How to fix error 1802 on a T43 ibm
After installed TP-Link WN-861-N the computer send the 1802 error code
  • 274 Answers
SOURCE: how to remove IBM t43 start up password
If you know the password, enter the BIOs. At start up you should see that option briefly displayed. It will prompt you for the password. Once its entered, you can do what ever you'd like. There are "three different password groups" on your machine. POP, HDP, and SVP (Power on, Hrd drive, Supervisor). If you don't know "either the HDP or especially the POP", there is nothing you can do except buy an new MB or HD. There is not short cuts. Hopefully you have the passwords and you'll be OK.
Posted on Aug 26, 2007
jemthy
  • 176 Answers
SOURCE: IBM R40 2722 1802 Error Message
check the booting priority maybe the first booting device is set to network that's why
Posted on May 28, 2008
ItWillBoK
  • 108 Answers
SOURCE: Is there a way to master reset the IBM T43 Thinkpad
No it's not possible to do it with just a button or replace it to factory settings.
The T43 Comes with WinXP or OS/2 Warp or Windows 2000 Pro.
If you wanted to reset it you basically would have to format the harddrive.
You can get a older version of WinXP which is still supported by microsoft or either that you can format it and sell it without a operating system.
Or you can add/remove items you installed and remove personal info delete pretty items much within windows itself.
Happy Holidays
Posted on Dec 25, 2008
  • 60 Answers
SOURCE: Trying to upgrade H/D on IBM T43 laptop, get 2010 error on
Error code 2010 is definitely hard drive problem.
Did you get the firmware from the site below?
Link to hardware maintenance manual for reference:
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles_pdf/39t2393.pdf
Here's the fix straight from the maintenance manual:
If in the primary bay the customer is using a non-IBM or non-Lenovo hard disk drive (HDD), or an old generation IBM HDD which is not supported by this system, with the risk in mind, the customer can still use it by pressing ESC. If in the primary drive bay the customer is using a supported IBM/Lenovo HDD with an old firmware, the customer needs to update its firmware to the latest. The latest version is available at http://www.lenovo.com/think/ support
Posted on Apr 07, 2009
bobfreengel
  • 37 Answers
SOURCE: IBM THINKPAD T43. I can find the switch for my ibm thinkpad T43
Are you sure you have a wire card installed? If so, then try this:
  1. Right-click the My Computer icon and select Properties.
  2. Click the Hardware tab and press the Device Manager button. The network card should appear under Network Adapters.
    Note: If the card has a exclamation mark over a yellow background, then this is an indication that the card is experiencing a problem. Go to Driver download step 5.
  1. Verify that the radio is enabled.
    It is possible to disable the transmitter of the wireless card without Device Manager showing any problems.
    Note: Follow the instructions provided to enable wireless card.
    • Most wireless cards will put an icon in the system tray (the line of icons in the lower right corner of your screen). Right click this icon and it may have a menu option to enable/turn on the wireless radio.
    • Some systems come with a Wireless Radio switch to disable the wireless radios. The wireless radio switch is usually located on the front side of the machine. If you are having difficulties with wireless connections, make sure the Wireless Radio switch is set in the On position.
  2. Check for association to an Access Point.
    If you double-click the previously mentioned system tray icon, the configuration utility of the wireless card will appear. This utility will be able to show the status of the wireless card, showing what channel the card is using and what signal strength is being received. It may be difficult to maintain a connection if signal strength is low due to either interference or distance. For example, interference can be caused by 2.4GHz cordless phones, other Access Points in the area, and physical structures such as load bearing walls or metal partitions.
    Note:
    The utility can be used to configure the wireless card settings, but if using Windows XP Zero Configuration or Access Connections, you will need to use those programs to actually configure the wireless card as they will overwrite the setting of the utility.
Posted on Oct 12, 2009
Error 1802
Please download the BIOS Update from Lenovo Support Solution Download of your reference to correct your Error 1802. Heres the link http://www-307.ibm.com/pc/support/site.wss/MIGR-51708.html
Jul 14, 2011 | IBM ThinkPad R40 2723 Notebook
I need ibm think pad t43 sound drivers free downlod
Hi chennupatism,
You can download the Audio Driver for your Computer Model ThinkPad T43 from the below link.
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles/1ya210ww.exe
Please copy and paste the link in the Address bar of a new Internet Explorer window and press the Enter Key to download the Driver. Then, please save the file on the Desktop. After that, please double click on the download file to begin the installation. After installing the Driver, please restart the Computer for the settings to take the effect.
Good Luck!
Please post back if you have any questions or require further assistance.
Thanks for using FixYa.
Nov 09, 2010 | IBM ThinkPad T43 Notebook
1802; error when i start thinpad t40
Sounds like a non-IBM network card is installed. Remove the card and reboot your laptop.
Jun 12, 2009 | IBM ThinkPad T40 2373 Notebook
System will not boot up.
Thinkpads have readable "FRU" (Field Replaceable Unit) numbers storedon various components, and at boot up time, for those internal devices(fortunately excluding drive, memory, etc) if they do not "respondcorrectly" saying they are a valid IBM part, they will give this 1802error.
It could be that the referenced device has failed, and thus seems to be there but not responding; it could need reseating;
The Lenovo site should be able to help you with a service guide to remove the card and see if that works.
there is also a "hack" to change the bios of machine - I think "prior to T43" to delete the 1802 check:
http://www.command-tab.com/2006/02/26/thinkpad-1802-error-fix/
Be aware any "hack" can disable the machine completely!
If it does turn out to be the mini PCI network card, you can tryremoving it and going with USB (did 600s' HAVE usb? I can't remembermine any more) or try to find a "genuine" IBM replacement on eBay orITxchange.com
May 30, 2009 | IBM ThinkPad 600E 2645 Notebook
Mar 13, 2009 | IBM ThinkPad T43 Notebook
Thinkpad T30 Error 1802 from Verizon modem..Now won't boot past error message even without modem plugged in. Help
The 1802 error is ussually caused by an "unsupported" wireless card being installed. check out this site for a fix that has worked for me on a couple Thinkpads (including the one I'm writing this message on) to allow unsopported wifi cards to work.
Mar 12, 2009 | IBM Thinkpad T30 Notebook
IBM ThinkPad T40 2373 PC Notebook error 1802: unauthorized netword card isplugged in my laptop cannot boot because of this probs
This is ussually caused by an unsupported WiFi card being installed. You can correct this problem by using a quick BIOS hack... (If you are getting the 1802 error)
Go to this site for the fix: http://www.command-tab.com/2006/02/26/thinkpad-1802-error-fix/
Jan 26, 2009 | IBM ThinkPad T40 2373 Notebook
This is due to the fact that IBM laptops have a list of accepted devices, and the pci card is not recognised in the list. On IBM - Amilo, Mini PCI card slot is usually at the back of computer. Locate and remove Mini PCI wireless card, you will not have integrated wireless after this.
Other solution is to find the option to disable mini PCI in bios settings.
Here is how mini pci wireless card looks like:
May 28, 2008 | IBM ThinkPad R40 2722 Notebook
1802 PCI error & Resource Allocation Failure
Hi disable the resource allocation to S3 first and then add the Nvidia card . A jumper could do this - for disabling onboard graphics .
May 04, 2008 | IBM eserver xSeries 360 8686
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
