Question about Sony STR-DE825 Receiver
Right front speaker channel has a lower than usual output...
I have a STR-DE825, recently I noticed that the right front speaker was very low when compared to the front left speaker, I have checked the same speaker in left speaker connection and it is a lot louder as it should be. Its on as there is sound coming out of the front right channel but its just lower than the left.
Any ideas on how to solve this?
Note. I have checked all the settings for the front speakers and all appear to be normal.
Many thanks.
  • 31 Answers
Very basically try swapping over the speaker cables, if this doesnt work i suspect you are in need of a new ouput i.c. these can go if the speaker wires are touched together, unless there is a protection circuit.
Posted on Jul 19, 2009
Low sound output from Front Speakers
The out put transisters are probally fried for the front channels,
Nov 27, 2012 | Sony STR-DE695 Digital Audio/Video Control...
No output to speekers Sony STR-DE825
Check that the mute is not on.If a headphone is plugged into the receiver the speakers will be muted.Verify the the output selector is set to the correct source.Here is a simple check.Select a strong FM radio station.Plug in a headphone.If you are receiving an audio thru the headset.Then disconnect the headset and see if the audio is transmitted to the speakers.If you still have no speaker sound check to see if the speakers have fuses which may be blown.I would try another set of speakers to determine if it's the amplifer or the speakers.The amplifer has fuses as well. Wiilbe inside if not at the rear
Oct 21, 2012 | Sony STR-DE825 Receiver
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Jan 10, 2011 | Sony STR-GX800ES Receiver
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
Right channel low volume on Sony STR-685
Here you go buddy:
Sep 20, 2009 | Sony STR-DE685 Receiver
No Right Front Speaker Output
Swap speakers over...check the balance isn't fully to the other channel...swap left/right phono cables over (if thats how your using it) other than that i would say is broke.
Easy way to check speaker cable/speaker... touch a small battery (like used in a remote) across speaker wires, you will hear and see the speaker cone move.
Aug 07, 2009 | Audio Players & Recorders
Quiet front R channel on Sony
Does problem persist when you connect other speaker to front right channel? (i.e. when you connect your FL speaker to FR and vice versa)?
Jul 15, 2009 | Audio Players & Recorders
Right audio channel not working
Most likely it's due to bad solder for the Blue Relays.It can be fixed by re-soldering.
Apr 04, 2008 | Sony STR-DE545 Receiver
Right speaker channel low, both front and and back, even the headphones
There might be a levels adjustment in the setup menu for distance or something, might check that before opening unit up.
Jul 08, 2007 | Sony STR-DE445 Receiver
Sony STR DE485 (Audio Video Reciever)
Your problem must be caused by the right channel (rear, front whatever..)side feeding resistor on the power supply.
May 05, 2007 | Sony STR-DE485 Receiver
Sony STR-DE825 Receiver Logo
357 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
