Question about Kitchen Ranges
How do I remove the top to my Simpson Riviera electric stove in order to clean it?
The model in question has a grill between the oven and the cooktop.
ngfam1
  • 639 Answers
SOURCE: I have an electric Maytag,digital
Hi Mearill,
Happy to help you!
At this site you may download a manual !
http://www.maytag.com/support/manuals_literature.jsp
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Posted on Aug 25, 2008
SOURCE: thermador range electric model ref 30
in pre heating the oven it does not go beyond 250 degrees. what could be the problem. I have a thermador 30 inch dual-fuel range (rdf30).
Posted on Feb 09, 2009
SOURCE: gas stove /electric starter won't click to start cleaned stove
Try cleaning the starter with rubbing alcohol and toothbrush. There might be soap or boiled over residue on the starter. If that doesn't work, try using fine 150 grit sandpaper and gentle clean the starter with it. This problems drove me nuts too. Good luck!
Posted on Mar 21, 2009
housejess
  • 317 Answers
SOURCE: I need to remove the top of my electric hotpoint
open oven door....pop the front up....
Posted on Nov 11, 2009
SOURCE: I need to replace the glass cooktop on my Maytag electric stove
  1. Open oven door and remove two screws that secure top.
  2. Lift up front and slide forward about 8 inches so that you can disconnect two wire couplings.
  3. Place on table upside down(I put newspaper down to catch the broken shards of glass) and remove burner unit (1piece, 4 screws).
  4. Place old burners on new stovetop in the same position as original.
  5. Remove 4 white plastic shims (round) from old stovetop and put on new stovetop.
  6. Tighten all screws and then sit it back on stove (two front tabs fit into slots) and then insert screws into holes and tighten.
  7. Took about 20 minutes, including vacuuming broken glass from inside burners and cleaning grease form crevices between burners and old stovetop.
  8. Wrap old stovetop in the newspapers that are underneath it and place it all in a plastic garbage bag to avoid any broken glass from falling out.
Posted on Jan 26, 2010
How to replace light bulb in microwave model MMV5208WW-1
The support page with free manuals is here.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MMV5208WW1&siteCd=WHRCOM&userType=Consumer
The owner's manual says:
Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove two screws on the vent
grille, tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws.
Cooktop light: The cooktop light bulb is located on the
underside of the microwave oven, and is replaceable. Remove
bulb cover screw, and open the bulb cover. Replace bulb,
close bulb cover, and secure with screw.
To remove the grille, see my video at microwavecontrol.com.
Sep 28, 2016 | In Microwave Ovens
How to remove the stove top on frigidaire stove model FFGS3025PS
IF you open the door to the stove, you will see screws under the lip of the cook top, take those out, check the back of the stove for screws and then lift the cook to. On some models you may have to remove the sides of the stove too.
Mar 13, 2016 | Frigidaire Stove/Oven/Range Cooktop -...
How to turn oven on on a Kelvinator Cookarama Oven (Older model)?
You need to hold /push the oven control knob in quite firmly while you press the igniter. When it lights up keep holding for about ten seconds then gently release it.
Jun 02, 2014 | Kelvinator Refrigerators
Oven, clock, timers all work, but grill & cooktop do not function Jenn Air Model SVE87600
Check the back and make sure the wiring to the grill cooktop is not unplugged from the main oven.
Nov 04, 2013 | Ovens
Vent fan does not turn on at all
If your cooktop lights recently blew, or if the relay that controls the vent fan is affected, you may need circuit board repair.
Otherwise, it may be a bad fan motor.
There should be a technical sheet hidden behind the grille or behinds the controls. It's very handy to locate and test components.
You can find a video here that shows you how to remove the grille & controller in about 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Apr 14, 2013 | GE Spacemaker JVM1540 Microwave Oven
The burner in question is the center back the indicator light stays on even in off mode
u may have a bad switch.. if the light stays on while all burners are off.. u will have to check each switch one by one to get the right one..
Dec 12, 2012 | DCS Professional RDU486GLL 48" Pro-Style...
What are the dimensions of a Simpson 2001 wall oven
4 burners. 540mm wide x 600mm. Oven is 1040mm high at rear and 890mm at front. Good condition. Only selling because I am upgrading.
Just to confirm is youre stove a Simpson Riviera ?
I hope this helps
Feb 20, 2012 | Ovens
DCS Grill
check the temp probe inside the oven looks like a little rod. to check it you will need to get to the back of the oven
Nov 10, 2011 | DCS RDT-485GD-N Kitchen Range
I have a Simpson electric oven with stove top elements, and one of the burners will only cook at the highest level, I cant figure out how to change it, any suggestions?
You need to change the "Simmerstat", take the model number to your local electrical parts supplier/parts counter at your local stove retail shop that sells Simpson stoves and ask for one for that model, make sure you get the right one for the position as some control a single element and some control dual elements.
*** TURN OFF THE WALL SWITCH AND ENSURE NO POWER IS APPLIED TO THE STOVE BEFORE PROCEEDING ****
Remove the upper back panel of the stove. Swap wire for wire of the old simmerstat to the new one, remove the knob from the old Simmerstat, undo the nut securing the simmerstat in the oven control panel and discard, fit new one, secure, fit knob, fit back panel, turn on wall switch and test.
Some countrys/states require registered electricians perform this task on electrical appliances so you must ensure you can do this legally before you start and take the relevant safety precautions and don't electrocute yourself.
Apr 13, 2011 | Ovens
Hi I have just moved property and I now have a tricity bendix oven that I can't get to work I have used the grill but can't use the oven
Its most probably the clock that needs resetting,by pressing the 2 rhs buttons depending on the model.Try this and hopefully the oven will work again as long as the cooker has been connected correctly.
Hope this has helped.
Jun 25, 2010 | Tricity Bendix Cooktops
Kitchen Ranges Logo
42 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
