Question about Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven
Quit heating both ovens quit heating
  • Official Brand Answer
  • 4,342 Answers
Hi getalifemom - From what you have described it sounds like the unit has faulty element(s) or could possibly be experiencing a wiring issue with the EOC. Try resetting the oven by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues and properly diagnosis the unit.
Posted on Jan 22, 2013
Oven won't heat
"heating and broil elements check ok?"...by using ohmmeter I assume? next step: unplug oven or remove power source; remove back cover of oven and ohm the thermocouple (unplugged) while heating/cooling it. Resistance readings should change quite a bit. If this checks out, your control board inside the panel is fried.A new one will cost $200-$300. If oven is more than 10 years old, I doubt if you'll find one.
Mar 05, 2014 | Whirlpool RBS305PD Electric Single Oven
Oven quit
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Sep 25, 2010 | KitchenAid KEBC107 Electric Single Oven
Oven quits heating
check that the tube feeding the air pressure switch is not bloked by unpluging from where the tube joins the with the switch and **** the tube hard. DO NOT SWALLOW.
Then put back and try again.
if doese not work please give more clarificaton on what hapens
Jun 15, 2010 | Lincoln Conveyor Oven - 1132-080-A
My oven does not bake any more
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jun 01, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Oven sometimes doesn't heat up. Sometimes heats up to desired temp, then quits working. Sometimes doesn't even heat up at all. When preheated light comes on, thermometer in oven usually says about 100...
This sounds like a weak igniter, it would have to be a gas oven and the symtoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 14, 2010 | Amana Ovens
Oven won't heat
The only reason I know the answer to your question is because I am having the same problem. Our appliance quit working after we used the cleaning option. Both the bake and broiler quit at the same time. Our local repair man said that the problem is caused from a malfunctioning thermostat, which is about a $300 fix.
May 18, 2009 | Whirlpool RBS245PD Electric Single Oven
Noisy oven
Make certain that the heating element is properly seated WHEN THE OVEN IS COLD! When you put "current" through wires and heating elements, they vibrate. Zip tie the wires together outside the oven cavity.
Apr 25, 2009 | DeLonghi Ovens
Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven Logo
55 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
