Question about Electric Mobility Power Electric Scooter Power Wheel Chair Safety Flag
Hoverround doesn't go. Batteries are good.
Posted on Mar 08, 2009
  • 118 Answers
Carefully read across two pins, without shorting to the case or other pins. You should have 1 hot, one ground, and usually another ground that acts as a charge inhibit to keep the scooter from driving while charging. I would expect to see around 27 Volts DCX on the output, maybe more without a load attached (battery)
Posted on Jan 27, 2009
Is there a way to check if Hoveround charger is good? My light stays green all the time even after I've used my Hoveround MPV 5 usually after using a few x's the light would be Red.Controller acts ok
Use a voltmeter to test for 24 volts DC on pins 2 and 3 of the charging cord connector. You should get a reading of 26 volts or more for a good charger.
Jan 30, 2018 | The Health & Beauty
I can leave it plugged in for 24 hours and not have a full charge. Is this the batteries or the on board charger
There are a few things to consider with this type of problem.
How old are the batteries. When did you last have them tested. Is the charger output ok on load (test with an amp clamp type meter). is the charger the correct one for these batteries, small output chargers take longer to charge big batteries. Are all connection tight on batteries and anything to do with the charging circuit. Plug and socket type connection do fail on poor connections. Check voltage on batteries when on charge and off charge to see if the charger voltage is getting through to the batteries.
Jun 15, 2015 | Pride New Mobility Victory XL 4 Wheel...
Proscan 7044K-C tablet won't charge
Test your charger with a multi-meter, does it output the correct supply? If not you need a new charger.
If your charger is ok, take a look at the charging socket, is it damaged in any way? Does the charger feel loose when it's plugged into the socket? If so you may need to have your charging socket repaired/replaced.
After checking all this the next thing I would try is a new battery. However, most tablets will at least work from main supply, even if the battery is faulty.
Mar 21, 2014 | Tablets & eReaders
Battery charging
Check your charger to make sure it is the right one for your laptop. If it is then test it's output to make sure it is producing the correct voltage and amperage. You can read the label on the charger to find out what it should be. Then a simple test with a multimeter will tell you what you want to know. If that is all good, check the contacts where the battery plugs in. Are they in good shape? Not bent or broken. Clean them with a pencil eraser so they are shiny. Now, disconnect the charger and plug in your battery. Do you have an indicator of power? Will your laptop boot? If not, use the multimeter to test the output of the battery. It should read the same output voltage as the charger.
Jun 04, 2012 | Toshiba Satellite A665-S6086 Laptop
I have a MPV4 Hovaround Electric WheelChair Power charger does not charge. What is wrong?
weel two thinga could be the cause bad batteries or a bad charger, If you have a meter you can set it to 200 vdc and plug the leads into the 2 outer holes of the charger port located on the joystick it will read your battery voltage and should not be below 16 volts. with the same meter have someone hold the charger plug and with it on read the output of the charger across the two outter pins careful not to touch the center pin with the leads it should read 27-30 volts if it is working Hope this helps
Feb 26, 2011 | NRS Hoveround MPV 4 - Hovaround Used...
Jassy 1103, will not start charging the battery.\r...
the 1103 uses an onboard charger. Charger's life span is about 3 years; some fail in 6 months, some in 6 years keep in mind. You can charge the 1103 using an offboard charger which are available for about $50.00 on Ebay. Search for electric wheelchair charger. You want one that has a 4 to 6 amp rating.
The offboard charger has a 3-prong connector on one end and the other plugs into a grounded wall outlet. Plug the charger into an outlet and the three prong connector into the female three prong connector located at the bottom front of the joystick. Give it a good overnight charge and it should be back up to snuff in the morning.
May 21, 2010 | Pride Jazzy 1103 Ultra Standard Power...
New batteries does not seem to fully charge. tested the output of the charger with meter and it shows no voltage on the output of the charger, but the two lights flash quickly when plugged in to the wall...
The measurements below are for a 12 volt charger or across one battery at a time. In a 24 volt charger or across both batteries at once, double the values.
The charger will not show any output unless connected to a battery. To test the charger, attach the charger to the battery but do not plug in the charger. Connect a meter to the battery and read the voltage (9.8v - 11.6v).
Now plug in the charger. Read the battery again (13.6 - 14.2v).
The voltage must not be higher than 14.8 on the battery or the battery will over-charge - the charger needs service. If the voltage does not come up to 13.2v, the charger is not running. Again, the charger needs service.
Be patient. You can wait ten minutes and measure again. Batteries respond slowly to the charger.
Apr 02, 2010 | Pride Jazzy 1113 Power Chair
Battery does not appear to be charging. After
Have both batteries checked ,Poss bad batts, load test them ,Also if you have a volt meter (DVOM) Put your positive probe on post of battery and neg probe on neg post of battery then plug in charger and take reading of battery it should go up if charger is good. I bet its your batteries though. Good luck , Erik
Mar 06, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
I have plugged the Soneil battery charger into the MPV4 Hoveround for over 24 hours. Although the indicator shows charging in process, the "battery charge indicator" shows it still requires a substantial...
If your Power Wheel Chair has been sitting idle for a while, the batts may need to be completely replaced. There is a gel inside the batts that need to have a current run through them via the charger on a regualr basis otherwise it will solidify. If the charger lights are onm you have connected the charger correctly for over 24 hours and the batteries are still not showing they have been charge, there may be damaged cells which means both batteries need to be totally replaced.
Nov 01, 2009 | NRS Hoveround MPV 5 - Used Power...
Charging a MPV4 hoveround chair
The battery charging connector, which may appear as the female connector of a stage-quality microphone, is underneith the Joystick control arm. An external charger should have been provided by the seller, so if you don;t have one, you'llhave to contact the chir manufacturer.
Nov 09, 2008 | Electric Jazzy 1115 Power Wheelchair
Electric Mobility Power Electric Scooter Power Wheel Chair Safety Flag Logo
195 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
