Question about Hammond Xk 1 Drawbar Organ
HAVE A HAMMOND XK 1, WHEN I TURN IT ON (ATTN: BACK UP ERROR! 40K)
Hammond rt3 service manual
For a service manual, contact Hammond directly.
Apr 28, 2017 | Hammond Music
Where do I locate serial number for Hammond A-205?
Normally it's either on a sticker on the top of the internal shelf (remove the back cover to see) or it's on a label attached to the underside of the lower keyboard. You have to lay down and look up to see it.
Aug 19, 2016 | Hammond Music
Won't load to default
Hi Lloyd,
The introduction in the manual warns that you should ask your dealer or store in order to change the batteries. I'd suggest seeing if they have any advice.
That said, how are you trying to default the settings? I've copied the two ways below. Maybe try whichever one you haven't yet. I hope this helps.
Manual: http://hammondorganco.com/wp-content/uploads/2011/03/XK-1manual.pdf
Default #1:
In this mode, you can return entirely or partially to the default setting as set at the factory.
To locate this mode:
Touch the [MENU/EXIT] button for the MENU display, select PAGE D by the [PAGE] button, and then touch the [3] DEFAULT button. To initialize each parameter, touch the button and then [4] OK
1. ADJUST PRESET
  • Initializes the content of the Preset Key [B].
  • If the Drawbar Control mode is at "UPPER A#/B", the content of [A#] is also initialized.
  • If you do this operation before you start a new setting, you can start from the factory
  • setting.
2. PRESET
  • Initializes the content of all Combination Presets.
3. GLOBAL
  • Initializes the Global Parameters such as Master tune or assignment of the Foot Switch.
4. LESLIE
  • Initializes the content of all Cabinets.
5. ALL
  • Initializes all parameters of this keyboard.
  • If anything caused an unstable trouble on this keyboard system, the trouble would be cleared.
Default #2
Please perform the following steps to reset the XK-1 to the initial default setting.
1. Switch off the power of the XK-1.
2. Hold the [REC/JUMP] Button, and switch on the power.
3. Continue to hold down / Keep pressing the [REC/JUMP] Button until "Loading Default..." appears on the Display.
4. After 5 seconds if everything is in order, PLAY Mode appears on the Display. (Completed)
Dec 20, 2013 | Hammond XK1 Pro Drawbar Organ
Load to default not working
Did you follow the instructions from the manual? If yes, at what point did this process fail?
What type oil and how much should be placed in each cup when oiling?
It is anybody's guess as to what type instrument you might be talking about... I MIGHT guess a Hammond organ but that is only a wild guess. Should this be the case go over to the:
Organforum.com where there are a lot of Hammond owners. You should ONLY use the Hammond oil. Also read this site: http://www.theatreorgans.com/hammond/faq/hammond-faq.html
Sep 15, 2011 | Music
I have a Hammond XK1, I plug it in and everything is fine. Once I turn on the recessed ceiling lights with the three rotrary dimmer switches, I get a loud scratchy/hummming line noise through the amp,that...
It is probably so kind of interference from the rotary switches. It is in the shielding of the Hammond organ. You might try some aluminum foil around the unit certain areas at a time which will give you an idea if it will help and what areas need to be shielded. If that does the trick you install the aluminum foil shield inside the chassis. Hope that helps. Let me know..
Jul 25, 2011 | Hammond XK1 Pro Drawbar Organ
I have 2 digital pianos and an xk3 Hammond but i find the xk3 is out of tune to the pianos. is this possible can you help me please Gordon
Ooften there is a setting for the pitch. Set it to A at 440 Hz which is usual standard. HOWEVER make sure it is really a pitch difference as the ear can be fooled by the "hammond" type sounds.
Dec 29, 2010 | Hammond XK-3 Lower Manual - Pro Style...
Hammond organ, L series brought out of lomg term storage problem
Lubricate with OFFICIAL Hammond oil immediately! Then let sit for a couple weeks. Manually turn the generator and add lube as needed until free. If bearings still sticky, put a bit of CRC226 on them individually and free them, then lube with the hammond oil via the wicks.
CRC226 is available at Home Depot in electrical dept.
Also, go to the organforum.com for additional help.
Jan 24, 2010 | Music
Schematics service manual hammond grandee 11100
Older Hammond schematics are often available online at Captain Foldbacks site.
Search Google for "Hammond schematics"
Jan 22, 2010 | Music
Hammond Xk 1 Drawbar Organ Logo
81 people viewed this question
Top Hammond Music Experts
drivealot
rhodesworks
Are you a Hammond Music Expert? Answer questions, earn points and help others
