Question about Vista Archery
When released the bow makes a clacking noise like the string is slapping the limbs.
Pulls smoothly but when released makes a sharp noise like the string is contactiong the limb creating a clacking noise.
  • James McCue
    James McCue Jan 18, 2013
    It is a takedown type bow.
  • 305 Answers
Remove string and check limb pocket inserts and limbs for delamination or coming apart. You can buy string dampners if it is just string slap.
Posted on May 06, 2014
Clack..clack.. clack noise when lightly applying brakes. front passenger side
That is the brake pads slapping in the mounting bracket . When the brakes where done did they use new mounting hardware > Did they lube the contact points for the pad slides etc... Your better off taking it to an ASE certified repair shop , not a tire an brake shop . Or the ford dealer .
Mar 12, 2016 | 2006 Mercury Grand Marquis
What type of string do i need for my bow
Usually on the lower limb of the bow is marked string and cable length. If not will have to contact manufacturer.
Feb 12, 2014 | Crosman Sentinel Youth Long Bow Set
Squeaking noise when drawing back Barnett vortex bow
The four rubber grommets where the string is attached to the limbs need some DRY lubricant. When drawing, the grommets 'slip', and that slip 'plucks' at the string creating the creaks. Keep applying dry graphite to these points and the bow will quiet up nicely.
Aug 21, 2013 | BARNETT OUTDOORS LLC 10 Barnett Vortex...
Assembly for pse stalker bow
you need a bow stringer for a recurve bow. $15.00 cabelas
Oct 26, 2012 | Puget Sound Energy PSE Stalker Recurve Bow
Why does the bow length need to match my draw length?
The bow length needs to match your draw length because the bow limb is designed to be used at a particular draw length range. For instance if you use a bow with limbs too long for your draw length, you won't be able to flex the limbs enough to make them efficient.
Aug 26, 2012 | Betsey Johnson Archery
What's a Recurve bow?
Often made of more than one material, either laminated carbon or fiberglass, with the tips curving away from the archer -- a highly recommended bow for beginner archers, in addition it is also the exclusive bow of the Olympic Games
Jul 30, 2012 | Archery
How does a bow work?
A bow is a flexible arc which shoots aerodynamic projectiles called arrows. Essentially, the bow is a form of spring powered by a string. As this string is drawn, energy is stored in the flexible limbs of the bow; the energy is transferred to the arrow when the string is released, projecting it much farther than a weapon could be thrown.
What's a crossbow?
In a crossbow, the limbs of the bow, called a prod, are attached to a crosspiece in order to allow for mechanical pulling and holding of the string. This mechanical pulling allows for a much larger draw weight than could be drawn by hand. A crossbow is mostly recommended for hunting
What is the difference between Dacron, Fast Flight & D97 string?
Dacron isthe standard for traditional bows. It has some stretch to it. Therefore, it isa little more forgiving for your bow. It is also a little quieter. Fast Flight and D97 don'tstretch as much and therefore transfer more energy to your arrow. It may giveyour increased performance. D97 will give you slightly better performance thanthe Fast Flight. Make sure that your limb tips are reinforced to be able to useFast Flight and D97.
All Bingham Bows will handle the increasedstrain of Fast Flight and D97, as long as the tip overlays are finished to anappropriate thickness.
Jul 09, 2012 | Archery
Clacking noise at different engine idles on my Yamaha V Star
Lots of bikes make a clacking in the transmission , especially when cold at idle. Basically the engine accelerates and decelerates between each piston firing, and you hear the backlash in the gears slapping back and forth. Without hearing it I can't say for sure, but find someone else with a similar bike and see if it sounds the same.
Sep 23, 2009 | 2002 Harley Davidson XL 1200 S Sportster...
Archery Logo
161 people viewed this question
Top Vista Archery Experts
pbickwermert
Level 1 Expert
Andre De Beer
Andre De Beer
Level 1 Expert
Tom Chichester
Are you a Vista Archery Expert? Answer questions, earn points and help others
