Question about Lexmark X 264dn - multifunction Laser Printer
My Lexmark X264dn is creating two yellow streaks on my pages when I scan...is this a photoconductor needing replaced?
  • 5 Answers
SOURCE: Resetting Lexmark E340 after replacing photoconductor kit
Reset Procedure(s) after installing new photoconductor kit
Resetting the Lexmark E340/342 (display type) machines
1) Turn the printer off
2) While still off, press and hold the SELECT and RETURN buttons.
3) Keep both buttons pressed, and turn the printer on. Continue to hold both until either “Performing self test” or “Config menu”
appears on the display.
4) Release the two buttons
5) RESET PC CNT should now show on the display. If it does not, press the left or right menu buttons until it does.
6) Press the SELECT button once. “Resetting PC Cnt Value” should show on the display.
7) When the display shows CONFIG MENU again, turn the printer off.
8) Turn the printer back on. (Do not hold any buttons down this time). The printer is reset.
You can confirm the counter was reset by printing a “menu settings page”.
Posted on Oct 24, 2008
SOURCE: Lexmark E232 photoconductor
Make sure to install the new photoconductor 1st.
1) Power off the printer using the switch in the back.
2) Open the front cover.
3) Press and hold the Continue button (Big silver button with Diamond shape symbol) and power the printer On (turn the switch back to ON).
4) When you see the last light i.e. error light on solid, release the Continue button and close the front cover.
5) When you close the cover you will see all the top 3 lights on solid.
6) Press the cancel button with X symbol for 4 times very slowly till you see toner low light (i.e. second light from top) on solid.
7) Press the continue button and wait until you see the light sequence.
8) Press the cancel button and wait until you see the light sequence.
9) Finally power off the printer using the switch in the back (IMPORTANT= wait 1 minute) and power it back on to exit the configuration mode.
Posted on Feb 09, 2009
MrNutz
  • 9 Answers
SOURCE: my Lexmark E250d will not
Here is how to reset the photoconductor kit counter:
1. Make sure the new kit is installed and the printer is turned ON.
2. Open the front panel.
3. Hold the Cancel button in until the front panel LEDs flash.
4. Close the front panel
Posted on Mar 26, 2009
  • 11 Answers
SOURCE: photoconductor kit
you must reset the error message; find the explanation in the photoconductor kit package
Posted on Sep 29, 2009
  • 72 Answers
SOURCE: Resetting the PhotoConductor Count
Following are the steps that you have to follow:
1. Press and hold Start
2. turn on the printer
- this is service mode -
- by pressing the Start you can print Printer Settings Configuration sheet -
3. press and release Cancel 4 time
4. Press and hold Start while all lights start cycle
5. press and hold Cancel untill all the light cycle
6. turn the printer off to exit the menus
Thanks
Posted on May 06, 2010
Scanner leaving black streaks
There are two possible fixes.
Download the latest firmware update by CLICKING HERE
The following is provided by courtesy of Lexmark:
Problem Vertical lines; Auto document feeder scan anomaly; ADF scanning problem; Scan issue; Scanner issue; Visible line; Streaks show on page; solid line down the page; Top to bottom line; Smudge runs down the page; Opaque line; Broken line; Bar all the way down the page Solution Overview
This article provides the self-diagnostic steps necessary to evaluate top-to-bottom streaks that appear when copying or scanning.
Important! This is seldom a scanner hardware failure.
The main reason for this anomaly is debris or marks on the scanner glass that is used for Auto document feeder (ADF) page scans.
Printed or Scanned Page Illustration
Who should consider this article?
Any user of an MFP or All-In-One printer experiencing the following symptoms:
  • -Vertical lines only when using the Autodocument Feeder (ADF).
  • -Observed with any type of scan job (e-mail, ftp, solutions, fax).
  • -However, normal expected output when the page is scanned from the scanner flatbed.
ADF scan behavior
Think of it this way:
  • -The page is pulled from the ADF.
  • -The moving page slides across an ADF-designated portion of glass.
  • -The image sensor, which is located under the glass, reads and interprets the moving page's contents.
  • -Contamination on this ADF glass is seen by the image sensor for the entire length of the page.
  • -The image processor interprets the image sensor's repeated capture of this contamination as a vertical solid line.
  • -Any ADF scan function now exhibits a vertical line.
Suggested Diagnosis and Fix
Step Action 1 Locate the portion of the glass designated for ADF scans.
HINT: The glass location differs by model. This area is often separate from the scanner flatbed. Please reference User's Guide for more information if you are having a difficult time locating this designated area.
2 Perform a visual inspection for any of the following recurring culprits:
  • -Clear adhesive tape
  • -Glue
  • -Ink pen
  • -Paper
  • -Marker
  • -White out
  • -Staples
  • -Environmental dust or dirt
HINT: Ink marks can be especially hard to see and almost translucent at first sight. However, the image sensor (CCD) registers them as a mark. 3 Use a clean, soft, moistened cloth to thoroughly clean and remove any marks or debris. 4 Inspect the underbelly or underside of the ADF for any marks or debris. 5 Perform another scan to see if cleaning the glass alleviated the issue. 6 Repeat the procedure if a vertical line still appears.
Remember! Printing and scanning from the scanner flatbed work fine.
7 This time, place an intentional mark on a blank sheet of paper and take note of its location. Now place that sheet of paper in the ADF and make a copy.
8 Evaluate the distance of the vertical line to the your mark. 9 Inspect that area of the glass for further debris or marks and clean as necessary.
Other Possibilities
If... Then... Vertical lines appear only when printing... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support. Vertical lines appear when you lay the page on the flatbed... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support. Vertical lines appear on ADF-fed printed copies, but they do not appear on scan-to-network [e-mail, FTP, folder (PC), solutions]... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support.
May 01, 2012 | Lexmark International LEX90T9005 Inkjet...
I have a Lexmark E250DN printer. The photoconductor kit was full of excess toner. It was easy enough to unscrew the holding tank and to clean out the old toner. Everything seems to work fine now except for...
Probably you need to purchase new one - Lexmark E250X22G photoconductor. Every 60000 prints you need to change it or
If it is OPC drum (green roller) damaged.
May 29, 2017 | Lexmark E250dn Laser Printer
What does PC Life Warning mean for a lexmark x264dn printer? Can you please link steps on how to fix this problem? Thank you.
That's mean you need to change photoconductor kit. Usually with HP printers that part is inside the toner so you change it every time you change the toner but not on some Lexmark printers.
Nabeel Jerjis
Feb 01, 2011 | Office Equipment & Supplies
I have a Lexmark E232 laser printer. I have just had a faint unwanted mark on my print-out which repeats itself on each page printed. I found a horizontal streak across the green photoconducter. Can this...
All laserjet printers and laserject function on the same basic principles and unwanted marks, streaks, line etc, which are repeated in a pattern are mostly due to the deterioration of the cartridge parts(photoconductor and PCR roller mainly). The problem can be fixed by correctly identifying the faulty part and replacing it. This saves the cost of buying a new toner. However, sometimes cleaning the visible inside of the printer and cartridge roller greatly helps, which can be easily done using dry lint-free cloth and gently cleaning the photoconductor etc. Good Luck!
Hope it Helps!
CreativeTECH
Nov 26, 2010 | Lexmark E232 Laser Printer
How to reset PC kit e332n
To reset the PC page count, while the printer is on, open front cover then press the cancel button.
NOTE: The photoconductor page count should be reset only when a brand-new photoconductor kit is installed. Resetting the page count without replacing the photoconductor kit could cause the photoconductor to operate beyond its intended life and thus create print quality issues.
Oct 01, 2010 | Lexmark E332n Laser Printer
Lexmark c532n prints smudges on page
The problem could be caused by the photoconductor units. Try to swap the affected photoconductor units (like swap the magenta with black and cyan with yellow). If problem still occurs, then the photoconductors need replacement. I suggest you contact Lexmark Technical Support for assistance. Thanks
Jul 26, 2010 | Lexmark C532n Color Laser Printer
Toner Streaks Printouts - Lexmark Optra SC 1275
Check the fuser for scratches. BE CAREFUL - - - VERY HOT ! ! !
If you need guidance for this, let me know.
Aug 12, 2009 | Office Equipment & Supplies
How do i reset a new photoconductor in lexmark e450dn.
According to Lexmark E450DN service manual;
1. Turn off the printer.
2. Press and hold Checkmark and Right Arrow buttons.
3. Turn on the printer.
4. Release the buttons when 'Performing Self Test' displays.
The message CONFIG MENU displays on top line of operator panel.
5. Scroll down and select 'Reset PC Cnt.'
Sep 25, 2008 | Lexmark Office Equipment & Supplies
Lexmark E238 Laser Printer
Here are the steps to reset the page count on a Lexmark E234, as described here:
  1. Power the printer on and get it to the Ready state.
  2. With the printer on and in the Ready state, open the front cover.
  3. Press and hold the Cancel button until all of the lights begin flashing up and down.
  4. Release the Cancel button and close the door. The photoconductor count should now be reset.
Hope that helps!
-MetaB
Aug 12, 2007 | Lexmark E238 Laser Printer
Lexmark X 264dn - multifunction   Laser Printer Logo
46 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
