Question about LG Washing Machines
I have an LG washing machine. As i turn on the Machine and start a load it runs for a short time then turns off. I noticed that one time it turned off the code "PF" came on the screen for a moment the
Model # WM2277HW
    Problem Solver:
  • 14 Answers
Pf is an indicator for power falier check your power supply to your washer or try another power point
Posted on Jan 25, 2013
  • 16 Answers
SOURCE: LE error
try using a-fresh its should help you out.
Posted on Nov 03, 2008
SOURCE: Drum will not spin
I unplugged the machine for 1 hour and the computer reset, and it is working fine
Posted on Jan 05, 2009
MNTECH
  • 1543 Answers
SOURCE: Lg Tromm washing machine drum will not turn
the Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty. Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
Posted on Mar 01, 2009
localwonder
  • 6784 Answers
SOURCE: dE code on WM0642HW TROMM washing machine
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
Posted on Jul 12, 2009
rdrsp
  • 85 Answers
SOURCE: LG model WM2277HW front load washing machine,
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
1) in my experience, sometimes this proves to be intermitent, and upon unplugging and waiting for 5 minutes does not seem to resurface again...
2)Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount.
this could prove to be very challenging to somebody who does not know what they are working with, i suggest if the problem is not intermitent, call a tech.. hope this helps.
Posted on Oct 26, 2009
What is the issue with LG washer
LG WM2277HSW XL Front Load... Repair Questions - Fixya
www.fixya.com/.../p95436-lg_wm2277hsw_xl_front_load_stackable
Recent LG WM2277HSW XL Front Load Stackable Washing Machine questions, problems & answers. ... My frontloader washmachine will not turn on · LG ...
LG WM2277HSW XL Front Load Stackable Washing ... - Fixya
www.fixya.com/search/p95436-lg_wm2277hsw_xl_front_load.../open
LG WM2277HSW XL Front Load Stackable Washing Machine, open related issues. Get free ... Wait 5 secs after turning off door release should open. If this does not ... OE error message won't open door, won't spin out water What is filters & open it are my problemsDue to that I cann't ... Where is it sticking and how do I fix it?
LG Tromm WD 12270 RD washer and dryer 'LG ...
Dec 19, 2015 | LG WM2277HSW XL Front Load Stackable...
There comes black stuff out of the washer when i spin. Isit the stasoft?
Fill your machine with hot water (if you only have cold water connected, then add hot water with a bucket) until the machine is filled to the top mark. Add a cup of dishwasher powder and stir it to dissolve. You can also let you machine run a short while, but be carefull that the water is not pumped out. Turn the machine off and let it stand overnight. Then turn it on the next morning and let it wash a complete cycle. You don't have to let the rinse part of the cycle complete. Just turn the machine off when the first water has been pumped out.
What this does: The machine builds of a residue between the drum and outer housing which is not removed in the normal wash cycle, especially if you don't wash with hot water. LG recommends that the machine is cleaned in the above way once "fluff" or black residue is starting to show in clothes after washing.
Mar 11, 2015 | LG WFT1071TP Top Load Washer
My wm2455h turns on by itself and after some time, it turns off. What is causing this>
It seems that the Main Control Board of your washing machine is playing up. The fact that when you unplug the machine from the mains, the main control board resets itself and you are able to start the machine points in this direction.
Nov 17, 2014 | LG WM2455 Front Load Washer
Lg tromm washing machine
If the machine still works and that is the only problem I would use it till it doesn't, really they cost so much to fix sometimes
Sep 01, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Users manual
The LG Canada website has it.
http://ca.lgservice.com/index_b2c.jsp
Click on "Owner's Manuals" on the left hand menu and fill in the details, model number WF-T8016TP. You'll need IE, not Firefox...
Jan 24, 2009 | LG WFT1071TP Top Load Washer
LG WM-2277HW
It sounds like a problem with the control board.  You will need to have the unit checked out by a qualified LG technician and possibly replace the board.
Sep 20, 2008 | LG WM-2277HW Front Load Washer
LG WM1285 WASHING MACHINE
hi Hills659.
this is all i could find out.
What does CL mean on LG washing machine?
LG Washer CL Code Definition (What does it mean?) = The CL Code on front loading LG washing machines simply means the CHILD LOCK feature is turned ON.
The CHILD LOCK feature on your LG washer is meant as a safety precaution so children are not able to change wash settings. CL is not an error code. It is indicating that the CL or CHILD LOCK feature has been turned ON and is active.
LG Washer Error Code CL How To Turn CHILD LOCK Off
Dec 17, 2017 | LG Washing Machines
LG WM 12230FB WASHING MACHINE
the belt which s at presently fixed is not of proper size change the belt and try it. the drum will run properly
Jul 06, 2008 | LG WM-2277HW Front Load Washer
LG front load washer spinsense buttom does not come on
I have the LG WM3988HWA, which is a washer and dryer in one. The way it works on ours is that you press and hold the Spinsense button for 3 seconds before you start a wash, or while a wash is paused. When Spinsense is on, the LCD will say "Spinsense" on the right-hand side when the machine is running. Nothing happens with the light on the Spinsense button.
Spinsense makes a huge difference as the machine is on the second floor of our old wooden house. I don't even notice the spin cycle with Spinsense on.
Problems:
1. We need to turn it on for every load. This is just annoying.
2. Spinsense will not turn on when you've the Dryer option activated. This means we have to do two trips to the machine for each load, or have our house feel like it's shaking to pieces. There's no good reason that the Spinsense/Dryer shouldn't work.
Jun 24, 2008 | LG WM-1832C Front Load Washer
Washing Machines Logo
204 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
