Question about Harmsco Pool and Spa Cartridge for Filter Cartridges for Betterfilter Single Cartridge Units - Tfc75 - for Tf75
Pool filter making a loud noise
When my filter came on in the morning after a cold night in Tampa it was making a loud noise like screeching sound. It still is working but the noise is terrible.
    Scholar:
  • 34 Answers
The sound you are hearing is most likely rust forming on the inside of the motor. It tends to happen when a pump seal starts to fail. Water travels up the spining shaft from behind the impeller into the motor. The high pitch is a direct result.
Solution. Replace the pump seal, and find a motor repair shop/ Pool pump repair shop to take a look at the motor. Have them check the brushes and bearings. Once clean of rust the motor should be quiet once again.
Posted on Jul 17, 2009
Engine noise accelerating
Does it sound like backfiring or knocking or squealing/screeching or what ?
Aug 11, 2017 | Ford Cars & Trucks
Loud motor
Hi kootchbol
Sounds like you have a faulty bearing that is causing your noise and a leaky seal on the back of the pump between the motor and the pump
Please rate me
Bud
Apr 07, 2013 | Sta Rite Pool & Spa
Loud screeching sound coming from the unit
It sounds like the fan motor needs lubricating. Do you need help with this?
May 05, 2009 | Amcor A12000E Nanomax Portable Air...
Loud screeching noise when spin cycle is on
Good morning! Possibly the noise was due to improper placement of load into the spinner which should be within its capacity load. best regards.
May 02, 2009 | Washing Machines
Mine is a FDB635RFS4 model - issue is loud screeching noise
i recently had the same problem of a loud screeching noise. my unit was installed new in 1999 and has worked well up to this point.
when i disassembled the tub water filter i found the filter was heavily clogged (it is supposed to be self cleaning), and i also found glass shards from a broken wine glass. i further disassembled the plastic housing under the filter ( held in place by three torx drive screws ) which covers the pump impeller and holds the lower spray arm. while i did not find any blockage in the pump area, and no abnormal sound when i turned the impeller by hand, i did find that one of the pump impeller vanes has a small chip which probably makes the impeller unbalanced resulting in more than normal vibration. i cleaned the water filter and reassembled the parts and the original screeching noise is now gone.
Sep 03, 2008 | Frigidaire 24 in. FDB635RF Built-in...
Loud, screeching noise when taking a message
Managed to clear it myself. After making several cell phone calls to my machine last night and unplugging it over and over, etc. I gave up. This morning I again unplugged everything, reset all the settings and called the machine several times. At first I kept getting the "noise", but eventually I was able to call and leave a normal sounding message. Can't really explain what "cured" it! In desparation I did shake the machine and give it a hard slap, but who knows what did it!
Apr 05, 2008 | GE 29875GE Digital Answering Machine
Harmsco Pool and Spa Cartridge for Filter Cartridges for Betterfilter Single Cartridge Units - Tfc75 - for Tf75 Logo
821 people viewed this question
Top Harmsco Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Harmsco Pool and Spa Expert? Answer questions, earn points and help others
