Question about Sharp CD-ES777 Shelf System
Do i have to have an antenna hooked up to play radio
    Top Expert:
  • Sharp Master
  • 43,031 Answers
Reception would likely improve 100%
Posted on Jan 18, 2013
When playing cds in my sony cdxgt500 the sounds come throught the door and rear speakers fine, but not through the subs. everything works as it should while playing the radio.
Hello.... it sounds like you have the remote wire for the amplifier hooked to the solid blue wire behind the radio. You need to hook to the blue/white wire behind the radio. What happens is that the solid blue wire turns on the power antenna when you are listening to the radio and it turns off (lets the antenna down) when you listen to a cd. There should be a blue/white wire that is the amplifier turn on wire that will stay on as long as the head unit is on. Hope this helped!
20 year car audio/video installer
Bay manager
Apr 06, 2011 | Sony CDX-GT500 CD Player
Cant get radio to play stops on station wont pick up antaina hooked up
Check if the antenna male plug is completely plugged into the antenna port of the car stereo.If it is plugged well in the car radio but don't pick stations then your antenna cable is bad.You need to install a new set of antenna,available at any car audio supply.
Jan 30, 2011 | Sony Car Audio & Video
Panasonic CQ-C8303U. Hooked up an amplifier and it works with the radio but when i put in a cd the amp doesn't work. the receiver just plays with normal sound.
Verify your wire connections are correct. Keep in mind that if your amp is hooked up to the radios power antenna wire this is the problem. When you insert a cd the radio is designed to lower the antenna. If your amp is hooked up to the antenna wire the radio is shutting off the amp when you put in a cd Panasonic does this on most of all their units. You may have to hook your amp up to a separate switch to turn the amp off and on or hook it to your ignitions acc wire, if you hook it up to your ignitions acc the amp will stay on as long as your key is on even if you turn off the radio.
Here's a link to download the manual for your radio just copy and paste it in to your web browser and download the PDF file. You will need the reader to view it. If you don't have the reader you can download it for free at www.adobe.com
http://www2.panasonic.com/consumer-electronics/support/Audio/Mobile-Electronics/CD/model.CQ-C8303U
Oct 09, 2010 | Panasonic CQ-C8303U CD Player
I hooked up my Sony cdx m-600, all works fine but radio does not work. at all. Why?
make sure the unit is hooked to the antenna correctly. This unit will not play the radio and will disable the static noise on the radio. So ensure the antenna is properly hooked in. For more info on how to use the deck click here for the manual. got this directly off sony's website for model cdx m-600. So let me know if that it is properly hooked up and we can figure out where to go from there.
Aug 31, 2010 | Sony CDX-M600 CD Changer
Sony xplod am/fm cd model cdx-m610 will play cds but the radio want play. i have tried to reset radio still will not play
Make sure that you have the antenna plugged in and if you have a power antenna make sure that you hook up the solid blue antenna wire behind on the radio harness to the power antenna wire from the car plug.
May 21, 2010 | Sony CDX-M610 CD Player
Wont play radio whats wrong
Hook a piece of wire to the FM antenna input. You should get a strong station. Turn off FM mute. If you still can't get a station you will need reciever serviced.
Nov 22, 2009 | Emerson AV510 System
Only door speakers have sound on the cd mode
the amp requires a 12 volt power constant, and a 12 volt "on" signal. you prolly have the 12 v "on" hooked up to the car stereo's antennae remote, meaning your amp gets power when the radio is on, cuase the radio is sending a signal to the amp (thinking that it is sending a signal to the antennae to raise)
you do have one of those collapsable antennas, right?
Mar 12, 2009 | Clarion VRX745VD Car DVD Player
1992 Honda Civic Radio has only static
if the tape player works fine and no static u most likely have a problem with your ground,check to see if your radio is getting good ground and also check the antenna unscrew the two bolts on top of the car and carefully pull the antenna upwards and check the wire connected to a piece of metal where the screw goes (if good) add another ground to your radio.
Jan 13, 2009 | 1991 Honda Civic
Eclipse CD2000 has no sound from a cd or sirius... radio works
If you have an amplifier hooked up make sure that the correct blue wire on the harness is connected. One of the wires is the remote amp turn-on, the other is for a power antenna. That would be why your radio plays through your speakers, the power antenna wire' when the source is set to radio, sends a 12 volt signal. That would turn on your amp if thats the way that its hooked up.
Nov 16, 2008 | Eclipse CD2000 CD Player
Plays radio not cds
You may have Power antenna and amp remote turn on wires switched. Your system may be looking for turn on signal from radio and only gets it when am or fm is on because power antenna wire is hooked up instead of amp turn on signal.
Jan 18, 2008 | Kenwood Sirius KDC-MP522 CD Player
Sharp CD-ES777 Shelf System Logo
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
