Question about ASUS X52F-XR2 15.6" Notebook - Core i5 2.53 GHz
Mouse pad sensitivity creates difficulty in typing, such as jumping to other spots, erasing typed messages, etc.
    Sergeant:
  • 378 Answers
Disable mouse and use external mouse or adjust sensitivity
Posted on Jan 25, 2013
Why is my mouse pad on the keyboard overly sensitive? Curser jumps around while typing
Try to remove the mouse pad driver and reinstall it. then goto control panel, click mouse pad setting. Here you can adjust everything including sensitivity.
Aug 11, 2014 | HP Computers & Internet
I have a Compaq Presario CQ62. When typing anywhere, the cursor randomly jumps to another spot in the text and continue inserting text there. How do I correct this?
This typically happens when the typist's palms touch the touchpad, which the pad treats as a mouse click. See if the cursor is jumping to where the pointer is.
Most touchpads have a control panel (usually part of the MOUSE Control Panel) where you can reduce the sensitivity (or disable) the left click function from tapping the touchpad.
Apr 20, 2011 | HEWLETT-PACKARD Compaq Presario CQ62210US...
I have a Dell Inspiron 1545 which has three problems, the battery discharges faster than when used by another computer of the same make, the screen lighting often blinks severally before it completely goes...
http://download.cnet.com/ccleaner/
run crude cleaner to get the flicker and speed the laptop up
get a new battery... if discharges too fast.. like less than 45 minutes
cursor jumping around.. watch your touchpad..
commonly you are touching the mouse pad during some keystrokes
you can set the mouse pad sensitivity downward under control panel--> mouse---> synaptics mouse pad sensitivity also
Jan 21, 2011 | Computers & Internet
My cursor keeps jumping when I type on my notebook. I don't even have to touch the touch pad for this to happen...how can this be fixed?
Check the Mouse sensitivity
Click START - Click Control panel - Open MOUSE
Check the Sensitivity and adjust accordingly.
Jun 29, 2010 | Medion md40298 Notebook
Add Toshiba Netbook for major cursor jumping making very difficult to use word processor. Oddly seems okay with Free Cell. Goes bonkers if word processing. I will try some of the solutions listed above...
It may sound kind of ridiculous but if you place a post it note over the mouse pad the cursor no longer jumps around. it may not always be convenient but for lengthy typing it really helps and easy to remove, etc.
Dec 17, 2009 | Computers & Internet
When typing an email the keys skip back to the
When I have seen this happen, the touch pad was set overly sensitive. When you are typing, your palm may be moving the cursor. If this happens at other times, then this can be corrected in the control panel. Go there and click on touch pad. It will have settings to set the sensitivity for the mouse pad, speed, double click/single, etc. You can change the settings to be more suited to your hands.
FYI: Older laptops were more susceptible to touchpad errors and I have even seen the area on either side of the touchpad to cause the mouse cursor to move and jump.
Good Luck
Dec 16, 2009 | Toshiba Computers & Internet
Cursor jumping around when typing on a Dell 1530
It is most likely the touch pad...a way you can tell is if you have a USB mouse, turn off the touch pad and use the USB mouse...go to type and see if it still jumps around.
Sep 16, 2009 | Dell XPS M1530 Laptop
Cursor jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
  1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
  2. Adjust the sensitivity of the touch pad:.
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
  3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
Aug 14, 2008 | Computers & Internet
Moving cursor.
well there is a few things that could possibly be happening. if it is a touch pad or a wireless mouse something like a cell phone sitting close enough to them could be causing some interference. the second one is that you could possibly have the mouse keys turned on where you can control the mouse with the keyboard.
Apr 29, 2008 | Dell Latitude D800 Notebook
ASUS X52F-XR2 15.6" Notebook - Core i5 2.53 GHz Logo
26 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
