Question about Saws
Where do I get a set of brush for a mastercraft 14'' abrasive chop saw
I own a mastercraft abrasive chop saw and need to replace the brush. I am informed that mastercraft no longer keeps these parts in stock. Where else might I find some parts now.
  • 885 Answers
Your best bet in this situation is to find a tool repair center that has a large supply of brushes on hand and is willing to look for a set that will work in your saw. At my repair center I do get tools like yours that don't have repair parts available. Most brushes come in standard sizes but the caps on the spring have to be compatable with the brush holder to work properly. If you don't know where a repair center is, go online and look for Authorized Service Centers in your area. You can get more specific and look for Dewalt, Ridgid, Makita, Milwaukee, etc., service centers.
Posted on Jan 21, 2013
2 Suggested Answers
lemmingleejn
  • 173 Answers
SOURCE: Mastercraft 14-in. Chop Saw w/ Laser fuse problem
The fuse is more than likely, fine.
Instead, check the carbon brushes.
Once you have dis-assembled the unit, you will see the way the springs hold them in.
If you can't find the brushes, chances are, they've desintagrated into micron thick diamonds.
(Unfortunately, they're worthless diamonds lol)
Hope that helps the problem.
Posted on Jul 24, 2009
Flexible Shaft Adaptor # 2221-MA00009-00 Carbon Brush # 03AT-000046-00 Brush Spring # 02AH-000088-00 For a Mastercraft Maximum Spin Saw Kit Model # 54-8205-8 Cdn Tire...
By robert_lessa on May 09, 2011
Model # 54-8205-8
Cdn Tire doesn't support their own "house" brand with spare parts.
Does anyone know who was contracted by Cdn Tire to make this unit? That could give me an alternate source for spares. Any help would be much appreciated.
Thanks, Bob
------------------------------------------------------------------ Canadian Tire stopped supporting this product in 2008 and have no parts in inventory ( I am not convinced they ever had a stock of parts) The Spin Saw was manufactured in China by Choon Nang Electric. Your best bet is going to a small engine repair shop and ask if they have universal parts which could fit. Best of luck Claude
May 09, 2011 | Garden
Bad arcing were brushs meets armature, installed new brushes and cleaned armature same thing happens
From snor38@gmail.com Hi dkhallquist. When you cleaned the comuntator did you carfully clean the groves as they may have enough trash to make the brushes ride roughly on the comuntator.
May 07, 2011 | Milwaukee 6180-20 14" Chop Saw Abrasive...
Looking for the 8 1/4 blades for the mastercraft chop saw.?
Hello. Mastercraft carries a variety of 8 1/4 replacement blades that are "normally" an in-stock item. The blade is labeled as a circular saw blade, not a chop saw blade.
  • standard 40 tooth Product# 55-6953-6 aprox $25
  • general purpose 24 tooth Product #55-6976-2 aprox $30
There are others that the store can order in, or to pick up on line as well. You may also notice, that the general purpose blade is rated for 8-8 1/4 inch, most of these two sizes have the same size arbour and will both fit on your saw - this gives you a varied selection. Hope this helps.
Feb 23, 2011 | Hand Tools
Hi i have a viperpro 2000 watt chop saw and the brushes have got to the end of there life but i can not find any one who stocks or sells them my local tool shop has told me to throw it away as they do not...
locate brushes with the same wire/spring attachments and that are slightly bigger than your brushes. Carefully reduce their size on abrasive paper laid on a flat surface, often checking for fit. They should slide into the guides freely without any sideways play. Be careful, the carbon abrades very fast and it is easy to rub off one end more than the other, rounding the surface off or having the brush taper, which is not what you want
Jan 25, 2011 | Garden
6180-20 chop saw trips 20 amp on start up all the time Terry
If it trips the breaker as soon as you hit the switch, check the power circuit. Check the power cord for frays or cuts, especially where the cord goes into the saw. Remove/split the handle and check the wires into and out of the switch and to the brushes and field. Lood for burned or melted wires or case parts. Milwaukee is notorious for running lots of small wires in very tight places. Make sure none of them got pinched when the tool was assembled. Watch for this also when you reassemble the saw. Check the brushes, if they're worn or broke they can cause a short on the armature. If these all check out you need to have the armature checked on a growler for shorts.
If the saw runs for a few seconds then trips the breaker I'd check for gear and bearing problems. Cehck for free, smooth movement of the bearings on the armature and blade drive assembly. The blade should turn freely by hand. Feel for undue resistance or a gritty feel in the bearings and gears. If necessary replace any offending parts.
Aug 31, 2010 | Milwaukee 6180-20 14" Chop Saw Abrasive...
Mastercraft Maximum Compound Mitre Saw
built by canadain tire company their customer service number is 1-866-746-7287 they should be able to get u replacement part and or advise who in ur area can
Jan 25, 2010 | Saws
Jun 28, 2009 | Saws
Need mastercraft chop saw 14 " bruches
Take your old brushes to a hardware store. A good store will have a selection of replacement brushes, go through them to find ones that will fit. Brushes can be sanded to size, it's the spring and connector ends that have to be as close as possible.
Apr 28, 2009 | Mastercraft Garden
My wilton chop saw motor appearsto be dead
take it to a electric motor shop and talk to them if they tell you a price way out the cost of new saw verces the amount of new motor.If it is half the cost of new saw or lower I would have the repair shop replace it or buy the motor from them and repair it myself.
Feb 02, 2009 | Wmh Tool Group Wilton 99174 14" Abrasive...
Saws Logo
138 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
