba boots up to get into the BIOS configuration, once you get into the BIOS you can change the device boot order.
Feb 23, 2011 | Toshiba Satellite A15-S127 Notebook
Toshiba Satellite A215-S7422 won't boot-up stuck with boot screen the bios is ver.1.00 need help how to make it boot up again,
My Toshiba A215 starts up but won't boot from any source_CD,external floppy, hard drive,etc.. I swap memory,CPU,hard drive ,nothing works,have any one got any solution?//
THANX
Sep 17, 2010 | Toshiba Satellite A215-S7422 Notebook
How do i install windows xp professional on my Toshiba Satellite A60 Notebook? Thanks.
You will need the recovery discs or the XP installation disc generally the recovery disc are delivered with the laptops if you do not got it then you have to buy it from Toshiba.Then you have to boot the laptop with that disc by pressing F2 at the Toshiba logo screen and selecting the cd/dvd drive as the boot device.
Mar 10, 2010 | Toshiba Satellite A60 Notebook
Toshiba Satellite A50
When the system boots hit the BIOS key F2 and in the setup select boot from CDROM and press F10 and exit, Insert the bootable CD and boot the system
Jan 06, 2009 | Toshiba Sattelite A105-S2071 Notebook
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
