Question about Panasonic PT-50LCZ70 50" HDTV
No sound when in hdmi mode - Panasonic PT-50LCZ70 50" HDTV
    Problem Solver:
  • 14 Answers
One or more of your cables are not in the right place and or u have not in the correct mode
Posted on Jan 18, 2013
Surround speaker is not working.
Make sure your receiver is in surround sound mode on the sound fields for that input. Some receivers have independent sound mode settings. example would be hdmi 1 is set to 2 channel stereo while hdmi 2 is set to PL II movie which is a surround sound setting. Hope this helps.
Feb 10, 2015 | Vizio Audio Players & Recorders
Denon AVR - 2807 flickers in TV mode with picture & sound.
Change the hdmi cable and try. If not then you have an hdmi fault module.
Dec 15, 2013 | Denon AVR-2807 Receiver
Sound doesn't work in HDMI mode, just picture. I tried buying a new HDMI cord but that didn't work either. Then one night the TV just turned off and now it won't turn back on.
Likely not related but HDMI does not like being connected if either unit is plugged in or powered up.
As to the TV let me know the brand and model number and what if any lights at all come on when you plug it in etc.
SD TECH
Dec 11, 2012 | LG 62SX4D 62" Television
How to change sound output mode of HP probook 4510s
You need to connect laptop headphone connector to TV for sound.
Feb 25, 2012 | HP ProBook 4510s Notebook
No sound
Check the on screen sound set up to see if the sound for HDMI mode is set for analog output (using RCA Red and White audio output jacks) or through the HDMI port.
Jul 02, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
No sound when in tv/video mode
Do you have it connected with HDMI? If so, run the HDMI directly to the TV and run an optical or digital coaxial to the receiver. That will solve the problem. If that's not the case, go into the receiver's main audio menu and make sure it's set to "auto" or "digital" or "analog" whichever you are running. Hope this helps
Oct 17, 2009 | Sony BRAVIA DAVHDX275 Theater System
No sound in hdmi mode unlock flashes on display I get sound in cd
Its asking your permission to unlock the setup menu. When you hit setup, and it says "unlock," you have to hit one of the navigation arrows on the remote control. Once you have unlocked the menu, you can assign the audio to that HDMI input.
Jul 30, 2009 | Harman Kardon AVR 130 Receiver
I have tried to connect my SD 6100 and am getting no picture. I get sound.
You must use the remote to toggle the player OUT of HDMI output mode to use the non-HDMI outputs (like standard RCA-jack VGA or s-video or component video output). The device displays black screen by default unless you're using HDMI, so it's not possible to see the menu if using s-video. The manual states to press the 'Progressive' button to change modes. Unfortunately, you can't see what mode you're toggling through until you hit the right one (Toshiba blew it here!!). Power on the device WITHOUT a disk in (you can't change modes during DVD playback mode). There are four output modes, so press the 'Progressive' button on the remote and wait for 3 to 5 seconds for the player to switch output modes. Repeat this up to four times to cycle through the available modes. During one of the modes, you should see output to your screen through the cable hookup you've physically attached. You will also notice the led's on the front panel go on and off during the process at times. If you ARE using HDMI, then you have to select a mode your TV or monitor can handle. When in HDMI mode, you'll notice the front panel HDMI led's will light up. There are five modes here - 480P, 720P, 1080i, 1080P and AUTO (when all four leds are lit). Select the HDMI mode that your TV works with. Good luck ~ and don't bother calling Toshiba support ... friggin waste of time talking to a recording that's dumber than Sh#@!!
Jul 09, 2009 | Toshiba SD6100 DVD Player
XBOX 360 Elite HDMI SOUND PROBLEM
First you have to activate the HDMI audio option in your Sony suround system options so as to activate it. Please try this and then tell me what happens.
Nov 25, 2008 | Microsoft Xbox 360 Elite Console
No picture but sound on panasonic plasma
Unplug the TV and disconnect any HDMI cables to the set. If the issue goes away there is a possibility that your HDMI source is causing the problem. Anything on the HDMI can cause odd problems with the TV since the serial data and serail clock lines are routed on HDMI. Those are the 2 commmunication lines used throught the TV for operation so anything HDMI that might load down one of those can cause issues.
Mar 07, 2008 | Televison & Video
Panasonic PT-50LCZ70 50" HDTV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
