Question about Roomba Irobot 4110 Floor-vacuuming Robot, Sage
SOURCE: Roomba Discovery
I read somewhere that you need to clear the software in case there is a glitch. To do this, take the battery out and then, simultaneously hold down the "spot" and "clean" buttons for 30 seconds. Replace battery. This has worked for my Discovery model.
Posted on Oct 10, 2008
SOURCE: Roomba shuts down after a few minutes
The brushes are clean on the outside, but probably not inside of the little yellow contact on the end. Also the junk that collects on the brushes finds its way into the gear box. Mine kept shutting down w/ the "Please remove and clean Roomba's brushes" message. I finally gave up and took it apart. There was a surprising amount of junk in the gear box. After I got it apart, I cleaned it out and I even used a straight pin and a pair of tweezers to get all of the gunk out. Now it runs like new. I'm no mechanic, but I used to help my daddy fix things around the house. I posted my solution to the problem and it has worked for a couple of other people too.
Posted on Dec 30, 2008
SOURCE: problems with roomba 530
before taking apart your Roomba read this!!! First to see if it is a defect or really the brushes, take the brusehs out and run roomba with out them. If you still hear the clicking/ thumping then try taking it apart or call roomba. But if the clicking/ thumping goes away when the brushes are out you're in luck! Take the brushes. The brushes have little yellow nubs... those come out. pull them out, and you will see a lot of hair waiting for you. clean all of the hair out ( tweezers are wonderful for this). Once they are cleaned out put the yellow nubs back on. Put your brushes back in and you're Roomba will be back to business in no time!!!
Posted on Jan 10, 2009
SOURCE: Roomba stops and beeps three times.
After reading Solution #4 and not feeling much of any air come out of the vent, I used a flat head screwdriver to remove the grill at the back of the debris bin. I then spun the vacuum impeller around, shaking out any debris that was stuck (a little wad that had plugged it came out). I then replaced the grill and put the dirt bin back on, and my Roomba worked!
Posted on Sep 28, 2009
Nov 28, 2013 | iRobot Roomba 530 Robotic Vacuum
Jul 12, 2013 | Vacuums
Nov 22, 2012 | Vacuums
May 16, 2010 | iRobot Roomba 530 Robotic Vacuum
Mar 27, 2010 | Roomba Robotic Floor Bagless Vacuum
Nov 09, 2009 | Roomba Robotic Floor Bagless Vacuum
May 13, 2009 | iRobot 4150 Roomba Vacuum
Apr 06, 2009 | iRobot Roomba Red 4100 Bagless Robotic...
Mar 25, 2009 | iRobot Roomba Discovery SE Bagless Robotic...
Dec 22, 2007 | Roomba Robotic Floor Bagless Vacuum
Mar 21, 2014 | Roomba Irobot 4110 Floor-vacuuming Robot,...
Sep 08, 2012 | Roomba Irobot 4110 Floor-vacuuming Robot,...
115 people viewed this question
