Question about Brother Office Equipment & Supplies
Typewritter makes a loud noise and printer head will not move
Model # CE-333, Serial # B61949216
  • 883 Answers
SOURCE: Paper feed
sounds like print head is not engaging home switch or sensor. open the printer and look for any such switch to sense print head at home position.
Posted on Jun 02, 2007
pagebor
  • 2785 Answers
SOURCE: Printing an 8x11 sheet the printer cradle makes a horrible noise
your printer needs servicing
Posted on Jan 07, 2009
bhagyavichar
  • 414 Answers
SOURCE: Head won't move far enough to the left to get cartridges out
seems a case of carriage jam n needs servicing..
howevr, do it if ur printer is out of warranty and u r a professional..
check for loose/faulty carriage-belt and the drive-assembly..jammed/sticky cleanser-unit (esp the rubber, gears n base)..
also chance of defective/faulty photo/opto-coupler 'sensor(s)'..the diodes and resistors in dis section..
always better to hv professional supervision, contact ur system admin/vendor....
Posted on Oct 31, 2009
sayer268
  • 147 Answers
SOURCE: The printer works...but it makes a loud clicking
please lubricate the rod that the print head slides on, 3 in 1 oil or sewing machine oil work best. Just a couple drops on either side of the carrier will allow it to move easier.
Posted on Jan 11, 2011
BaronVonNuke
  • 1915 Answers
SOURCE: When printing, makes a loud noise, like rattling
If the sound is coming from the back, this is likely a failed fuser bushing. If your printer has less than 150,000 copies on it, you can probably get the fuser replaced by HP under an extended service advisory they have for this product. Any service dealer can perform this free repair but you may have to make them aware that it exists.
Posted on Mar 11, 2011
The scan head moves when I start the printer, but then stops after making a loud noise, and the window reads, Printer error.
If visible check the print head track for some kind of blockage. Please include your model # and brand name next time.
Mar 18, 2015 | Office Equipment & Supplies
My Canon MG8120 all-in-one makes a loud noise when copying (not when printing). How do I fix it?
Dear
from the question I understand, the scanner move to right and during return it starts noise.
The problem with scanner assembly, It might be dust accumulated on gears, the scanner belt might have loose or the grips of the belt has worn out. Proper cleaning and lubricating the moving parts may overcome also if the belt worn out it has to be replaced.
In case of at home position it gives noise then the home position sensor may dirty/dusty, it has to be cleaned.
thanks.
Feb 15, 2015 | Canon Pixma MG8120 Wireless Photo...
I have HP laserjet 1018 printer and it makes noisy sound when it prints. But it prints fine though. What causes making this noise?
The noise is probably due to the print heads aligning and clicking. To try to make this noise a little quieter, clean and align the print heads.
Mar 23, 2011 | HP LaserJet 1018 Printer
The printer works...but it makes a loud clicking noise just after being the printer is turned on. The print heads move into position, as they always have, but it sounds as if something is about to break. ...
Jan 11, 2011 | HP Deskjet D4360 InkJet Printer
Oct 31, 2009 | Epson Stylus C44UX InkJet Printer
Weird noise from printer carriage
The loud clicking noise is probably the carriage trying to move and something is keeping it from doing so. Check to see there are no foriegn objects obstructing the carriage head from moving across the paper. If nothing is found, then likely a hardware error exists.
hope this helps!
Aug 31, 2009 | HP Photosmart 3180 All-In-One Printer
Printer made machine gun noise. will not print.
The print head is stuck - something has jammed it and the noise you are hearing is the carriage for the print head. Open the top and try moving the head by head sideways to see what has jammed it.
Aug 31, 2009 | Canon PIXMA MP760 All-In-One InkJet...
My HP psc 2210xi all-in-one printer makes loud noise & prints bad
It requires service as due to dust and dirt the gears are getting stuck, however if you can do it all it requires is a good cleaning and use machine lubricant to oil the iron rod on which the head moves.
May 05, 2009 | Office Equipment & Supplies
KB? Pitch?
maybe your printer stuck,try to move him manually and then start typewritter
May 07, 2008 | Brother EM-530 Typewriter
Multipass print head stopped working
try to move the printhead left to right. and make sure there is nothing obstructing it. Also make sure you ink cartridges are in securely. If that doesnt work let me know.
Jun 28, 2007 | Canon MultiPASS F80 All-In-One InkJet...
15 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
