Question about Speed Queen CTS99AWN Front Load Washer / Dryer
Door and wash status are flashing and it won't start
My WFS1071aw washing machine won't turn on. All
This video will show you how to open your WFS1071aw washing machine door that is stuck shut
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 16, 2013 | Washing Machines
Whirlpool washer won't start. Not a water problem. Door lock lift on or at times flashing. Think it's something to do with the door or panel.
At the right end of your panel you will find the 'end of cycle' symbol, to unlock keep this depressed for 3 seconds, this is the child lock feature. You do it again, and the machine locks.
Click if helped......
Apr 20, 2013 | Washing Machines
Kenmore front loader washing machine won't start
You will need to replace the door lock. Here is the part to order.
To replace the lock, remove the band securing the boot to the front panel and fold back the door boot. Now you can access and replace the lock. Let me know if you should need further help.
Nov 05, 2012 | Washing Machines
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
see this causes and fix it. God bless you
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
Sep 27, 2012 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
Maytag maxima door locked
Similar problem here - pump was set for a 58 minute normal cycle, I look in and see it is now showing 67. Hmm. Attempt to shut it off because it is just sitting there pumping and pumping. Power shuts off but pump keeps running and add garment light flashing red. Cannot open door (to add garment or not) Unplug the unit and the door will not open. Anybody got a clue what's up? I have a wash in, service is closed due to a storm today. Just bugs me that it is 6 months old and seems to act up a fair bit electronically.
Dec 09, 2011 | Maytag Washing Machines
Door won't lock..machine won't start
could be a faulty door lock as this is required to be locked before a signal is sent to the controller to start the wash cycle, try replacing the door lock, there quite cheal only a few pound
May 31, 2011 | Kenmore Washing Machines
Speed Queen CTS99AWN Front Load Washer / Dryer Logo
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
