Question about Belling BE808 Compact Refrigerator
How do I replace light in Belling BE 808 fridge
Do you sell belling built in fridge freezer BSTAT7090
Michael, No, we answer question to every day problems, here at fixya.
Mar 12, 2016 | Belling Dishwashers
I AM LOOKING TO PRICE A BELLING BUILT IN FRIDGE FREEZER
Michael, Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Cooling
Belling Integrated 70 30 Fridge Freezer
Buy Belling BIFF233 Integrated 70 30 Frost Free Fridge Freezer from...
http://www.powercity.ie/?par=45-25-BFF233
Mar 12, 2016 | Belling Refrigerators
Were do the wires go on a belling fridge
You need to talk to the factory. I would get in touch with belling, however,if you only have two wires going to your thermostat, it doesnt matter which goes to which terminal. its an A/C circuit. Your wall voltage goes through temp control. If you have MORE than two wires, disregard the above. Your experience is why I only ever replace one wire at a time whenever i repair a refrigerator. You can reply here or send me a question from my website: www.FixMyFridge.net
Mar 15, 2010 | Refrigerators
Belling Bi60 Integrated fridge freezer (fridge) not working
I also have probs with Belling Bi 60 less than 3 yrs old...already had
enginneer out & paid......now fridge aint cooling showing H
its frost free and this may be too sensitive ??
tried unplugging no Go
wont buy Belling again
Dec 15, 2008 | Refrigerators
Belling B160 Fridge is warm Freezer is cold
In fridge freezer where the fridge is under the freezer, the cold air falls down a channel from the freezer. I had a similar problem and it was a failed defrost thermostat. The evaporator in the back of the freezer was a solid lump of ice and wasn't allowing any cold air to drop into the fridge. The defrost thermostat was changed and then 30 minutes with a heat gun melted the ice. It was worked fine ever since. On a side by side fridge, there is a bypass from the freezer to the fridge. Either way, you need an engineer. You are not the only one to see this problem with that model. I see two in Google.
http://www.ukwhitegoods.co.uk/forumsphpbb3/belling-b160-fridge-freezer-t48629.html
Sep 19, 2017 | Refrigerators
Belling be810
Hi the problem is with a clogged drain hose that's why all the water. to unclog turn off fridge. pull away from the wall . remove back panel. clean all vents . locate drain tube, by the drain tray. clean out the drain . thanks the appliance doc
Oct 06, 2008 | Belling Freezers
Belling fridge/freezer controls
most likely that is an on off switch for the temperature alarm. the 1 or l is the on psosition and the O is the off postition..
Nov 16, 2007 | Freezers
Belling intergrated Fridge Freezer
On integrated appliances the power supply is invaribly behind the unit. However there is normally an isolator to the side of the unit or in a side cupboard. Hope this helps.
Aug 06, 2007 | Belling BE811 Bottom Freezer Refrigerator
Belling BE808 Compact Refrigerator Logo
Top Belling Refrigerators Experts
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
Bill Boyd
Are you a Belling Refrigerator Expert? Answer questions, earn points and help others
