Question about Saeco Stratos Coffee Maker, Espresso Machine
Saeco royal proffessional remove brew unit - Saeco Stratos Coffee Maker, Espresso Machine
mirran
  • 515 Answers
SOURCE: Brew unit missing?
Make sure the brew unit fits in place, press the "press" button when you put in the brewunit.
Let me know if it works.
Posted on Aug 06, 2008
EsWorld
  • 1618 Answers
SOURCE: No coffee brewing with beans, but with coffee brewing with ground coffee.
It is possible that the grinds chute is blocked, remove the brew unit and check the chute from the grinder chamber, make sure that it is not blocked with coffee grounds.
Posted on May 31, 2009
  • 1089 Answers
SOURCE: saeco royal digital part 0701.R05.050 broke how
HI
Its called a thumbscrew. You have pulled the nut that was molded into it out. Don't use the key to install the new one. That is why they call it a thumb screw. Finger tight. Should be able to get it from one of the online vendors. http://www.partsguru.com carries it. Wholelattelove. 1st line.com
Posted on Oct 26, 2009
Testimonial: "thanks "
  • 81 Answers
SOURCE: Error Code 4 on Saeco Talea Ring
error code 1 means the grinder is not working, either the motor is bad or there is no power supply to the motor.Have to take it back to the Seaco service center.
Posted on Mar 06, 2010
  • 1089 Answers
SOURCE: how to decalcify saeco royal exclusive coffee machine
Hi
Auto descale: To automatically descale your machine, press the scoop button or menu button if you have one, and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don’t have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Posted on Jun 14, 2010
Machine will not dispense water at all,leaks behind dispenser, doesn't brew coffee
Hi. Great machine. You have a brew unit blockage. Remove the brew unit and clean. It canbe striped down and cleaned, but does requirer a bit of expertise in stripping them. Dazza REPAIRER
Sep 23, 2011 | Saeco Royal Digital Plus Coffee...
Hi, My saeco royal cappuccino is displaying, brew unit block. It has been checked and all is clear. It was suggested that maybe it was the gearbox? Is this possible, if so do you have an exploded view of...
the saeco brew unit is the same as a Miele brew unit from a cva 615. check to see if there are any Miele service centers near you. The brew unit needs to be lubricated with food grade silicone grease every 30 days. if you dont do that, the plastic gears in the gearbox can and will strip. Try to find another brew unit and see if it works with a different one. If not, you may need to send it in to a repair center.
Nov 20, 2010 | Saeco Royal Cappuccino Espresso Machine
My Saeco Royal Cappucino gives hard noise, when "tamping". The grind goes to waste-basket. No coffee..
HI
There is a lever on the top of the door that has a + to the back and a - to the front. Pull the lever back 1 click to the front or - side. Your putting too much coffee in the brew unit and could break the brew drive.
Nov 30, 2009 | Saeco Royal Professional Espresso Machine
Saeco Royal Professional capuccino maker brew unit assembly issue
Try this, check brew unit on it you will see a small arrow, this has to be pointing at the letter N, whisch is near the handle. Remove the drain tray and dreg tray, check the rails for the brew unit make sure there is no coffee on it, then slide unit in place.
May 27, 2009 | Saeco Royal Professional Espresso Machine
Ground coffee Saeco Royal
Hi
thedalys. you probably have a bad micro switch on your doser. and that just needs to be replaced. If the grinder does not sense that the doser box is full it will keep grinding until it times out.
Guest. Try pulling the dosage lever back one click from the full and push your grind lever to the largest # and see if that helps. Sounds like you grinds are too fine and its clogging the the grind box. If the dosage level is too full it will cycle and dump the brew unit or break the brew drive gears, then you will hear a clicking noise when it trys to make a coffee.
Dec 12, 2008 | Saeco Royal Digital Plus Coffee...
Looking for instructions on cleaning and servicing the Saeco Royal
When you clean the brewing unit wash it with hot water, do not
use any solvent.
Make sure there are no coffee residues on the two steel filters: the upper filter can be removed by unloosening and turning the plastic pin anticlockwise using the tool supplied.
Dry thoroughly each central unit component, fit the filter again and tighten it properly with the screw .
To do a descaling:
Saeco descaler is recommended; however, you can use any non-toxic and/or non-harmful descaling product for coffee machines, commonly available in retail stores. The used solution is to be disposed of according to the manufacturer’s
instructions and/or regulations in force in the country of use.
Never use vinegar!
Best regards
/Mirran
Nov 26, 2008 | Saeco Royal Digital Plus Coffee...
Can't remove the brew unit
I ran the machine again using a plastic card to activate the micro switch for the dregs unit and it recycled the brew unit to the correct position so that it could be removed.
Nov 07, 2008 | Saeco Royal Digital Plus Coffee...
No coffee, water going to the drip tray
OK, so this is a problem with your brew unit. The unit is not cycling correctly to tell the water to come through.
We had another problem like this just this week.
The wat we fixed it was 1) Give the Brew Unit a really good clean. 2)Make sure the Brew Unit can complete a cycle - manually rotate the brew unit components through a cycle 3) Lubricate the Brew Units moving parts if necessary using some Saeco or Other Food Grade Lubricant
Then try watch a complete coffee cycle by leaving the side door of your machine open, and tricking the micro switches into thinking the door is closed by engaging them with some card or something similar.
Let us know if this does not resolve your issue.
Paul from Coffee Shrine
Saeco Coffee Machines
Aug 20, 2008 | Saeco Royal Professional Espresso Machine
Saeco Royal Professional Coffee ends up in the bin not into the cups. What has happened and where can I go to resolve it. Thanks Mala
If you mean the Coffee Seems to end up all around your brew unit, a common fix is to move the dosage control (this is the slide on the right hand side of your machine just above the door to the brew unit) back and forth repetitivly.
Try this
Paul
Aug 18, 2008 | Saeco Royal Professional Espresso Machine
Saeco Stratos Coffee Maker, Espresso Machine Logo
12 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
