Question about PNY VCGGT4302XPB Verto NVIDIA GeForce GT 430 2048MB DDR3 PCIe 2.0 x16 Video Card
Gateway sx2370 ur30p w/ nvidia gt 430 graphics card won't boot up, constant loud beep
When I try to boot it up with the card installed all it does is just sit there and make a loud beep sound that doesn't cease unless I shut it down. Nothing on the screen, nothing coming from the speakers, just a constant loud beep coming from the computer. When I take the card out and the pc is running on only the internal graphics, it will run fine. I am running an amd a8 3870k black edition apu, with 8GB G.Skill Ripjaws RAM, and a 1 terabyte hard drive. I would like my pc to continue using the nvidia graphics card since it is better, so, help?
  • 102 Answers
SOURCE: I'm having a problem with my new graphics card
camocrazy:
-Make sure that the video card is properly seated. and you have installed all the latest drivers and patches of this card from?
http://www.nvidia.com/object/winvista_x86_163.75.html
try to play games now and if the problem still exist then do:
-At this stage I would recommend just to blame the card's software (drivers) uninstall all drivers and software partinent to this video card. Restart the machine and play the game for a while, see if your monitor crashes. If still does crashes then its the OS.
-Simply uninstall the graphics card from the PC and check if the perfomance of games effect your video. If it still does effect then there is a problem with OS.
Finally I would suggest to simply install the card install the latest patches and drivers from the website of the manufacturer and restart your machine if it works then we can blame faulty driver and software.
-Also please check the manufacturers website of any known issues with this particular card with Vista.
Hope that helped!
Posted on Dec 10, 2007
  • 7 Answers
SOURCE: driver file shuts down windows
Need to know what OP system you have ?
Posted on Apr 02, 2008
ZeroCool2u
  • 15 Answers
SOURCE: GeForce 8500 GT installation problrm
Try looking for a message in the BIOS startup screen usually delete or an "F(X)" something button i.e. F1 or F2 That says it will let you chose your boot device. If you can than press that and chose the hard disk option. If it doesnt let you or it doesn't work than theres probably something wrong with your hard drive and I doubt it has much to do with your video card unless the driver caused it. In that case try starting your computer in safe mode by pressing F8 after the BIOS startup and selecting safe mode and then uninstalling the driver from the change/remove applications part of the control panel. Of course if none of that works you could just yell and swear at HP until they help you. :)
good luck
Posted on Jul 04, 2008
BNUTZBCRAZY
  • 130 Answers
SOURCE: I recently bought a PNY GeForce 9800 GT and it
make sure that the heatsink is in contact with the video card. it must have gotten really hot or something for the fan to split, the card may be faulty. i hope this helps you a little
Posted on Jan 15, 2010
SOURCE: Error code 43 "Incompatible display adapter has been disabled"
I have got Dell comp with same n-vidia 8800GT suddenly after installing adobe's update only 1 monitor functions and slowly.
Any reinstaling and updating drivers that i ve tried did not help.
Posted on Dec 06, 2010
Power Light Flashes 5 Times Won't Boot Up
If it uses AMI bios then 5 short beeps means motherboard failure.
  1. Remove RAM memory, Graphics card, other Plug-in cards, and Drive cables from your mainboard.
    Only CPU + Fan + Power cable are installed on the mainboard.
  2. Power on the PC, and listen to the beeps:
    • no beeps => Power supply, CPU, mainboard or BIOS is most likely defective.
    • some beeps => remember the beeps and next step.
  3. Power off the PC, and insert the RAM memory.
  4. Power on the PC, and listen to the beeps:
    • no beeps => RAM incorrectly installed.
    • same beeps as before => RAM is most likely defective.
    • beeps have changed => next step.
  5. Power off the PC, and insert the Graphics card.
  6. Power on the PC:
    • some beeps => Graphics card is most likely defective.
    • blank screen =>Graphics card is most likely defective.
Nov 15, 2015 | Gateway Ne56r15u Pentium Dual core B950...
I HAVE 2 OTHER USERS ON MY COMPUTER AND I FORGOT PASSWORDS TO GET IN. CAN I GET IN FROM MY USER
no --you will be able to get into that users files and folders but not your own as in effect there is a computer in a computer for each user.
Jul 12, 2015 | Gateway SX2370-UR30P Desktop PC with AMD...
1 long beep 2 short beeps
sounds like you've got a dead graphics card
May 16, 2012 | Nvidia Geforce FX5500 5500, (256 MB)...
Can't install drivers for GeForce GT 430. "Graphics Adapter Not Found."
I am assuming that your PC is working alright connected to the onboard graphics port.
Make sure any supplementary power connectors to your video card are in place, and the card is firmly inserted into the PCIE slot.
If you try these two items with no results, you might try installing the card in a known working PC. It could be a problem with the card itself.
Mar 24, 2012 | PNY GeForce GT 430 Video Card Bundle
Nvidia boot agent ?
I would state use the Restoration Disk, and perform a Repair. (Non-Destructive Installation)
This will repair the Nvidia settings for YOUR computer.
But more than likely Acer did not provide a Restoration Disk, and it is my understanding it may be hard to get a hold of. (Acer Support)
This makes me think you have installed a new Nvidia graphics card, since specifications indicate it comes with Integrated Graphics that is Nvidia GeForce 7050.
http://reviews.cnet.com/desktops/acer-aspire-m1641-u1521a/4507-3118_7-33234219.html
{Integrated Graphics is also referred as OnBoard Graphics.
ON the motherBOARD. The graphics chipset (GPU) is soldered to the motherboard, and Not to a removable graphics adapter card,
http://en.wikipedia.org/wiki/GPU
IF SO, the software (Installation disk) is installed FIRST, then the graphics card is physically installed.
IF not you get a driver conflict.
When a device is installed on a computer, (Such as a graphics card), Windows 'breaks it's neck' to find matching suitable drivers.
If THE drivers are not there, Windows will match up one of it's THOUSANDS of generic drivers.
This won't do.
Windows: "Which drivers do I use? These or THESE?"
[Drivers are small pieces of software, that allow the Operating System to 'communicate' with a device ]
Is this what you did? Install the graphics card, THEN use the graphics card's installation disk?
Post back in a Comment.
Regards,
joecoolvette
Feb 12, 2012 | Computers & Internet
Nvidia gt 430 doesnt working
Hello
you have to install the Nvedia driver to work this card properly. You may have got it when you bought the video card. Just insert it inot the ROM drive, and install the driver. It will take more than 40 minutes to complete the installation. OK.
Feb 02, 2012 | Evga Nvidia GeForce GT 430 with 1024MB...
Respected Sir, I installed an nvidia 8400gs graphic card a year ago..........it works fine ....then two weeks ago i dusted up my cpu...........i inserted the graphic card then the computer...
it is because your nvidia card was broken, it makes the windows won't boot up, try to clean up your nvdia card (yellow circuit which will connect to the pci of the mother board) using a pencil eraser
i suggest you to change your nvdia card with a new one
May 14, 2011 | Dell Inspiron 6000 Notebook
I have a Galaxy GT 430 1GB graphics card and I installed into the PCIe x16 slot. But when I boot up my computer, it locks up in POST. I can see that my computer recognizes the graphics card because a...
If you had a graphics card prior to this one make sure all software from previous card is uninstalled. If you installed your card correctly, it should come up normally then, you can run your installation cd. If it is not coming up properly, see if you can start in "safe mode", go to "device manager", click on the box next to "sound , video, and game controllers", then click on your card and in the list make sure you see "disable". If you see "enable" click on that and exit, then restart. You should now be able to run your cd. If you had prior software and didn't uninstall before the install of new software, you may have to start over. After your original install from cd you can get all prior updates from Nvidia
http://www.nvidia.com/Download/index.aspx?lang=en-us
Apr 25, 2011 | Galaxy Technology Galaxy 43GGS8HX3SPZ...
Getting constant beep when i add new pci-e card
Did you plug in the power connector? If so make sure that your power supply is rated correctly.
Mar 18, 2009 | ASUS EN8500GT Silent DDR2, Graphic Card
PNY VCGGT4302XPB Verto NVIDIA GeForce GT 430 2048MB DDR3 PCIe 2.0 x16 Video Card Logo
Top PNY Computers & Internet Experts
David
David
marley mcelhinney
Jim Thurston
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
