Question about Bunn VPR Coffee Maker
VRP it keeps on steeming all the time i turn the temp up and down and half a pot always steems out what is going on
  • billhrsn Jan 24, 2008
    There is no on/off switch on this model, so a test takes patience. Plug and pray. My unit will produce some steam from the water tank after ten or so minutes, make noises as it should, then stop making steam and noise after five more minutes. No water ever reaches the filter basket or nozzle. Both plates heat up fine, both plate switch lights come on. There are no other controls, no drain for the tank. There is a part inside that has a post and tiny two blade propeller on top. Is this the temperature control? What would need to be replaced? Will Bunn send me the parts I need? This heavy duty machine would be perfect for our small church cafe.
  • Anonymous Nov 21, 2008
    It sounds like you are referring to the burners and not the actual brewing cycle which is the same problem I have
    Sergeant:
  • 274 Answers
Thermal switch in the burner is defective. You can take it apart and replace it. You have two possibilities here. If you take it apart, you will either need to replace the temperature control switch completely. You will see a part number and mfg name on the switch. See you can find an electrical store near by that has them. Or, there may be a seperate "high temp thermal switch" on the burner element. Don't know that particular design but either way it sounds like the thermal swich is not letting the burner shut down ans cyclt as it should.
Posted on Jul 14, 2007
Our Bunn VRP SERIES MAKES NOISE WHEN WATER IN THE TANK SITS AWILE
There are two heaters in a VRP unit (Pour over style) The brewer has a tank that your last office person poured in a full pot of water. The main heater senses the colder water and begins to reheat the water to near boiling. The new water pushes out the same amount of water into the brewing basket (funnel with coffee). Once the new water has come up to temperature then the main heater turns off. There is a warming blanket around the inside tank. This keeps the water hot and ready to brew. It uses less power than the main heater. If this blanket fails then the water will cool down to a point where the main heater heats everything back up. You may not notice this as the only indication is luke warm coffee on a freshly made pot or a 'boiling' noise every 15 - 25 mins. This VRP probably needs servicing (check Thermal blanket and Thermal fuse)
Sep 17, 2017 | Bunn Coffee Makers & Espresso Machines
My steem iron down n up both hot OK bt steem not following I thing so pump not working g soPlz tell me this where I get in UAE Dubai sir plz reply soon my iron not in use problem sir thank for reply
I would disassemble and clean it using vinegar to remove scaling that builds up from tap water, same issue caused a lot of problems for Keurig. Just make sure it is unplugged and cool to the touch before working on it.
If you need further help, reach me via phone at https://www.6ya.com/expert/christopher_978a4cfc8a812206
Nov 30, 2015 | Cell Phones
Steem not flowing
Is it getting HOT
Nov 30, 2015 | Irons
2000 suzuki steem 5 gear jump ?
please explain the full story.
i have 5speed transmission option
and in 5th gear it does something odd.
what?
1: im going on flat ground, up hill , down hill?
2: im accelerating , deceleration or holding steady speed.?
and what does it do , go to neutral and RPM goes why high?
Define JUMP>
May 05, 2014 | 2000 Suzuki Esteem
I have the Euro Pro Steam Caddy #S3325H. I have had it for years and have never used it. Now I have a ceramic bathroom and dirty grout. There are no instructions in the box, and I can't get the steam to...
dont steem this grout,,,it will only fall out or you could crack a tile,,,wipe on some strong bleach/loo cleaner and scrub it with a stiff brush its a lot safer than steeming it
Aug 21, 2010 | Euro-Pro S3325 Handheld Steam Vacuum
My Shark Steem Mop ,No steem coming.Need help.Thanks
I assume that you have read the instructions and know that you have to push in on the handle to make the steam come out....Me being the man that I am did not read those directions and it took my wife to show me how to use the natural pushing and pulling motion to make the steam work...
heatman101
Aug 07, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Top and bottom caked with junk
well now who's a naughty girl then??? il give you a tip,, next time your cooking in this sandwich maker put a small drop of oil or butter in it first,,,it stops all this sticking,,,,however,,, get a wet cloth,,put it in your "hot toster" and tost it a bit,,,,,the steem will clean off all the gunk for you and what it cant get off it sofens so you can rub it off with a paper towel,,,,or wet cloth,,,clean it whan its warm not when its realy hot! burnt fingers hurt? this also works in microwaves put a dish of very hot water inside shut the door and leave it for a time,,the steem dose the work for you,
now mine's a bacon butty please??
May 05, 2010 | Star CG10I Sandwich Maker
Hayward H100IDP1 steeming pipe
english is good th epipe taking the steem out has a reason to be may be the heater is over heating or is has been left open by accident but here go if open may the heater exchanger is plug the pipe has been installed reverse or assembly valve is not good any more , is the flow to slow? psi at the filter must 10-18
Jul 28, 2009 | Hayward 100kbtu Pool Or Spa Propane Gas...
Bunn VPR Coffee Maker Logo
176 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
Marvin
Marvin
Inky Fingers
Inky Fingers
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
