Question about Dryers
Accessing drum in dryer to re-attach the fin - Dryers
  • 979 Answers
Try removing the top of the dryer. You can get to a lot of the machine from this angle plus it is easier to work on.
Posted on Jan 25, 2009
How do I access the fin in the drum to tighten it?
You may have to disassemble your dryer to get access to the drum. Go to and enter DLEX3360 to see a list of common replacement parts and perhaps view a general video showing the disassembly procedure.
Jun 07, 2016 | LG DLEX3360 Electric Dryer
Fin that tumbles clothing inside dryer coming loose, how can I tighten it?
These fins are usually screwed on from the outside of the drum. If you're up to it this is a simple but time consuming fix. Take the cabinet off the front of the dryer, the top will come off as well. be careful of the wires from the control console, they will stay attached to the dryer. Tighten the tumbler fins on the drum and then re-assemble the cabinet. Typically the screws you need to access are the same used for the door latch and hinges. They go back together easy ........
Feb 14, 2011 | Maytag Neptune MDE7500AY Electric Dryer
Fin on gas dryer loose.
The model number is generally inside the door or door jamb area. The top must be removed to access the drum to tighten the screws to the fin
Apr 15, 2010 | Maytag SDG4606A Gas Dryer
How do I access the drum to tighten the dryer fins
Disconnect power to the dryer !!! Remove the 2 screws holding the door hinges on and remove the 2 screws opposite the door hinges . This will let you pull the top of the front panel outward and lift off the bottom clips . If you have enough room , slide your arm thru the front opening to tighten the screws . Otherwise , remove the 2 screws holding the clips for the top , 1 on each side , and lift the top , to get better access to the screws .
Apr 10, 2010 | Maytag MDE2400AYW Neptune Electric Dryer
Dryer fins coming loose
Unplug Unit.
Refer to pages 5-2 and 5-3 of the manual below to see how to expose the drum by lifting the top of the machine. Then turn drum very slowly and only until the screw holes for the missing fins are within your reach. Most of these dryers have two sizes of fins make sure you order the right one if you need to replace them.
Good Luck
Download this file : Maytag Dryer
Sep 07, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer fin on model MDE7400AYW fell off.
Take the door off. Do this by first loosening the screws on the hinge.
Then loosen the screws on the left (they hold on a plastic flange-type thing) that hold the front panel on. Once it's loosened, then the door hinge will have room to wiggle out.
Once the door is off, then the front panel will swing down--and you can lift it off the flanges that hold the bottom of the door.
Now you have access to the drum and can reinstall the fin.
Apr 08, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Unplug the dryer, remove the door hinge screws that go into the cabinet and the two screws on the opposite side of the door opening, then the front panel can be removedby starting at the top. Once the front is off, there are two screws, one to each side that hold the top on, remove these and raise the top. You can rotate the drum by hand and the baffles are held on by the screws on the outside of the drum. Reassemble in reverse order.
Jan 06, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Replacing the a drum "fin"
you should be able to Open the top of the Dryer, from front to back, U might need to pry the front corners up with a flat tip screw driver. It should hinge to the back, to expose the Tub... Hope this Helps U...
Sep 20, 2008 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag atlantis
Red silicone glue will not hold the "fin" under operation. You will have to access the outside of the drum to reattach the fin Avoid removing the drum unless you have the equipment to re-install the bushing that holds the drum. Make sure you disconnect the power and gas.
Aug 31, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
57 people viewed this question
Top Dryers Experts
