Question about Frigidaire GLTF1670A Front Load Washer
Not spining it seems to agitate but dosent spin on spin cycle please help! they just fix the motor not to long ago
  • 188 Answers
It could be the motor they installed (either incorrectly installed or defective).
It could be the SCU/ MCU (speed control unit/ motor control unit).
It could be the door lock mechanism (if it does not sense that it's not locked you will not get high speed spin).
It could be a wiring issue (loose or corroded connections).
It could also be an unbalanced load (this can be verified by trying a spin cycle with the machine empty).
Hopefully whoever "they" are they have a guarantee if the work was done not too long ago. Get them back in there.
Hope that helps!
Posted on Feb 19, 2009
During wash cycle it is only spinning one way
I hope you are referring to the agitator.
On washing machines, the drum only spins one way.
The agitator in the middle of the drum will spin both ways.
If your agitator only spins one way, something is broken.
Please share the year (?), make and model of the machine.
God bless your efforts.
Apr 12, 2016 | Washing Machines
Washer not agitating,spining,motor turns but will not turn belt,the belt gets hot an melts.Replaced belt,lid switch works ok, I can manually turn agitator in clock wise direction but not counter clock...
Need model number! Do a google search for a manual (just search by model number). Repair parts and some troubleshooting help at: http://www.repairclinic.com/
Jan 16, 2014 | Washing Machines
Help! I replaced the clutch and motor coupling a month ago. Ran great till this week. The wife washed tennis shoes, it quit agitating and spinning-i could hear the motor running fine. I again replaced the...
Have you checked for any damage on the lid switch at all? Washers won't engage the cycle you're having issues with if the lid switch is faulty. usually a magnet or plastic piece that pushes down the piece to engage agitation.
Sep 21, 2017 | Kenmore 22622 Top Load Washer
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Please help! Problem: no agitate, no spin.
The motor coupler is the likley problem. You can download theapplianceman1949's $9.95 videos to tell you how.
Jun 12, 2010 | Roper RAX7244KQ Top Load Washer
Washer won't agitate for wash or spine for spin cycle, only 5yrs old
Hello Friend, Your solution is very simple. You need to replace the motor coupler. It's easy to replace the motor coupler on your machine. First, remove the two screws that hold control panel in place and tilt back exposing the two metal clips that hold the cabinet in place. You will see some wires plugged into the cabinet, just unplug them. There are two clips, one on each side. Just pop these clips off and lift cabinet slightly from back and tilt forward. At this point you will be able to completely remove the cabinet. Once you have cabinet removed just set it aside. Now, just lay the washer on it's back. At this point you will see the water pump, motor, and transmission. Remove the pump by snapping off the two spring clips. The pump will slide right off the motor shaft. Now, remove the two screws that hold the two spring clips attached to motor. Unplug all the wires etc. and then snap the metal clips off motor. Lift motor straight up, it should slide right off. Now you will see the motor coupler. Half of the coupler is on the transmission shaft and the other half is on the motor shaft. There is a rubber center connector ring that connects the two together. Just remove the old coupler pieces by prying under them with slotted screwdriver and replace with new ones. Re-assymble the washer and the problem you are encountering should be solved. Happy to help, Tim.
Nov 06, 2008 | Hotpoint Aquarius WD63 Front Load...
Kenmore washer won't spin
This should help you get to the coupler between the motor and the trans.
Good Luck
Oct 11, 2008 | Kenmore 24032\24036 Top Load Washer
Same whirlpool ultimate care 2 gripe.
sounds like the run winding is out on the motor BTW the whole cabniet comes off the unit so you dont need to put it up on jack stands
May 22, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Frigidaire GLTF1670A Front Load Washer Logo
85 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
