Question about Electrical Supplies
In Sink Erator leaks half way down
My In Sink Erator Pro 333 leaks where motor attaches to grinder
  • 5,245 Answers
1) Copy following link for troubleshoot and replacement tips.
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
2) Insinkerator usually has 5 year warranty.
If unit is leaking, then replace with new disposal.
Waste King disposals have longer warranty, but local hardware sells Insinkerator/Badger for less.
Posted on Jan 20, 2013
protek480
  • 1723 Answers
SOURCE: water leaking by discharge tube
All you need to do is tighten the two screws on the discharge pipe (right on the side of disposal.) There is a gasket that needs tightening under the pipe fitting.
Posted on Sep 07, 2009
SOURCE: in sink erator leaking at bottom by electrical connection
I don't think it can be fixed by anyone other than the factory. I wanted to find a parts list so I could buy a seal that goes above the motor housing (which is where i think the problem really is) and repair it myself. I wish I had better news but since the leak is small and the motor still works, I'm going to keep a bucket beneath it and periodically empty it as recommended by a previous contributor.
Posted on Jun 03, 2009
handygirl911
  • 65 Answers
SOURCE: In sink erator is leaking from bottom
I had this happen right before my disposal stopped working completely. Mine was leaking from the same place. The one I had was a 2 year Badger. They are easy to replace. If yours still works I would keep using it and just sit a pan down below to catch water. A new Badger 1 year cost $80 at Home Depot. If you get one, do not worry about buying extra gaskets or the black sink strainer thing because the new one will come with everything needed except for the plumbers putty. You will need plumbers putty. Good Luck
Posted on Jul 22, 2009
  • 250 Answers
SOURCE: I have an in-sink-erator model 1-81 which is
The unit's seals have failed. The metal piece covers the box where the cord is wired to the motor, meaning the motor above it is already soaked with nasty water. It's definitely your best value replace the disposer. If you get another insinkerator or one made by insinkerator (whirlpool, kenmore, etc) you can hook up the new one in three easy steps.
Posted on Feb 21, 2010
heatman101
  • 43501 Answers
SOURCE: the in sink erator model
Here is a tip that I wrote about how and where a garbage disposal will leak and what can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
Posted on Jan 03, 2011
Insinkerator badger 1 leaking from the bottom
check to be sure water is not leaking down the side from d/w drain or sink drain if not look inside with flashlight to check for rust if rusted trough time for a new one
Aug 10, 2015 | In-Sink-Erator InSinkErator Badger 1, 1/3...
Motor just hums,grinder wedges are free, no leaks apparent,motor turns free in both directions.
yes there is start capacitor on each motor, connected to start winding.
There are two windings on each motor: start winding and run winding.
Both windings receive power at same time. If the start winding is bad, or capacitor is bad, then motor hums as the run winding receives power but there is not enough torque to get the motor rotating.
If motor is humming instead of rotating, then quickly the motor overheats and looses speed after repair or melts and fails.
The problem with disposal repair is getting the thing apart... finding replacement capacitor, or replacement parts, and then reassembling without a leak.
http://waterheatertimer.org/Color-codewire.html#motor
http://waterheatertimer.org/Color-codewire.html#Motor
Gene
h
Nov 15, 2013 | In-Sink-Erator Garbage Disposals
Leak from area where cord comes out of the in sink erator
Not good seal could be bad are you sure it is not leaking from the top and running down the side.Fill sink all the way then pull plug get a flashlight and examine well.
Apr 17, 2011 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
The in sink erator model # 5-81A is leaking from the reset (red) button underneath. Help???
heatman101
Oct 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water leaking on bottom of disposal by wire connection
Here is a tip that I wrote about how and where a garbage disposal will leak andwhat can be done to fix it.
heatman101
Sep 09, 2010 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
I have an in-sink-erator model 1-81 which is leaking from the power cord attachment area and from a small rectangular metal piece mounted on the bottom of the unit. Replace or repair and is this possible?
Feb 16, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Jul 20, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Dismantle Emerson insink erator
There is a retainer ring that holds the drain and the Insinkerator together. You loosened the drain with the 4 screws. You need to rotate the retainer ring counterclockwise when looking up from the bottom. Maybe 45 degrees and it will come loose. BE CAREFUL IT WILL WANT TO FALL!!
Phil
Dec 03, 2008 | Emerson InSinkErator W-152 Point-Of-Use...
Electrical Supplies Logo
256 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
