If the Netbook as been online before I would check to see if there is Malware. It sound like that might be your issue.
SOURCE: Qosmio g15 recovery disk error
If the discs are clean and pretty much scratch free, then this is most likely a bad hard drive. If you have another PC or laptop, try burning copies of the recovery cds and then use those. If the problem remains, you will need a new hard drive.
SOURCE: Trying to reset
Hi, it seems that the recovery partition is not working.You may have to get the Recovery CD's to do the Factory Recovery.If you have not created the Recovery CD's from the Recovery manager software, you can purchase it from the Acer website.
The Alternate method for starting the Recovery on startup is using the combination of ALT+F10 ( some models its ALTgr ) on startup.Press and Hold down the ALT( Left jand of space ) and at the same time keep on tapping the F10 key till you get the message " Windows is loading files".Just follow the On screen Instructions to start the Recovery.
SOURCE: sylvania netbook cannot find server or DNS Error
Hi PROBLEM FIXED!!!
I had the same problem but fixed it! its simple, go to network and dial up connections in control panel and change your internet adapter card to obtain ip address via dhcp. to do this just double click on it or right click and change the properties. if you are not sure which one is your wifi adapter just do it to all of them till it works. also make sure u have set up yr encryption properly.
SOURCE: When i use youtube on
You are restricted to using the "YOU TUBE" icon on the desk top as that will connect to a server that can handle the restricted CE displays. If you try and go around that and ask for http://www.youtube.com it will give you an error code. Many sites cannot recognize the CE format as that is somewhat restricted to "Smart Phone Usage" in the past.
Try these product numbers:
FM9FY - TMF7Q - KCKCT - V9T29 - TBBBG
HCFPT - K86VV - DCKH3 - 87CCR - FM6HW
You will be done INSHALLAH.
