Question about Pioneer Audio Players & Recorders
PDP-RO5E media receiver won't turn on
Power LED (green) and standby LED (red) are lit simultaniously
C-Dog
  • 84 Answers
SOURCE: Can I use media receiver PDP-R04U with PDP-436PU display?
You need the pioneer media cables hooked up to the media receiver to the plasma unit itself. each end has 2 different plugs. one has 2 thumb screws and the other is a squeezable end that clicks into place. They MUST be on before you plug in any power what so ever!!!! And yes, other information is being passed through.
C-Dog
Posted on Feb 10, 2008
  • 41 Answers
SOURCE: pioneer media receiver won t turn on
If the light on the media reciever doesn't come on then the power supply in that needs to be replaced by a service tech. If you disconnect the 2 cables from the media reciever and the panel and then try to turn on the panel it should light with red and green squares for a few seconds but will turn off as it needs the media reciever to be connected.
Posted on Mar 30, 2009
  • 197 Answers
SOURCE: will not power up fully
power supply call pioneer
Posted on Jun 07, 2009
SOURCE: Kenwood vrs-7100 surround sound receiver turns on and shuts off
The audio amplifier IC are fried
Posted on Aug 12, 2009
Bulldog AV
  • 52 Answers
SOURCE: after turning ON the power/standby switch, the
Is the red light flashing at first?
The unit may be going into protect mode. Lets hope it has done the job and the receiver has protected itself from failure.
Protect mode can result from speaker wires touching each other or the Amps2_bing.gif metal case. Check that first.
It can also be caused by unstable ohm loads if too many speakers2_bing.gif are connected to any of the outputs especially zone 2.
If you can remove all speaker wires and turn the unit back on. If it stays on, turn the volume down on the main zone and zone 2 if connected. Then reconnect speaker wires.
Posted on Nov 24, 2009
PDP-4340HD keeps turning off.
Continuous blinks of standby light indicates a fault in the IIC data bus. The main board is likely to be faulty. If you wish to know more Check this link.
Feb 03, 2013 | Pioneer PureVision PDP-4340HD 43 in....
Our 60sdx took an electrical hit, and now, when we turn it on it goes to protection mode. What do we do?
All of this involves some testing:
I would remove back cover and look at the several green LED's on the board and the red one as well.
The red one should be lit and the green ones should light when set is turned on; primitive self check as each green one is tied to a voltage in the set's internal power supply.
Usually when an electrical hit parts at the in to the power supply get taken out.
Got a red led lit on the board?
This like all sets has standby power supply built into it: some sources are active 7/24 even if set is off and they usually take the hit.
Not knowing if you have a voltmeter and or know how to check I would suggest look at the led lights on the board.
Before you rate this information LET ME KNOW WHAT YOU FIND.
Sd Tech
Aug 16, 2011 | Hitachi 60SDX88B 60" Rear Projection...
My pdp r04u media reciver red and green ligth not blinking only stady lit when i hook up my plazma with laptop i get green light blinking no picture just i want to know what happen my pdp-r04u problem
if this is only with the laptop,, you need to replace your hdmi board if its with the cable
and you receive sound and no picture replace the tcon board. if you dont have neither
picture or sound replace the power supply.
for any parts you can order at tvpartsandmanuals. com
Dec 14, 2010 | Pioneer PDP-4350HD 43 in. Plasma...
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Apr 13, 2010 | Samsung HL-S5679W 56" HDTV
PDP 5030 blinking red light on monitor
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 07, 2017 | Pioneer PureVision PDP-5030HD 50 in....
Pioneer media receiver won t turn on
Mar 29, 2009 | Pioneer PureVision PDP-4340HD 43 in....
Pdp r05u receiver
You should return that box to the seller. There are half of dozens senarios which you should not have to go through.
When you are not able to turn of the power of the media box,that is a sure sign of trouble(assuming you have already replace it with the good battery.)
Instead of going into details,you should get your money back,and i DO NOT recommend you to buy a media box from ebay.To me,who would want to sell the media box that works with the plasma TV monitor?That is a video/audio connection board for the tv,without it,the tv is useless.
solutiondoct
Sep 19, 2008 | Pioneer PureVision PDP-4340HD 43 in....
169 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
