Question about Grilling
Dcs bgb grill won't ignite
Bgb grill has battery powered ignition. It suddenly stopped working. No click when I push it in. I changed the battery and it still doesn't work.
    Novelist:
  • 200 Answers
It is probably the contacts, your new battery is probably fine but weathering can cause corrosion on the battery contacts. Emory board, steal wool, sand paper should be able to fit. To help prevent this in the future you can get some conductive grease from an auto supply store.. It is cheap for a small tube.
Posted on Jan 21, 2013
  • 4736 Answers
SOURCE: when i push igniter it
It sound s like the grill's regulator is locked up from "burping" the tank. Hopefully it's not a permanent lockup. To hopefully solve the problem, follow the steps below:
1. Turn the tank valve OFF and disconnect the hose from the tank.
2. Turn the burner(s) ON for 1 Minute, Then turn them OFF.
3. After 5 minutes reconnect the hose to the tank and open the valve VERY, VERY, SLOWLY (Slow
motion, slow).
4. Once the tank valve is fully open light one burner and turn it to HIGH. Did the burner light and
does the flame height look correct? Id so, light the remaining burner the way. Did it light and the
flame height look correct? If so, you solved the problem (with a little help).
If the above didn't solve the problem, the Hose/regulator Assembly needs to be replaced. What happened was this, when you turned the tank upside to "burp" the tank. The OPD Valve shot a hot load of gas to the regulator, when you opened it, as you normally would and permanently locked up the grill's regulator. That "burping" trick used to work with the old style tanks. Won't work with the new ones. You can get a new hose/regulator assembly at any home center or hardware store, that sells grills and accessories. They run about $30.00. Take your old one with you for comparison purposes. Once you install the new one and connect it to the tank. Open the Valve Very, Very Slowly, until it is fully open. Or you may have the same problem again.
Hope this helped to solve the problem. Happy Grilling!!
Posted on Jun 19, 2011
  • 4736 Answers
SOURCE: When I try to light
What you have is delayed ignition. It's being caused by the gas regulator. It is solvable, though.
Turn the gas tank valve OFF and disconnect the hose from the tank.
Wait 5 minutes and reconnect the hose to the tank.
Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
Once the valve is fully open, light 1 burner and turn it to HIGH. Did the burner light and does th eflame height look correct? If so, light the remaining burner the identical same way. Now, to both flame heights look correct? If so, you solved the problem. Remember to always open the tank valve Very, Very Slowly. And always light the burners with the Lid/Hood Open.
If the above did not solve the problem, you will need to replace the Hose/Regulator Assembly. Since your grill is brand new, the Hose/Regulator Assembly will be covered under Warranty. Have your Proof of Purchase handy and call Weber 1-800-446-1071. Also, if you haven't done so already, register your grill before calling http://help.weber.com/register/ even if you don't need a new Hose/Regulator Assembly.
Hope this helped you troubleshoot & solve the problem.
Posted on Jul 06, 2011
cadesertmax
  • 274 Answers
SOURCE: just bought summit s 670
To determine if it is the switch, remove the wires from the back of the switch and touch them together, if the lights come on, it is the switch. You will have to contact Weber for a new switch.
Posted on Jul 20, 2011
  • 4736 Answers
SOURCE: I have a Kenmore Quantum
The problem you're having is related to the OPD Valve in the Propane Tank. But, it is solvable by following the instructions below.
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling and thanks for choosing FixYa.
Posted on Aug 09, 2011
  • 4736 Answers
SOURCE: How do you use the
Because of the two different operations, you can only use one at a time. This is true with any gas grill that has those features. Operating both at the same time would cause an overheating problem.
Hope this helped you. Thanks for choosing FixYa and Happy Grilling!!
Posted on Aug 11, 2011
How to replace the ignitor battery on a DCS outdoor grill
  • Open the two cart doors on the bottom front of the grill, if your DCS model has doors.
  • Remove the drip pan under the grill by sliding it forward.
  • Locate the 9-volt battery behind the grill control panel in the compartment directly below the "Ignition" button on the front of the panel. The battery is mounted vertically to the connection plate.
  • Pull the battery straight down to disconnect and remove, using pliers if necessary.
  • Hold the new battery in position below the connection terminals so that the positive (+) post on the battery is facing inward beneath the grill. The positive post is the larger of the two posts on the top of the battery. Push straight up to connect the battery.
  • Slide the drip pan back in place and close the grill cart doors.
Jan 21, 2017 | Grilling
Igniter won't start grill
could be a disconnected wire from the igniter. could be a bad ground. could be corroded. Is there a spark going across one of the jets? may need to resort to a butane grill lighter (cheaper than digging around and replacing parts.)
Jul 07, 2012 | Weber Q Grill
Infared burners ignitor won't work
Mike, have you replaced the battery in the igniter button ye? That's the first place to start troubleshooting. Be sure you install the new battery facing the same direction as the old battery. Also, check the interior contacts of the battery holder for corrosion. If you find any, use a Q-Tip sprayed with a little WD40 to clean it.
If the above doesn't solve the problem, trace the igniter wire from the igniter button to the spark igniter at the burner for damaged wire or a loose connection.
And finally, try match lighting the infrared burners to make sure that they are getting an adequate flow of gas.
Hope this helped you t troubleshoot and solve the problem. Happy Grilling and thanks for choosing FixYa.
Aug 24, 2011 | Weber-Stephen Products Weber Summit...
Igniters stop working. replaced once before. need new igniter.
The igniter is warrantied by the manufacturer for 3 years. And now you're on your second one. I was just wondering, have you changed the battery in the igniter button? If so, was it installed facing the same direction as the one you replaced? Was there any corrosion on the battery holder contacts? If so, a Q-Tip & WD40 does well cleaning it off. Also, the ground wire from the ignition module may be loose and is not making contact with the grill's frame. When that happens, the spark ignitors won't spark.
I hope these few things, that have been pointed out, will save you the trouble of having to replace another ignition module.
Thanks for choosing FixYa.
Aug 17, 2011 | Vieluxe 370102 (NG) All-in-One Grill /...
How do you use the smoker on the professional bgb grill? Do you use it with the rotisserie or just the smoker?
Aug 11, 2011 | DCS Grilling
I have a stainless steel Ducane BBQ with five burners plus side burner and a rottisserie burner , which does not work. It is approx 5 years old and I have never used the rottisserie till last week. I have...
Since you've never used it. It may simply be a case that the infrared rotisserie burner is dirty and clogged with grease from cooking on the main burners. In addition, the Thermocouple and the igniter for that burner may also have a grease build up. In which case it won't allow the burner to light.
The electronic igniter that lights the main burners, also ignites the the rotisserie burner. Are you geting the click noise on the main burner igniters? If not, the battery in the igniter button needs to be replaced. Be sure to take note of the way the old battery is facing, when you unscrew the igniter cap. Because, that's the way the new battery should face.
Also, try match lighting the rotisserie burner. To do this, turn the Rotisserie Burner's Control Knob to the ON position and push it in, as you touch the lit match to the burner. If the burner lights continue to hold the burner knob in for a couple of minutes. This allows the Thermocouple and the ceramic plaques to heat up completely. Then slowly release the burner knob and the burner should remain lit.
If it doesn't stay lit, clean the burner and the Thermocouple ,in the manner that is described in your Owner's Manual.
Hope this helps you troubleshoot and solve the problem. Please let me know and Happy Grilling!!
Jun 15, 2011 | Ducane 30400040 Stainless Steel Grill
I need to change my thermostat on my 1990 toyota mr2 mk2 but also need pictures too.
Its not fun. If you are a MR2 owner you need the BGB. There are 2 Big Green Books that can be purchased at Toyota.( mechanical and electrical).........or you can use www.mr2-tech.com. The have the step by step procedure on how to do it with pictorial from the BGB. good luck and also go to the MR2board.com and register there. you will find tons of great write ups and tech facts.
Jan 04, 2010 | 1991 Toyota MR2
My drivers side electric window isnt working mr2
This should help you out for now. Also the BGB is there for future reference. www.mr2-tech.com/bgb/mechanical/volume2/body_electrical_system/Manual_1325_0001.jpg Good luck!
If you find its not the relay and its a motor let me know....keep me posted.
Nov 24, 2009 | 1991 Toyota MR2
Igniter will not shut off on my DCS RGS-366 gas range
Replace the multipoint gas re-igniter, it is a blue unit behind the knobs. This unit detects the flame and stops the clicking. Call Fisher and Paykel (owners of DCS) at 1 888 936-7872, they sell parts for DCS. The old inferior unit is blue and has a whte label. The newer unit has a yellow label.
Jul 23, 2008 | DCS RGS-366 Professional Gas Kitchen Range
Grilling Logo
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
