Question about Jenn-Air JDS9865BDP Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range
Need Jenn-Air Y704752 switch
Automatic oven cleaning kills this switch. Very difficult to find. Can you help?
SOURCE: Jenn-Air Model W130W-C Wall oven...
Yo timer eez broked dood
Posted on Jan 28, 2009
SOURCE: Jenn Air auto clean oven
once cleaning is completed and completely cooled down. Turn both knobs off. turn both knobs back to clean and hit cancell button twice. should un-lock then
Posted on Apr 13, 2009
SOURCE: Jenn Air oven door won't open after clean cycle
Had this EXACT same problem the day before a party where I needed the oven for lots of baking.... Tried all sorts of things, was about to call a repair man- I FINALLY got it to open by following the first two directions for putting it into self clean mode (turned both knobs to CLEAN), then when it said to lock door I tried to move the lock lever and bam it worked! Give it a shot! Good luck! (:
Posted on Jun 13, 2009
sclarke7
  • 222 Answers
SOURCE: How to turn off self clean oven Jenn air slide in
the self clean cycle will run for 2-3 hrs and the door will remain locked for another couple hrs while cooling let it finish and wait till the next day basically if it still wont open (sorta common) the door lock assy needs replacing.
Posted on Oct 08, 2009
SOURCE: Jenn-Air S136 Grill-Range--auto clean not working
Selector to Clean
Temperature to Clean
Move lock lever to the right
Press the enter button Twice
Posted on Nov 27, 2009
Old Jenn air oven. Ran self clean over 30 hours ago. Door wiil not unlock. Have tried opening with knobs on clean. Have resat breakers. Have restarted cleaning cycly. Will not unlock.
It sounds like the temperature sensor has failed in the locked position. I am not familiar with Jenn Air Ovens, but my best guess is you have to remove the back cover to access the sensor and replace it and then reset the oven. This could be a very time consuming and difficult process. If you are not typically a DIYer, I would suggest having someone else look at it and determine if it is repairable and is it worth the expense involved.
Nov 24, 2014 | Kitchen Ranges
My Jenn Air oven is asking me to remove the meat probe. The only thing I did before it asked me to do that was to turn it try to preheat the oven to 350 degrees
you could have a bad probe receptacle. Or a board problem. Kill power to oven, wait 10 min, cross your fingers and restore power.
Oct 26, 2009 | Jenn-Air Ovens
Jenn-Air JDS8850BDS control panel malfunction
You need a new control board. I bought similar range in 2004 and I just got my 3rd control board. Heating the oven over 400 degrees and using the self-clean function kills the board.
Aug 11, 2009 | Kitchen Ranges
Looking for replacement switch
You would have to send me the old switch so that I can locate one
Apr 16, 2009 | Jenn-Air JDS9865BDP Stainless Steel Dual...
Jenn-Air JMC7000 Microwave Stopped working
take the trim off of the microwave and on the top of the oven on the right side all the way in the back there should be a reset button just like a surge protector.
Dec 01, 2008 | Ovens
You need the repair man; not a diy project. Please contact me if you need further help and leave feedback. Thanks for letting me help you!
Nov 30, 2008 | Jenn-Air JGR8775QD Gas Kitchen Range
Need help unlock oven after self cleaning jenn air jjw9527
The temperature setting must be set on "Cleaning" and the oven cooking dial to "Clean"; otherwise the door will not open and forcing will damage the mechanism. Also, before the door will open, the internal temperature must drop to a safe level and a red "cleaning" light must go off, after the temperature drops inside the oven.
Aug 23, 2008 | Jenn-Air Ovens
Jenn air 88370
I have a similar Jenn Air oven approximate date 1982. It has a catalytic liner (colored a kind of dark charcoal  with paler flecks), so it is a continuous clean oven during normal cooking.  However, it also has the Accel Clean setting on the control knob. This increases the oven temperature to maximum and also runs the convection fan to burn off cooking residues. This allows the catalytic lining work at high efficiency, and burn off stubborn residues that are not removed at normal cooking temperature. The oven may emit smoke through the top door vents as the food residues burn off, so watch that you do not set off your smoke detector. I switch on the cooker hood fan and also put a fan in the kitchen window (blowing air out of the kitchen), to avoid setting off my kitchen smoke detector if I use Accel Clean.
Jul 28, 2008 | Kitchen Ranges
Clock assembly
my automatic cleaning setting in my oven will not heat up. I set "clean" on both dials and put the lock on, the fan comes on but no heat. Is there a certain system to turning it all on and the timer so it will work?
Mar 21, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Selfcleaning Jenn-Air electric oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Dec 05, 2007 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air JDS9865BDP Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range Logo
91 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
