Question about Craftsman Garden
Lt2000 CRAFTSMAN MOWER MAKES CLICKING NOISE AND WONT START
  • 153 Answers
SOURCE: mower will not start will make clicking noise. did start at for one minute
Your battery is dead. Replace it.
In the winter keep a smart trickle charger on the battery to prevent it from discharging. Lead/acid batteries lose 1% of their charge per day and are basically junk in 3 months. They have to be kept charged.
Posted on May 05, 2009
SOURCE: clicking noise
removed engine cover - found starter was hung up, this seems to have fixed the problem it starts and runs fine now.
Posted on Jun 02, 2009
erpaalai
  • 999 Answers
SOURCE: LT2000 had been working fine, but trying to start
Make sure there is no corrosion on the battery terminal connections and check the fuse and safety switches clutch, brake,seat.
Eric
Posted on Jun 29, 2009
  • 13 Answers
SOURCE: How to remove blades on craftsman lt2000
There usually bolted on from underneath you must have a wrench are set of wrench to take off. Most models are some times kinda hard to get to
Posted on Sep 29, 2009
  • 11 Answers
SOURCE: my riding mower start but it wont move
Is it a Hydro, or belt drive?
Is Hydro on bypass?
Is the belt off, or broken?
Posted on May 05, 2010
Need free owners manual for a 6 speed craftsman Lt 20000 17.5 HP riding mower
You normally download the Craftsman manuals @
http://www.searspartsdirect.com/
You will the model number from the serial number decal under the seat area. This number usually starts with 917.
Aug 05, 2014 | Craftsman Garden
Why did Craftsman LT2000 stopped moving? Engine starts and blade engages fine.
The transmission drive belt is a separate one from the blade belt. The clutch pedal when released puts tension on the transmission drive belt so it tightens up and drives the gearbox pulley by way of a large spring. Make sure the spring is ok. The belts don't last forever and probably needs replacing looking at the age of the machine. That is a fun job as it is right up under the machine and runs from the engine pulley right back to the top of the transmission. You have to drop the deck right off and I usually find a tree with a large branch and haul the front up with a rope or winch so the mower is vertical. Makes it easier to work on. Drain petrol first though. Hope this helps otherwise get a mower shop to do it for you if you feel it's to much of a task. Good luck.
May 19, 2014 | Craftsman Garden
How can I replace a lost ignition key for a Craftsman LT2000 riding mower
the model number is under the seat on a sticker most riding lawn mowers use the same key the older models used one the looks the same on t=both sides and was short the newer style is longer and has cuts on one side only most any lawn mower shops will have them
Jun 14, 2012 | Craftsman Garden
Craftsman riding mower clicking noise - wont start
RIDING MOWERE JUST CLICKS AND WON'T START HOWEVER IT WAS RUNNING FIND JUST 5 MIN. BEFORE I TURNED OFF.
May 22, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Jcb electric mower just makes clicking noise wont start
some of these mowers have reset buttons on the motor---it works like a circuit breaker---access the motor housing to check for a button
May 10, 2010 | Acer Lawn Mower
Sep 29, 2009 | Craftsman Garden
I turned my craftsman mower off, and then tried to restart it and it wont even turn over. will jumpstarting help?
Does it make a clicking noise when you turn the key or nothing at all?
If it makes no noise at all (more likely), it is very likely a safety switch is being triggered. Be sure the blades are disengaged, you are sitting on the seat, it is in neutral, you are pressing on the clutch (if it has one( and there is enough oil in the engine. Those are all safety switch points which will prevent the mower from restarting
Aug 29, 2009 | Craftsman Garden
Eric
Jun 29, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Clicking noise
Jun 01, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
48 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
