Question about Emerson GF827 DVD Karaoke Player
Emerson gf827 does not recognize cds
My emerson GF827 karaoke player does not recognize CD's. I've tried switching CD's many many times, using the remote, powering on powering off. It did recognize a CD once but only once.
  • 2318 Answers
SOURCE: Emerson TC1351 chassis power switch doesn?t work but remote power does
If that contact cleaner did not work, get a new switch and replace it.
Before replacing it just short both contacts where the switch is soldered, the TV should turn ON and OFF.
Good Luck.
Posted on Feb 17, 2008
SOURCE: need code number for emerson TV to set up on sony remote
Go to http://tvservicemenu.blogspot.com for more help.
Posted on Mar 29, 2009
  • 213 Answers
SOURCE: my emerson tv/dvd player wont work.
need reader pcboard that set ontop of dvd it a chip that till the drifent from dvd to cd
Posted on Jun 02, 2009
  • 1116 Answers
SOURCE: Was messing with Karaoke system
Hit the A/V button and take the TV off of the input for the Karaoke Machine and switch it to the input for the TV. You switched the input device from TV to the port on the front of the TV, which must have your Karaoke machine connected to it. That is all. The graphics you are seeing are the screensaver for the Karaoke machine.
Posted on Aug 09, 2011
gopakumarg43
  • 74482 Answers
SOURCE: Have a Emerson 6 chger CD/am/fm system. Do I need the remote to use the CD player?
Buy one universal remote control, which have setup codes for your device. Brand name isn't a matter.
Posted on May 07, 2012
I have a 2001 Honda Crv, the cd player keeps ejecting CDs before it has the chance to load them. The radio works fine, and I gave tried burnt and original disc CDs. Can anyone suggest a solution?
Are these CDs that you burned yourself? Older CD players won't recognize the audio file format of this kind of recording, only the established file format that typical retail CDs have used for years. In recent years, CD players have been developed to recognize more file types than just the old format; but with an older player like you have in your car, it wouldn't recognize what you were trying to play, as if you put a DVD in. It balks, and spits it out. You can burn CDs with the correct file format, you just need the appropriate software or file translator.
Apr 14, 2012 | Car Audio & Video
My karaoke machine will not play CDs
the only suggestion I can offer is clean the laser lens with a Q-Tip and rubbing alcohol gently and allow several minutes to dry, if that fails! the whole assembly will need to be replaced.
Mar 15, 2012 | Venturer CD-2160 Shelf System
I have my late husband's Pioneer PDF906, (100 disc capacity) and I created eleven music CDs on my computer which play perfectly in my computer, my car and my DVD player, but with the PDF906, only the...
The last 3 discs might be CD-RW which can be rewritten, but not all cd players will be able to read them. Just go to the store and buy some CD-R disks and re-burn the last 3 disks. That should solve your problem.
Jul 28, 2011 | Pioneer PD-F906 100-Disc CD Changer
The CD player does hardly read self- burnt audio CDs although every one of my other cheap Players i have at home or in the car can read them.
The answer depends upon the age and precise version of your Bose system. Not all CD players can reliably read CD-R and CD-RW discs, and even those which do are sometimes picky about the brand of recordable disc in use.
In my experience, all of the Bose Wave systems I've worked on have contained surprisingly cheap/average parts inside considering the luxury price-tag. Either stick to using other cheaper (and often far better) CD players for CDs you've burned yourself, or look into getting the CD laser pick up inside your Bose replaced with one which is known to have no issues with CDs of different reflectivity to standard pre-recorded CDs.
Jul 06, 2011 | Bose & Wave& Music System
Hello, I have a Technics HiFi system - I've had it for 10 years. The problem is that the CD player skips and jumps. I've tried cleaning the CDs but there are no scratches on them. I've also...
Its time to replace the optical unit ( lens ) of the CD player. Brace yourself the unit on some of those old players can cost more than a new DVD player.
Jun 02, 2011 | Audio Players & Recorders
My 760 recorder keeps show no audio when I try to record. I've tried hooking it up serval ways no luck. However it plays perfect.
You can not use normal Data CDs. Use CD-R Digital Audio CDs or CD-R Audio recordable CDs. If you use correct Digital Audio Recordable CDs, it will show OPC. Once you press Recording, audio out is coming. Otherwise you can not listing to audio. Please read manual carefully. Above will solve your matter.
From Channa
May 10, 2011 | Philips CDR760 CD Player
It wont play CDs
the cds you put in there are not compatible to the player.if it had been playing the same cds then it is time to take your set to a tech for repair it can be your memory chip or your lens.good luck.
Apr 18, 2009 | Memorex MKS5009 Karaoke System w/CD/CD+G...
Professional new karaoke system skipping and lyric problems
your disc is scrath or maybe the lens of your player is already weak,or have dust,if you can do the job,clean it with a soft cotton..wipe carefully with only one direction..try also the lens cleaner.
Feb 23, 2008 | Memorex MKS5009 Karaoke System w/CD/CD+G...
Problem with Karaoke System Memorex MKS5009
If it was "lying" in the attic, that is in any position other than upright, the drive probably has failed.
Sep 09, 2017 | Memorex MKS5009 Karaoke System w/CD/CD+G...
Emerson GF827 DVD Karaoke Player Logo
24 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
