Question about Epson Stylus Photo RX600 All-In-One InkJet Printer
Error message 'please open the output tray' comes up every time..
We continue to receive this error 'please open the output tray' every time we try to print. We already have the output try door open. It's an Epson Stylus Photo RX600. Nothing in the manual regarding this error message.
neoranjit
  • 310 Answers
SOURCE: The printer will not scan
have to installed the software that came along with it ? Can you make sure that
1. the lights in the printer glow as they used to..
2. The software that came with it is uninstalled and reinstalled again.
This usually does the trick
- Ranjit
ranjit@supportminds.com
Posted on Nov 02, 2007
Lonewolf1038
  • 6 Answers
SOURCE: epson stylus photo r320 ink pad relacement
Here's 3 things you can do to get around this...depending if your printer is new and still under warranty or not (do NOT void your warranty!).
I have used all 3, but the third one was a lifesaver (AND money-saver!). About once a year I have to reset the printer using #2, but other than that....#3 is the greatest!!!
1. Try resetting it by, unplugging the power cord then while holding down the POWER STOP and MAINTENANCE buttons simultaneously while replugging the power cord caused a reset to zero on the counter. You will still have to replace the pads or redirect the waste ink tube to a receptacle on the outside of the printer, hope this helps?
2. If you go to inkjetprinterhelp.us there you will find the ssc service utility. Once you open the page click on the service utility and then choose the english version unless you can spk russian.If you then scroll to the bottom of the page and install the prog. Once you have installed the prog you will get the ssc utility logo in your bottom tray. Right click the icon and then select reset protection counter from the protection counter drop down. Once you have done this restart your computer and this should reset the system.
3. INSTALL AN EXTERNAL WASTE TANK and forget all about those gunky ink pads forever!
On the left rear of these printers is a small trapdoor held by a single screw.
Remove it, look inside (down and to your left) and you'll see the waste ink tube.
The tube is free at one end, and with a suitably curved piece of wire you can hook it and wangle the end out through the opening (you may dislodge a small piece of plastic in the process -- just put it back where it was, it's only a vibration damper.) I found the tube to be rather short....so I added an extension since I do not have room directly behind my printer for a container. I used the tubing you use with oxygen tanks or fish tank bubblers. They also make a little plastic connector so you can join the two together.
At this point, you're almost there.
All you need now is a suitable container for the waste ink, and I drilled a small hole in the trapdoor cover so you can put it back on without pinching the tube (or you could just leave it off.)
The container is a small square one with a snap-on lid, approx. 60mm square and holding about 150ml -- they're sold in sets of three for a few cents and are for making ice-blocks etc. in your freezer. Any small container will work.
Make a hole in the lid (slightly larger than the tube to let air escape) insert the tube and forget about the internal pads forever.
I've had mine in place for almost 2 yrs now and it works like a charm. If you need photos, let me know and I have a couple I can send you.
Posted on Jul 01, 2008
SOURCE: Stylus Photo R320 "printer driver dealing with CD printing...
I had the same problem and was able to get my EPSON Stylus Photo R220 to print a CD using the following procedure. This should work for other Epson Photo printers as well.
1.     Open EPSON Print CD
2.     When CD is ready for printing do the following:
3.     Select Print from the File menu
4.     When “The EPSON printer driver dealing with CD printing is not installed” is displayed – click OK and select Manual Print
5.     Set Paper Size to A4 and click OK
6.     In Layout select Print Settings
7.     In Media Type select CD/DVD
8.     Then press Print
Th
Posted on Sep 24, 2008
Dipu007
  • 2110 Answers
SOURCE: epson photo rx600
If the LED display screen on your printer is blank please try disconnecting
the USB cable from the computer and then disconnect the power to your
printer. Reconnect the power to a different power outlet, and turn your
printer back on. If the same issue occurs, your printer will require
service.
Posted on Dec 04, 2008
  • 2976 Answers
SOURCE: Epson Stylus Photo RX600 Error Message
Unplug the power and USB cables. Reboot the computer. If that doesn't work, reinstall the software. Here is a link for the manual. It's big so it takes a couple minutes to load.
http://files.support.epson.com/pdf/rx600_/rx600_01u1.pdf
Posted on Jan 30, 2009
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
I receive the following message on the PC display: "Document printing cannot be executed because the paper output tray is closed. Open the paper output tray. Printing will restart". I want to mention
The blinking is just an attention light so there's nothing to worry about that. Try adjusting your paper tray to the paper size you are about to use. Or try checking the duplexer panif its positioned properly. Hope this helps.
Dec 20, 2012 | Canon PIXMA iP3000 InkJet Photo Printer
Error message "push output tray
PowerCycle your Printer. Unplug all cables and push the power button for 5 seconds. Plug the cables back and try again.
-please thumps-up if you find this helpful
Mar 28, 2011 | HP Photosmart C6280 Printer
Hi...I have a problem with my HP Photosmart C7280...can you help ? the error message "Photo tray problem" keeps coming up, telling me to "lift the output tray, push the photo tray all the...
Photo tray problem
' Lift the output tray up and verify that the photo tray
' is pushed in until it stops, then lower output all the
' way down. Press OK button on the printer to
'continue printing
HP Photosmart C7280 All-in-One Printer
1. Turn off printer.
2. Pull out paper tray and photo tray
3. Remove output duplexer (on back of printer)
4. Open input sheet feeder (on top of printer)
5. Open cartridge access door. (Basically lift up control panel and scanner section of the printer)
6. Turn on printer (Power button on now raised control panel)
7. Printer may display message "Performing printer alignment - Do not interrupt"
8. Wait for a few minutes until printer stops making all setup noises.
9. Close cartridge access door, close input sheet feeder, replace output duplexer, insert paper trays
10. Do a test print. All should be fine.
Mar 11, 2011 | Office Equipment & Supplies
HP c7180 message "Push output photo tray all the way down"
I have the HP C7280 and I was able to fix the problem.
HP seems to have 3 trays. The bottom tray is for the paper. The middle one has a small blue tray for the photos and the top tray is where the paper comes out.
Well I lifted the top tray where the paper comes out (it can angle up) and then I clicked OK on the problem. I may have even rebooted, but then I got a new error message which is good. It said to push photo tray (the small blue tray) all the way in which I pulled out and pushed back in. Then I pushed the top tray down so all is flat again. I clicked OK and it re-calibrated with no more error messages! Hope this helps.
Feb 16, 2009 | HP Photosmart C7180 All-In-One InkJet...
When printing paper continues to jam.
  1. Take out paper tray 1.
  2. Remove any jammed sheets of paper you find there.
  3. Once you have done this, reinstall the paper tray and try printing again.
    Note: You may receive a message informing you that another sheet of paper is jammed elsewhere in the printer. If so, please open the front door and remove the toner cartridge. Also open the rear door of the printer (and the duplex option if a duplex unit is installed). Remove any and all jammed sheets of paper you find. Then try printing again.
  4. If the printer jams again with a 241 Paper Jam error message, look to see if it has tried to feed a sheet of paper out of the tray.
Dec 16, 2008 | Office Equipment & Supplies
PIXMA ip8500 not printing
i have a pixma ip4300 i keep getting the error number 1250 "paper output try is closed" but infact its is open i have tried opening and closing and restarting and everything else i can think of. any ideas of what to do?
Jun 23, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
Printer Error
there is button or clip backside of the printer.......u just press it and open the tray..........it is also possible that u don't attch ur usb wire to the cpu u just check it .........may be it will be good........
Apr 19, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Epson Stylus Photo RX600 All-In-One InkJet Printer Logo
628 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
