Question about Lexerd Kenwood KVT-739DVD 719DVD TrueVue Anti-glare In-Dash Screen Protector Dual Pack Bundle
Disconnected cable found please confirm a connection line
Hp laserjet 3050 has comp error 413, cannot receive fax
During a V.34 transmission, the local machine is unable to connect (handshake) with the remote machine and is consequently unable to send a T30 frame. This occurs when the line is disconnected or if line conditions degrade during the session.
Solutions
  • Remove any pass-through devices from the phone line, and then try the fax again.
  • Confirm that the fax/phone cable is no longer than required, and that it does not pass near unshielded electric motors such as fans, heaters, or household appliances.
  • Try to send the fax at a different time when telephone line conditions have improved.
Also, here is a link for every error code your fax machine could ever display:http://h10025.www1.hp.com/ewfrf/wc/document?cc=uk&dlc=en&docname=buu02549&lc=en#Error396
I hope this helps and thanks for using Fixya! ** If you found this helpful, please leave a great rating so others may benefit from this answer too! **
Sep 23, 2011 | HP LaserJet 3050 All-In-One Printer
Error message
Hi the wiring is not fit to your unit! please check one by one to see its fit
Thanks!
Jul 19, 2008 | Kenwood KVT-817DVD DVD/CD/MP3/WMA 7"...
Tip
Car amplifier troubleshooting
No output:
  • Confirm that all terminal strip connections are firmly connected.
  • Check in-line and built-in fuses. Both +12V and RMT terminals must have +12V to chassis ground.
  • Confirm that signal source ( Car Radio/Deck, EQ, X-over etc) is connected and is supplying output signal.
To confirm that Amplifier is working, connect an RCA patch card to LEFT& RIGHT low-level inputs of Amplifier only ( Do not connect the other end of the patch card).Briefly tap the center pin of each ( disconnected) RCA plug on the other (disconnected) end with your finger. This should produce a noise (feedback) in the speakers.
If this tip in anyway helped you please do not forget to rate it, thanks.
on Feb 19, 2010 | Car Audio & Video
My view sonic monitor has no sound
Troubleshooting Sound Issues Verify that the audio cable is connected to the AUDIO OUT or LINE OUT output on the Sound Card and plugged into the AUDIO IN or LINE IN of the Monitor.   Make sure there are no cables connected to the Headphone Jack (located next to the AUDIO IN port) on the monitor. If there is, please disconnect that cable and try the speakers again. Connecting a cable to the Headphone Jack disables the speakers. If there is no cable connected into the Headphone Jack, test a pair of headphones into that jack to see if you can hear sound out of the headphones. If you are able to hear sound out of the headphones, disconnect the headphones and try the speakers again.   Verify that the Mute on the monitor is not on or the Volume is not turned down.    Verify that the Mute on the computer is not on or the Volume is not turned down.<    If there is still no audio from the monitor's speakers, connect the Audio cable to another audio source like a portable CD player or tape player headphone output. If audio can be heard through the monitor's speakers, then there may be an issue with the computers sound card.    Connect another set of computer speakers (if available) or headphones to the AUDIO OUT or LINE OUT output on the Sound Card. If NO audio can be heard then there is an issue with the sound card. Verify with the computer's manufacturer for additional assistance.   LCD TVs Troubleshooting No Sound from a LCD TV No Sound when using RGB (when connected to a PC) Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the computer. Note: On the N1700W use the GREEN mini-jack; on this model Audio is SHARED between DVI and RGB, there is only 1 audio channel for data connections. The N1700w is designed to take a 1.0v RMS audio signal for optimal sound quality.   Confirm that both the LCD TV Mute and Windows Mute are off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the monitor or remote to confirm the Volume is not set to zero.   Confirm that PC volume is sufficient by using Windows/Macintosh Volume adjustment settings.   Try plugging another audio source such as a CD or Cassette Player directly into the Audio port on the LCD TV to confirm the speakers work, or try plugging headphones or external speakers into the sound card on the Computer. If the Headphones or External Speakers do not work, contact the manufacturer of your Computer for further support. No Sound when using S-Video/Composite/ Component Video Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the S-Video, Composite, or Component Video device.   Confirm Mute is off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the LCD TV or Remote to confirm the Volume is not set to zero.   Try plugging headphones or external speakers into the audio port on the S-Video, Composite, or Component Video device. If the Headphones or External Speakers do not work, contact the manufacturer of your S-Video, Composite, or Component Video device.   Note: Some ViewSonic monitors do not include speakers.
Nov 23, 2010 | ViewSonic E70f 17" CRT Monitor
BLACK LINE on screen and see-through Pink Bar!
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .
Apr 12, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
"disconnected cable, please confirm connect"
do you getta dvd picture...i get sound only but no pic....????
Apr 24, 2008 | Kenwood KVT-719DVD 7 in. Car Monitor
Cable Disconnected
there is a large 20-30 pin VGA cable that goes betwen the display unit and the hideaway tuner module. It is the most likely suspect.
Sep 11, 2007 | Kenwood Excelon KVT815DVD Car DVD Player
Kenwood kvt 715 screen saying disconnected cable found
same problems would like it if you could tell me how you resolved it, many thanks
Aug 29, 2007 | Kenwood KVT-617DVD Car DVD Player
Dissconected line
just had the same problem. it turned to be the large black cable that goes from the control box to the head unit. hope that helps.
Aug 20, 2007 | Kenwood KVT-617DVD Car DVD Player
Lexerd Kenwood KVT-739DVD 719DVD TrueVue Anti-glare In-Dash Screen Protector Dual Pack Bundle Logo
96 people viewed this question
Top Lexerd Video Cameras Experts
Are you a Lexerd Video Camera Expert? Answer questions, earn points and help others
