Question about Zanussi Dishwashers
Is there a known overheading problem with Zanussi ZDF4010
Is there a known overheating problem with Zanussi ZDF4010
Zanussi zob550xl built in oven is overheating
it sounds like a temp sensor, or thermostat...both are easy to change.
Apr 20, 2014 | Zanussi ZBF360X Electric Single Oven
Zanussi z9191t washing machine overheating
this is easy and cheap take the plug out and turn the machine round and take the back plate off and there should be a out side stat with 2 or 4 wires going to it ok not the heater which has only 3 wires ok hope i have helped you
Oct 17, 2012 | Zanussi Washing Machines
Overheating z9191t
this is easy and cheap unplug the machine and turn it so you can see the back unscrew the back plate and down on the right there is a out side stat it has 2 or 4 wires going to it not the heater which has 3 wires take to a shop and ask for a new one and all done ok
Oct 17, 2012 | Washing Machines
How to remove the cylinder head on a jeep cherokee 4.7l
There are several configurations of engines; the older overhead valve conventional cam, overhead valve with overhead cam or cams utilizing chain drive, overhead cam engines with staggered chain drive, gear driven overhead cams and the most common belt driven overhead cam engines. Although each engine has its own specifications, developing the skills to remove Autocome cdp pro
Apr 27, 2012 | 2006 Jeep Grand Cherokee
My Zanussi double oven switches off during the cooking period.
If it turns off after it has been on a while, then it could be caused by overheating due to failure of the external cooling fan.
The fan is designed to prevent the oven overheating, and failure of the fan causes a safety thermostat to operate and stops the oven from working.
You need to access the fan to check that it is working.
It is usually located at the top of the oven at the rear, and entails removing the top cover and the back cover possibly depending on the model number.
What you are looking for is a cylindrical type fan about 8" to 12" long, again depending on model.
Hope this helps solve your problem.
If you requies any nore info, please e-mail.
Dec 23, 2010 | Zanussi Ovens
My Zanussi ZBF360X OVEN IS OVERHEATING WHERE CAN I GET A WIRING DIAGRAM
You will have difficulty in obtaining a wiring diadram, as they are normally only available to their own engineers.
However, from what you say about your oven, I would say that you probably have a faulty thermostat, as this is about the only thing that makes it overheat. If you can hold of an oven thermometer and establish how much it is overheating by, you may be able to compensate for this by turning down the temperature setting.
Hope this is of some assistance to you.
Dec 02, 2009 | Zanussi ZBF360X Electric Single Oven
Zanussi TCE 7276 W Condensing Dryer
hi i have a problem with the zanussi 7276w model all lights are on ready to start but the tumble dryer will not start
Sep 21, 2008 | Zanussi TC7114W Electric Dryer
Smelly Washer
dont't use liquid detergent - this is the cause of the smell. it is a well known problem. use powder in the drawer
May 13, 2007 | Zanussi FS1455W Front Load Washer
Zanussi DE540X
rather difficult to go further remotely. could be temp sensor. another place to look is at the module - have known quite frequently dry joints at the heater output. examine it carefully
Apr 05, 2007 | Zanussi 24 in. DA6153 Free-standing...
Dishwashers Logo
44 people viewed this question
Top Zanussi Dishwashers Experts
paulcarew
Owen Barnes
Gerard Curran
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
