Question about Panasonic SC-HT900 System
My sc-ht744 wont turn on just displays f61 and shuts down
  • Anonymous Mar 27, 2014
    IT IS FLASHING CODE F61
    Novelist:
  • 91 Answers
Sounds like a short in the speaker wire or your polarity is incorrect ,black is negative and red is positive ,just double check theese before next step also the ic501 power module has been known to solve this problem if its not the wire,s because either of theese two failures will cause the error code too pop-up, Honestly this has been a problem with this unit and you are not alone , If the power module in the unit needs to be replaced ,call up customer service at panasonic and maybe your still under waranty where they,ll fix it for free !Thank you and hope I might have been able to help you in some way ,Sincerely Glenn
Posted on Mar 04, 2009
Turn on dvd panasonic sc-ht440 the display see me f61
Hi, F61 is and amp error code. probably needs an output ic. could be a shorted speaker or bad cooling fan. Disconnect all speakers and turn it on. if the fans run and it still displays f61 then odds are very good an amp ic is bad.'''Hope it helped.
Have a nice day..
Feb 24, 2011 | Panasonic SC-HT440 System
Dvd reset
hmmm..that's not too good...would you disconnect all the wires, on back, and try it with no load?
Mar 12, 2008 | Panasonic SC-DT310 System
At power on, displays F61 code and switches off
F61 is an error code.
It will automatically shuts down your unit.
This is very common on your unit.
Try to checked if the fan is working or not.
I have repaired some unit before, this is the caused why f61 appeared.
The symptom is shutting down the unit after a few minute.
If the fan is not working it will shuts off automatically to avoid further damaged to your output I.C. from overheating.
If confirmed that the fan is working then I've suspect that your output I.C./pre-amplifier circuit is faulty.
This is quit technical and need to send to repair shop to isolate the faulty parts.
The output IC of your unit is RSN series and quite expensive.
Pls rate my help.
Thaks for using fixya...
Jan 21, 2011 | Panasonic SC-HT75 System
Player keeps shutting down with display saying f61
POWER SUPPLY OR POWER OUTPUT IC BAD..
NEED CHECK AND REPLACED
May 01, 2010 | Panasonic SC-HT995W System
F61? how do i fix it...................everytime i turn my panasonic sc-ak340 on i get a error code that reads f61 and then my system shuts down by itself..can this be fixed?
I've encountered that kind of problem.
f61 appear on the screen then shuts down the unit.
The very common defect is your fan, output ic (rsn series).
First check the fan if it is in good condition (disassembling the component is quite technical it need a lot of care).
sometimes the fan is full of dirt that's why it will not work properly which the system sense and uttered the unit to switch of avoid further damaged.
If you confirm that the fan is working properly I will suggest you to bring your unit to a qualified technician/service center because replacing the output i.c. is more technical.
Dec 13, 2009 | Panasonic SC-AK340 Shelf System
Getting F61 in Display of Panasonic SC-HT700
I have gotten the f61 error code on my SC-HT700. No idea what the problem is.
Aug 30, 2008 | Panasonic SC-HT700 System
Error Message
The F61 indicates a problem detected in the output amp stage and the unit us shutdown to prevent further damage. If you can supply the model number, I can give you the part required and the approximate cost.
Dan
Jul 15, 2008 | Panasonic Home Theater System System
Sa-ht680 service manual
The F61 indicates protect mode. There is a problem with the output stage of the amplifier section and the unit shuts down to prevent further damage. This unit will require service of the amp section. You can try to contact Panasonic for the service manual.
The output amp pac is an RSN311W64D at a cost of $95 plus shipping.
Dan
Apr 09, 2008 | Panasonic SC-HT930 System
My Panasonic SC-A240 shuts down displaying the error f61.
Several components in the power supply maybe faulty, especially Tranisitor Q5110, Resistor R5114 and Diode D5102 on the power supply board. Check and replace these and also resolder the regulator IC's on the heatsink.
Sep 05, 2007 | Panasonic SC-AK240S Shelf System
Panasonic SC-HT900 System Logo
156 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
