Question about Nu Mark Numark Cd-Mix-2 Dual CD Player/Mixer Combo - Good CD Player
Skipping cd deck 2 on numark cd mix 1 player.
The slightest vibration even at very low volumes causes deck 2 to skip, cut out etc. Had to hold it all night friday night whilst doing a disco just so I could use it. What needs to be replaced or fixed???? Many thanks , need to sort this by saturday if poss. my unit is a cd mix 1 not the karaoke one but there is no category for this.
    Problem Solver:
  • 15 Answers
You're best bet is to replace the stock rubber feet with a true vibration absorbing rubber pad. Audiofiles like myself have discovered that Sorbothane rubber is the best for this application. There is no other material that can even come close to matching it's performance. Get yourself a set of their Sorbothane rubber hemispheres, probably something about a 1" diameter would work best. The best place to get them is Amazon.com.
1.25" Sorbothane Rubber Hemispheres
Posted on May 01, 2010
Same problem here........put a small folded blanket under it for shock absorbing.
Posted on Aug 08, 2009
Paul asked my KAM KCD130 cd deck starts to slow down during playback
Posted on Apr 13, 2009
It does it on both decks..If it was the volume controls there wouldn't be any output on the meter. Even when the meter is showing output there is no sound..
I don't know how you are using the mixer are you using it as an interface? or are you directly running speakers to it? start with checking speaker cords I had an issue once that I accidently grabbed a mic cord and used it every system is different but on mine it cut input to all my speakers till right cord was replaced with good one if that's not it give me alittle more info on how your using it before I can touch on it further good luck
Oct 28, 2013 | Nu Mark Numark Cd-Mix-2 Dual CD...
I have numark tt 1610 decks, checked needles on both decks and they are both fine 1 of the decks however keeps skipping even when I try with both needles and different vinyls I've taken the weight off,...
Examine the cantilever very carefully - you sure that the stylus is there? Not uncommon for the lever to be perfecto but the stylus is gone. So when you go to play a record the arm slides all over the place!
Sep 23, 2017 | Numark TT1610 Turntable
Numark Axis 9's. . Problematic. Ahhhh!!!
Sorry, this isn't a solution but I just wanted to mention that I just got an Axis 9 and it is not playing burned CDs either. And I see another problem reported on this site specifically called "my axis 9 wont play burnt cds". What in the heck, Numark? Are all the Axis 9's this way?
Jan 18, 2010 | Nu Mark AXIS 9
Numark CD MIX2 right deck skipping, sounding scratchy
Did you by any chance buy it from a b stock retailer?...send it back...also reduce your burn speed when recording cds
Aug 04, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
Numark cd mix 1
The buttons usually wear out, open unit and replace the buttons.
May 14, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
Numark cd mix 2
just clean the contact using the contact cleaner..remove the shuttle then spray the potentiometer..do not use the oil base cleaner!! look for quick dry non-residue electronic contact cleaner
Jan 21, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
Channels inputs connectors
try relacing the RCA Jack ..
That is tyhe main problem
Nov 14, 2007 | Nu Mark Numark Cd-Mix-2 Dual CD...
Moodey newmark cd mix 2
Just wanted to tell you i have the same problem with my right deck! after about 2-3 hours of usage the right deck will start to skip while playing a cd...almost sounds like im fast forwarding then itll just stop playing, but only on the right deck! Ive noticed that it happens when the unit gets hot whether by usage or sunlight. Now as for youre issue about the crackling, i have two staements one is the cd youre playing scratched? ive had cds that have had minor path scratches that follow around the cd not straight across scratches..while playing this sounds like static or crackle then fades away! I would recommend playing the cd in a entirely different unit to see if this is the prob...if you know this is not the issue i would say that its a loose connection to a capicator or that a capacitor is on the way out...this happens when the capacitor is cold and doesnt let proper flow to go thru but as the capacitor heats up it it may heat the connection making a better contact.....just out of curiousity do you have the right rated fuse in the holder.. sometimes just having a fuse off by a couple of volts or milliamps can cause the same effect
Nov 12, 2007 | Nu Mark Numark CD-Mix-2 Dual CD...
Nu Mark Numark Cd-Mix-2 Dual CD Player/Mixer Combo - Good CD Player Logo
497 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
da surgen
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
