Question about InFocus IN3116 DLP Projector Projector
How to take the cover off infocus projector IN3116
3 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: LP500 Infocus projector images on screen covered
make sure it's on vga and not composite.
Posted on Aug 17, 2009
SOURCE: How do you remove the "Top Cover" off the InFocus
Michael,en la parte de abajo del lado dellente tiene un tornillo que tienes que quitar y tambien tienes que quitar la tapa de la parte de atras,del mismo lado donde esta el lente tienes que levantar la tapa porque tiene seguros,antes de levantar la tapa desconecta el cable que va hacia los botones de menu,source y reser para que te sea mas facil. espero que esto te ayude . Atte.Rivas.
Posted on Apr 28, 2011
In3114 dead pixels
You should change the DMD or the optical engine. DMD abouut $350
Engine about $650 P5X84-2200 OPTICAL ENGINE, IN3116
Nov 28, 2013 | InFocus Corp. Open Box InFocus IN3114 DLP...
Hi, I have a Infocus Projector, Model # LP70, serial # begins with ACAN. The projector only has 951 hours on the bulb. The unit powers on and I get the Infocus startup screen. as soon as I turn on a video...
I think it is the time to remove the cover and check for air filters blocked with dust.
When this happens, air doesn't flow freely through the projector and result in overheating, which leads to automatic shutdown.
Sep 22, 2011 | InFocus LP70+ Multimedia Projector
How do you remove the top cover off on a InFocus LP130
Here is how you dismantle the LP130, I did a screen capture for you can see it:
Mar 14, 2011 | InFocus LP 130 Multimedia Projector
How do I open the lamp cover on the InFocus IN2102EP (to replace the lamp)? Cheers
There is a single screw that you need to remove, which will allow the panel covering the lamp to be removed.
The screw is located on the back grille, opposite corner from the power connector. For a full diagram and instructions download the following PDF:
https://portal.infocus.com/support/Product%20Downloads/InFocus_IN2102%20IN2104%20IN2106_LampReplacement_en.pdf
Mar 04, 2011 | InFocus Replacement Lamp for IN2102 IN2104...
Infocus sp5000 wouldn't turn on. i replaced the bulb & it worked fine yesterday...today it won't turn on again. i screwed the lamp cover back on tight so don't think it is that.
take the lamp cover off.
get a toothpick and push it down where the cover operates the swicth and check that it clicks on and off properly.
check the air filter cover as well
Mar 03, 2011 | InFocus ScreenPlay 5000 Multimedia...
Ordered/installed from Infocus a new bulb unit.
the colorwheel needs to be replaced. the projector won't turn on if the colorwheel motor is not up to speed.
Feb 25, 2010 | InFocus ScreenPlay 4805 Multimedia...
Infocus LP120 Retrying-Power Light Turns Red...
Usually when the lamp is good and you get this message, the ballast is bad. That is the part thatdrives the lamp. Check with Infocus for a repalacement balast.
Dan
Apr 09, 2008 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Infocus LP120 counts down then restarts counting down
this can usually indicate one of several things, a lamp service life issue, an overheating problem, or that the lamp service cover has not been properly secured
Dec 08, 2007 | InFocus LP120 / 1000 Lumens / XGA / DLP...
InFocus IN3116  DLP Projector Projector Logo
148 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
