Question about Speed Queen Washing Machines
How do I replace a lid switch for model # awm392w
    Problem Solver:
  • 13 Answers
I own 20 speed queen top loaders that the same machine as yours.
they are 19years old and have never had a lid switch go out.
the problem is the arm that activates the switch gets bent and can activate the switch. to fix take the 2 screws out of the left side of the lid hinge then tilt the lid to the side and slide the right side out. this is the arm that activates the switch . looking at the top of the lid bend the arm up just a small amount. them put it back on the machine and try it you may have to bend a little more to make it work.
Posted on Jan 24, 2013
Washer will not spin r drain model whirlpool la7680xmwo
Sounds most likely a broken/defective lid switch. The lid switch on a top-load washer is a safety switch that detects whether the top-load washer lid is closed. The lid must be closed when the basket spins; some top-load models require that the washer lid be closed before the washer drive motor runs (thus no draining). If the lid switch isn't properly detecting whether the lid is closed replace the switch.
Dec 24, 2016 | Whirlpool Washing Machines
My kenmore 90 series washer will not drain i have tried playing with the lid leaver any thing else i can do ,can i replace the leaver switch?
Yes you can replace the lid switch its fairly easy to do...this tip i wrote will help ya to replace the lid switch http://www.fixya.com/support/r9939128-whirlpool_kenmore_estate_kitchen_aid
Series 90 is unfortunitly not a model number please reply with exact model number as found on a label on the rim of the tub inside of the lid and i will give you the part number for the lid switch.
GENE
Sep 12, 2011 | Kenmore 24032\24036 Top Load Washer
Model #AWM392W when water is filling tub, water is coming out from around the bottom
the outer tub seal is bad,you need to remove the inner tub then outer tub to replace this seal
Aug 07, 2011 | Speed Queen AWS52NW Top Load Washer
Wont agitate or drain water to spin
Check to see if your lid switch is working. On most models the lid switch will prevent the washer from spinning with lid open. Some models will stop once the washer fills with water. Depending on what brand you have depends on where the lid switch is. If you need assistance finding the lid switch or replacing it please respond back. Thank you
Aug 02, 2011 | Washing Machines
I cannot open console to replace Lid Switch
You can watch the video on replacing the lid switch at www.appliancehelponline.com/servicemanual.html.
Also there are diagrams just enter your model # but the video will show you exactly how to do this.
Mar 25, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore washer lid switch problem
Good day,
Common problem, Change the switch, and make sure if it is the model with a plunger for the switch mounted on the lid, that that be replaced as well.
Thank you for using FixYa
Dec 29, 2009 | Washing Machines
Washer goes through wash cycle and stops
Check your lid switch. If the washer fills and agitates, but stops at the rinse cycle, this is a common symptom of a lid switch malfunction. The following link explains how to access and/or replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If the switch is not activated by a lid strike, it will activated by a hinge actuator located next to either the left or right lid hinge. You will need to remove the operator console in order to access this type of switch.
NOTE: On this type of lid switch the lid hinge has a small rod that is used as an acutator to toggle the switch. In many cases, you can adjust the rod by bending it if the switch is not making contact.
If you determine the switch to be defective, a replacement can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. All these sites offer competitive pricing, so shop all of them for the best price.
If the model number you have this listed under is correct, the part number for your lid switch is 8054980. The lid switch on this model is located under the washer casing along the right lid hinge. This is a very simple repair, that usually costs about $25 to $35 to repair yourself. If you have questions, or require additional assistance, please let me know. Post back with a correct model number if the model number is not correct. I hope this helps you. NOTE: The timer costs about $130. I would recommend checking the lid switch first.
Sep 30, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Need to replace lid switch in a kenmore washer
Hi, The easiest way to replace the lid switch (if this is the reight model) is to remove the two screws holding the lid switch and pull the lid switch out so that you can splice the wires to the new switch. If you want to replace switch with the harness complete, here is how to remove the cabinet
Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Now the cabinet will lift off the frame and you can set it aside. Now you will be able to get to the switch and replace it.
Plase let me know if I can assist you further.
Vic
Jun 20, 2009 | Washing Machines
My Kenmore 80 series washer won't agitate but it will spin. I have replaced a coupler before, but this problem seems different. Any help?
This problem is commonly attributed to a lid switch malfunction. If the model number you have this listed under is correct, the lid switch is mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If your washer is not configured in this manner, please post back with your COMPLETE model number (located along the tub rim under the lid) so I can confirm how your washer IS configured.
A replacement lid switch can be purchased on line at searspartsdirect.com, repairclinic.com or appliancepartspros.com. All three sites offer competitive pricing, so shop all three for the best price. For instructions on how to replace a lid switch, you can refer to my profile and look under my "Tips and Tricks" for links for Replacing a Lid Switch. If you still need assistance, please contact me and let me know.
Feb 17, 2009 | Kenmore 24032\24036 Top Load Washer
Replacing lid switch
me too...exact same washer and same problem...how do u fix it?
Apr 20, 2008 | Washing Machines
Washing Machines Logo
57 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
