Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Water from ice makers leaks and builds up in botom of freezer
Ice maker works fine. If we turn off the ice maker the problem stops.
  • 410 Answers
Ice maker leaks are usually a sign of icemaker mold corrosion eating the lining off the icemaker causing it to leak. the only repair is to replace the complete icemaker. you will need a complete model number from the unit and the part can be ordered online thru whirlpool or some of the other appliance parts sites. you may even have a local parts warehouse where you live. hopw that helps peyton
Posted on Jan 28, 2009
Kenmore Model 78862891 freezer defrost drain keeps freezing up every month.
It can be issue with water valve its clogged and not letting the water to stop running and that is causing the overflow of water and that is getting freezed and then clogged.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Kenmore model 106.72009010 leaking water onto floor
Defrost is not working and that is causing the leak.
These will help.
Thanks,.
Ice maker
other ice maker related issues and solutions:---
Ice maker dispensing ice with black or white plastic pieces in ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-ice-with-black-or.html
After replacing ice maker assembly, ice is not getting made?
http://alltypesofpartsreplacing.blogspot.com/2011/10/after-replacing-ice-maker-assembly-ice.html
Ice maker is leaking water and causing the ice to freeze?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-leaking-water-and-causing.html
Ice maker is noisy and not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
Refrigerator ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/refrigerator-ice-maker-stopped-making.html
Ice maker leaks water into ice bin causing a glob of ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaks-water-into-ice-bin.html
Amana Refrigerator leaking water from ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/amana-refrigerator-leaking-water-from.html
Ice maker leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaking.html
Ice maker is dumping the ice cubes out before frozen solid.
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-dumping-ice-cubes-out.html
Water overflowing ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflowing-ice-maker.html
Ice cube is getting stuck up hard in ice maker
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-cube-is-getting-stuck-up-hard-in.html
Icemaker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/icemaker-quit-working.html
Quit making ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/quit-making-ice.html
Water leaking into ice tray, frozen glob of ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-leaking-into-ice-tray-frozen-glob.html
Not making ice, and water leaking in freezer?
http://alltypesofpartsreplacing.blogspot.com/2011/10/not-making-ice-and-water-leaking-in.html
The ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice_20.html
Ice maker not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-making-ice.html
Ice maker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-quit-working.html
Ice maker dispensing black pieces of plastic in the ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-black-pieces-of.html
Replaced Ice maker but its still not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/replaced-ice-maker-but-its-still-not.html
Ice maker leaked creating an ice block?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaked-creating-ice-block.html
Ice tray leaked?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-tray-leaked.html
Ice maker stopped functioning?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-functioning.html
Ice maker stop working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stop-working.html
Ice maker failed
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-failed.html
Old ice maker stopped working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-stopped-working.html
Old ice maker started leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-started-leaking.html
Ice maker not working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-working.html
Ice maker overfills and cause water to flow into ice dispenser and freezes?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-overfills-and-cause-water-to.html
Ice maker didn't make ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-didnt-make-ice.html
Ice maker was leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking.html
Ice maker was leaking after it filled up with water?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking-after-it-filled.html
These will help.
Thanks,.
Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
Ice maker is splashing water all over back of freezer and it builds up til the fan starts to make noise if I turn it off and defrost the ice it will start up noise free til the ice builds again.
What is the model number of your unit? When the ice builds up, does the ice just build up where it is splashing or is the ice also building up behind the back wall of the freezer?
Thank you! Richard
Jul 21, 2011 | Refrigerators
I recently replaced the evaporator fan motor. Now I have two problems: 1) Ice maker does not dump ice automatically. The water line is clear and fills up the tray. The ice freezes but will not dump the...
Hi and welcome to FixYa, I am Kelly.
You made this statement:
I have to manually make the ice dump. 2) I now have a slight build up of ice under the ice maker where it appears the water from the ice tray is leaking and the inside of the freezer also has a slight build up of frost on the walls.
From my 40 years of experience that statement is telling me that the freezers' evaporator coils are blocked with ice. (i.e frost on the walls) When the coils become blocked or built up with ice everything APPEARS to be working fine but the actual freezer temp is above 17 deg F. An ice maker will not initiate an ice-harvest cycle until the temps are between 14 - 16 Deg F. I.e it is not cold enough to automatically make ice because the ice maker thermostat is not closing at 14 - 16 deg F to start the ice harvest.
So I will pose these questions for you and answer them:
Q? What causes the ice on the walls
A: The unit is not defrosting properly.
Q? What causes a refrigerator to not defrost properly?
A: There are several; reasons that a refrigerator will not automatically defrost
1. The defrost control has failed (Most common failure)
2. The defrost heating element has failed
3. The defrost thermostat has failed
4. A wiring problem in the defrost circuit
Now.... you also made this statement:
You may have a leaking ice tray but it is quite rare. What usually causes an ice build up directly under and ice maker is the inlet water valve leaking / bypassing water when it is supposed to be shut off. An inlet water valve will bypass water when the internal diaphragm fails or debris is blocking the needle seat of the diaphragm. Either way the only remedy is to replace the inlet water valve because the valves are NOT repairable.
Reach inside your freezer and squeeze the rubber tube that fills the ice maker with water. If there is a problem with the inlet water valve the rubber tube starts freezing up with ice. Eventually when the rubber tube is totally frozen the plastic tube on the back of the refrigerator that connects to the rubber tube either leaks or separates from the rubber tube and ports water onto the floor.
If you really want to prove that there is a problem with the inlet water valve turn the ice maker OFF. Remove the plastic tube from the rubber ice maker fill tube (Just pulls out) and place it in a bucket overnight. IF you note water in the bucket the next day then the inlet water valve has for sure failed. Sometimes they LEAK intermittently when the failure first begins so the bucket test may not reveal a leaking inlet water valve. The key here is you said you have water UNDER the ice maker and you suspect a tray leak.
Here is what I recommend you do after the overnight plastic tube in a bucket leakage / bypassing test:
1. Reinstall the plastic tube on to the rubber fill tube.
2. Turn the ice maker ON
3. UNPLUG the refrigerator and so a manual defrost by removing the freezer contents then directing a fan into the freezer compartment for just over 2 hours. (Makes a water mess)
4. Return the unit to normal service
5. Check for ice production 6 - 8 hours after you performed the manual defrost.
If you have automatic ice production you most likely have and automatic defrosting problem... BUT.... there can be a problem with the freezer door / light switch. The door light switch is a 3 contact switch. One contact is a common power wire and the other 2 contacts turn on the light and provide power to the ice maker (and some times the evaporator fan also depending on unit design)
Test the door light switch amd make sure the light will go off when the door is closed. (depress the plunger) If the light stays on the door switch is bad.
Hopefully you have enough information to understand what is happening with your refrigerator and what the causes of the symptoms you have are.
I think in the end you will have to repair the automatic defrost problem and replace the inlet water valve. Do not forget about testing the door light switch.
Thanks for choosing FixYa,
Kelly
Apr 14, 2011 | GE Refrigerators
Ice building up in the bottom of the freezer
The water supply line is leaking.Put some paper towels down after you clean up and check real often to back track where leak is coming from,maybe your ice maker is over flowing with water.When was the last time you replaced your water filter?Could be backing up,just replaced mine,it was leaking under the fridge,mine is a Sear's Kenmore,ordered a filter from Sear's,Cost me 50 buck's,My filter is at the bottom front,your's may be inside the freezer.
Apr 13, 2017 | KitchenAid KBLC36FKS Bottom Freezer...
Ice build up on bottom of freezer. Water leaks out of freezer possibly from melting. Water leaks onto floor of kitchen.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
May 19, 2009 | GE Profile Stainless Bottom-Freezer...
ICEMAKER NOT WORKING NEW WATER LINE
Ice maker must be on(arm up) .If the ice maker is turning and not getting water probably the solenoid valve is bad or the line between the valve and the ice maker is broken or frozen, if its frozen the valve is leaking and needs to be replace.For the ice maker to work the freezer must be working fine (freezing )But if everything is ok and the ice maker still dead(not turning) check if it's plugged in,right behind it and if this is ok the ice maker inside board is bad ,but replacing it is probably better to get a new one.
Apr 30, 2009 | Frigidaire FRT21H8 Top Freezer...
Ice maker leaks inside freezer
check the water discharge hose which fills the ice maker after ice is dumped into the bin. the line is located in most cases at one end of the ice maker and allows the water to flow into a funnel like device above the ice maker mold. the hose has the diameter of a penny, it is probably misaligned with the ice maker itself/
Sep 13, 2008 | Samsung RM255LASH Side by Side...
Check the cam wheel beneath the front cover of the icemaker it is probably not turning.
May 31, 2007 | Kenmore 21.7 cu. ft. Top Freezer...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
154 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
