Question about Toshiba Satellite Pro A210-EZ2202X Notebook
Toshiba satellite A210-19T just updated but laptop will not boot up just says 3 of 3 updates configuring please do not turn off your computer
Model no. PSAFGE- 03VO11EN serial no. 28078478Q
    Sergeant:
  • 293 Answers
When starting your laptop togglr F8 key and then start in safe mode and then go to system restore and pick an earlier date and follow instructions
Posted on Jan 19, 2013
  • flung6969
    flung6969 Jan 19, 2013
    hi there tried that, to no avail in safe mode it says unable to start programme
  • pat  murray
    pat murray Jan 19, 2013
    ok sounds like 1 of 2 things if you made up restore or recovery discs you may want to put them in and see if it will recover if you dont have recovery discs or install discs then you need to get a copy of them and see if they will recover your system if you try to restore and it does not it should give you a reason like hard drive failure or somthing
studio2054
  • 33 Answers
SOURCE: toshiba satellite laptop drivers
Click here to download: http://cdgenp01.csd.toshiba.com/content/support/downloads/sl20modemx.exe
More drivers here: http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modItemList.jsp?moid=1272270&rpn=PSL20U&ct=DL&BV_SessionID=@@@@1082861316.1225660061@@@@&BV_EngineID=ccceadefiieldejcgfkceghdgngdgnj.0
Posted on Nov 02, 2008
cpenzes
  • 1102 Answers
SOURCE: My Toshiba Satellite L300D keeps shutting down when I start it up
restart in bios setup
then click to default settings press f10 to save and exit
if problem persists let me know
don't forget to rate
Posted on Feb 09, 2009
SOURCE: toshiba L305D S5881 bios updates
problem solved
take out battery open the port were the ram is installed ......remove RAM
you need a small piece of wire and a piece of tape
you will see 2 mount points with B500 above them
simply place the small wire across the 2 points install 1 stick of RAM plug into wall leaving main battery out fire it up and it may restart 2 or 3 times or you will immediately be in
NO JOKE did this exact process last weekend and it worked
i figured this out from a very similar tutorial on toshiba
let me know if this helps .............CIRRUS
cirrus2028@yahoo.com
Posted on Sep 26, 2009
n5kb
  • 349 Answers
SOURCE: WEBCAM DRIVER OPEN FAIL. Toshiba M300 satellite
Go here and download the driver utility for your webcam.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2228766&rpn=PSMD8U&modelFilter=M300-ST3402&selCategory=3&selFamily=1073768663
Posted on May 02, 2010
techresolve
  • 109 Answers
SOURCE: i have a problem booting
Go to bios and reset the priority of booting, make hdd 1st . Your computer is trying to boot through bootrom of your ethernet card.
Thanks
Posted on Aug 02, 2010
When I try to update Bios on Toshiba Satellite A215-S7462 The computer 'locks up' (becomes completely unresponsive), and the computer's display goes blank (turns off).
Updating the BIOS usually brings up some problems. It burns the motherboard. I suggest that you contact Toshiba regarding this for warranty support.
Dec 11, 2012 | Toshiba Satellite A215-S4747 Notebook
My laptop won't allowed me to login II don't what wrong with it..in the screen it says configuring updates then goes off and back again to configuring updates but just keep doing it again and
you can login to safe mode using F8 key on boot or just waite for fully updates instalation it can take some time and can reboot many times if it's installed many updates
Nov 14, 2012 | Toshiba Satellite M300-ST3403 Notebook
Need to update bios toshiba satellite c660,using ubuntu live dvd, will not boot hard drive, all normal recovery options used up
Hi There,
There are currently no easy ways to update a bios through linux at all - including live cd's. Your best bet is to make a bios update USB stick (or floppy depending on the age of the computer)
Here's a link to those instructions:
http://www.biosflash.com/e/bios-boot-usb-stick.htm
Alternatively, speaking from my own experience with a similar situation, you can take the hard drive out, use it in place of the usb stick, boot from it, update your bios, and go from there.
Jun 06, 2012 | Toshiba satellite c660
Toshiba laptop stuck on Microsoft Corportation screen
not to sure how that can be fix for its very important to have the updates done for it updates the system and it is required to let the process finish. Take your computer to a shop and they will be able to help u but do not ask how much it would cost. :)
Feb 19, 2012 | Toshiba Satellite L305-S5933 Notebook
Toshiba satellite C655 laptop has black screen with blinking cursor. It did complete some Windows updates. I was on the Internet then my laptop just shut down and it in this black screen with blinking...
Turn the computer off all of the way by holding in the power button until it shuts off.
Turn it back on and immediately start tapping the F8 key. It should bring you to a menu that has an option for going to "Last Known Good Configuration". Choose that option and see if it boots up.
If pressing F8 doesn't bring you to the menu - you may need to run diagnostics on the computer. To get to the diagnostics, attempt to boot to the Boot Menu by pressing F11 or F12 at the boot screen and see if it gives you the option to run diagnostics.
Nov 15, 2011 | Toshiba Computers & Internet
I HAVE TOSHIBA A45-S151 AND I WANT TO BOOT IT FROM EXTERNAL USB DVDWRITER FOR INSTALLING FRESH WINXP-SP3 FROM DVD BUT IT IS NOT BOOTING BECAUSE MY LAPTOP IS NOT SUPPRT EXTERNEL USB CDROM BOOTING OPTION....
A BIOS update may still not allow you to boot up from an USB port.
You can download theBIOS updates and device drivers for your model laptop from the Toshiba WEB site from theirdownload page. Make sure you enter the model of your laptop so you can get thecorrect drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp http://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
Sep 09, 2011 | Toshiba Satellite A45-S151 Notebook
The laptop is stuck in a cycle and won't start keeps saying configuring updates stage 3 of 3 .0% complete it thenthinks about it then screen goes dark and tries to start again. I have tried to reboot and...
Re boot in safe mode and run 'restore point' from the search box. Select a date/time just before the problem update happened. That will reset your date/time to before the update.
Feb 25, 2011 | Toshiba Satellite Pro L300 Notebook
Configuring problems
Get the system to enter safe mode,turn off auto update, and do a system restore. Then go to update and pick, check for updates but let me choose whether to install. Then look at the updates and install
one at a time, or you can post back the update# and we will tell
you what is important and which ones you can hide.
Apr 09, 2009 | Toshiba Satellite Pro L300 Notebook
Won't start
hmmm..that's weird..here's a notion. are you connected to the net, with wireless or direct connection? If you disconnect, the updates will shut off, since there's no connection found.
try that first..
Feb 17, 2008 | Computers & Internet
Toshiba Satellite Pro A210-EZ2202X Notebook Logo
63 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
