My passport hard drive was working fine yesterday, it has my life savings of pictures and videos on it now my computer is telling me to format it every time I try and get on my hard drive please help
    Genius:
  • 1,669 Answers
Please try this:
If the drive uses a optional power adapter, be sure to use it and be sure it is the correct one for the drive Be sure to plug the power adapter directly into the wall and not through a surge protector or extension cord (this diminishes the power) Plug the USB cable into the Back USB port of the computer not the front or through a Hub (diminished power again) go to Start/Run and type devmgmt.msc and press enter. In the Device Manager do you see any devices with yellow marks, or under Universal Serial Bus Controllers do you see an Unknown Device? If so, right click it and Uninstall it. Remove the USB cable from the Computer End and restart the computer. When it comes back up, plug it back in. You can also go to Start/Run and type diskmgmt.msc and press enter. In the Disk Management window it will show all the drives on the computer. If all this fails, do as JMPC suggested, then remove the drive from the enclosure and either put it on a desktop computer as a Slave drive or attach it to a USB Adapter. The logic board inside the enclosure may have failed. Once it is outside of the enclosure you can hear if the drive is spinning up or if it is clicking or if it is cold (dead).
Posted on Jan 20, 2013
  • 37 Answers
SOURCE: I have a western digital essential 1 TB external
HI, RULE #1 IS "ALWAYS" ATTACH/PLUGIN WHILE PC IS SHUT-DOWN. NEVER CONNECT/DISCONNECT WHILE RUNNING. GO TO CONTROL PANEL, DEVICE MANAGER, SCROLL TO BOTTOM, CLICK + WD DRIVE MANAGEMENT DEVICES, SEE IF WD SES DEVICES IS THERE IF IT IS, DOUBLE CLICK IT. A WINDOW SHOULD POP-UP SEE IF IT SAY'S THIS DEVICE IS WORKING PROPERLY. IF NO DRIVERS ARE INSTALLED, CLICK UPDATE DRIVER. IF THAT DOES NOT WORK, GO TO CONTROL PANEL, ADMINISTRATIVE TOOLS, COMPUTER MANAGEMENT, UNDER STORAGE, CLICK DISK MANAGEMENT, MAXIMIZE PAGE, SEE IF MY BOOK IS THERE. IF IT IS, RIGHT CLICK, THEN MARK PARTITION AS ACTIVE...........I HOPE THIS HELPS..........JEFFXC
Posted on Jan 26, 2011
  • 39 Answers
SOURCE: cannot copy large files onto my WD passport
Your drive is probably in FAT32 format.  FAT32 has a 4GB file limit that is why your 5GB movie isn't saving.  You will have to format the drive in Mac OS file format (HFS) using Disk Utility.
Unfortunately once its in Mac format the drive will not be recognized by windows PCs.  What I do is have a program called macdrive installed on my windows computers so that they can access mac format hard drives.
i hope this helps!
Posted on Nov 26, 2008
  • 77 Answers
SOURCE: my external hard drive says you need to format the disk befor you
Download the BartPE bootable iso and burn it on to a CD:
http://www.download.com/BartPE-Bootable-Live-Windows-CD-DVD/3000-2094_4-10611131.html
It has some nice data recovery softwares. Boot using the CD and run the data recovery software(s) and you should mostly be able to get your data back - save it to your other hard disk.
You can also get some free software data recovery tools from:
http://www.freebyte.com/filediskutils/#datarecovery
You won't lose your data,
HTH,
Deboo
Posted on Jan 20, 2009
Jim1969pa3
  • 152 Answers
SOURCE: Western Digital WD Passport external hard drive not working!
Sometimes drives fail to spin up. they normally whine a little. Can you hear it spinning? If not bump it as if to try spinning it. If the drive spins up, get all of your data off ASAP.
Posted on Apr 14, 2009
Crankstart
  • 696 Answers
The problem you're having is not at all uncommon. The external drive may simply have been disconnected improperly or may have experience a small power surge while it was writing files.
The files on the drive are most likely still retrievable should you need them. If you already have copies of all of them you can simply reformat the drive and recopy them to it. If you do not have copies, whatever you do, do not format the drive.
Assuming the damage is logical(lost the partition table), your files should be recoverable through a relatively inexpensive data recovery process. Should the drive turn out to actually be failing they are likely still recoverable but this tends to be more expensive.
There are a lot of good companies that can handle this type of recovery. The one I often use for my clients it Armor-IT Data Recovery. Although they have recently gone private(gov't contracts) you can still find them by searching the above on google and they still do private work out of Canada, they just don't advertise anymore.
Hope this helps FixYa
Chris
Posted on Apr 29, 2009
All I really want to do is delete what is on my terabyte.
The quickest to delete the data off the Passport hard drive is to format the passport hard drive.
Connect the passport drive to the USB port on your computer, click My Computer, right click on the Passport hard drive then click on Format.
Apr 01, 2013 | Computers & Internet
I have had my WD 320GB portable hard drive for a year now and have had no issues with it. I plugged it into my laptop yesterday and instead of showing up as a removable storage drive, it is now coming up...
To be honest, all the external portable drive sometimes just stops working for no apparent reason even if you take very good care of it. If it cannot be formatted, maybe it's already a hardware problem. If the drive is under warranty, you might want to bring it to where you bought it and ask for a replacement. Also, these brands have the Data Recovery systems where they recover your files if the hard drive becomes unusable.
Mar 07, 2011 | Western Digital WD Passport 250GB Portable...
I'm not able to write files to my WD passport drive. It works fine in XP, but I have a Mac only..really not sure wat to do here..sos!
If the WD has been formatted in NTFS then the MAC cannot read or copy to this hard disk.
To make it compatible for the PC and MAC, format the WD Passport drive on your XP computer in FAT32 format. Then you can copy and exchange files between the PC and MAC.
Dec 26, 2010 | Computers & Internet
I have a wd used on a mac and would like to use it on a eepc as well, but it is not working...I can't open it on the eepc
The disk-drive might be formatted for usage _only_ with Mac OS X.
Copy all the files from it to your Mac's disk-drive.
Move the Passport to any PC, and "format" the disk for use by Windows.
Move the Passport to your Mac, and copy all the "saved" files back onto the Passport.
Move the Passport to your EEPC, and you should be able to use it, and to see the filenames that you copied from your Mac.
Dec 18, 2010 | Western Digital Passport WDXML800UE...
How to format WD Passport 1TB to FAT32 I have used WD external 500GB passport drive with my samsung 1080p9 dvd player successfully WD 1TB passport drive is not recognised by dvd player
Plug the drive into your PC.
Right Click on My Computer (or Computer in Vista/Windows 7) and select Manage.
Click on Disk Management.
Right Click the Volume in question and select Format. Select FAT32 in the options.
Dec 24, 2009 | Western Digital My Book Essential Edition...
External Hard Drive will not show up. Tells me to format it.
I have a Western External Hard Drive 320 and when I plug it in the computer will recognize it and allow me to access my files but after a short while if I go to click on a file t open it the WD 320 will click off for a minute and then reappear in the auto run mode.
Jun 20, 2009 | Western Digital Passport 320GB External...
WD Hard Drive will not pull up pictures of home movie i made
It seems like you do not have a picture viewer associated with the image file format that you save the pictures in.
Did you try opening a graphics program and then opening the pictures from there?
Install IrfanView if needed, opens almost anything image related.
Mar 04, 2009 | Western Digital Passport WDXML800UE...
Cannot copy large files onto my WD passport
i hope this helps!
Nov 13, 2008 | Western Digital Passport WDXML800UE...
Computers & Internet Logo
194 people viewed this question
David Payne
David Payne
