Question about Senco Air Tools & Compressors
My senco frame nail gun isn`t working
Senco sn iv frame gun - the drive pin is not returning -is loose .
    New Friend:
  • 24 Answers
First get an exploded view of gun and parts list and numbers from senco.com,,take nail gun apart,,,take a good look at the rubber bumper stop to see if it is broken,,look at the driver nut to see if it is tight,,,,you can go to juldan.com once you have gotten a list of the worn parts,,,juldan sells complete o ring kits along with nearly all parts needed for your repair
Posted on Jan 22, 2013
  • 3 Answers
SOURCE: Hitachi Framing Gun Not Firing - Bad Battery?
Does the fan run and the light blink ont he nailer? I have one that I just bought. I put in the wrong type of nails and got one stuck. I had to take the front apart to clear it and now the damm thing wont fire. The green light blinks and the gas cartridge is basically full, even the fan does run after I release the push lever, but no fire???
I wonder if yours is the same as mine did fire for a couple nails first just fine then got jammed...
I will try to charge the battery more.... MAybe like yours it needs a strong charge for the spark...
Russ
Posted on Oct 05, 2008
  • 104 Answers
SOURCE: n80sb-1 stanley bostitch framing gun.
try going to their website -I have several guns and each take at least 4 sizes of nails- yours should be no different- good luck hope this helps
Posted on Oct 16, 2008
  • 1388 Answers
SOURCE: Senco SFN1 wont work
I have worked on many sfn1 with the problem that you describe. Here are a few things to check. Driver/piston too tight or too loose in cylinder or bent. It should be relatively easy to move the driver piston up/down the cylinder. Usually it should hold it's own weight and not drop down the cylinder. There is a washer that should be at the bottom of the gun under the bumper (washer part# bf0070). This washer must not be worn to the point that too much air will leak past or missing. Finally there is an oring that controlls return of piston (part # lb0077). Pull out the cylinder and find it located on the outer part of the cylinder close to bottom. Clean the port holes under the oring and make sure that the oring fits snuggly. Do not use oil in this gun. Oil will swell the rubber parts. I use silicone lube available form Lowes in the plumbing department. The grease is used to lube faucet orings. Good luck with your repair and email if you have questions.
Posted on Mar 16, 2009
Idaho_Biker
  • 32 Answers
SOURCE: Paslode framing nailer loss of power.
Here's what I found at the Paslode Troubleshooting Site:
Tool will not cycle - fan runs, indicator light
is solid green.
Lockout bracket is stuck in lockout position.
Work-contacting element is bent, or build-up of
debris in track restricts operation.
Follower is not behind fasteners.
Fuel Cell empty.
Spark wire out of spark plug.
Spark plug is dirty.
No spark is generated.
Check lockout.
Remove and inspect lower probe. Clean and
lubricate track with Paslode Impulse® oil.
Repair or replace lower probe as required.
Position follower behind fasteners.
Replace fuel cell.
Remove cap and check spark lead, insert in
spark plug and replace cover.
Clean tool cylinder head and spark plug.
If this doesn't work, I suggest contacting Paslode directly 800-222-6990
Posted on Mar 27, 2009
Editor925
  • 285 Answers
SOURCE: How do you safely remove jammed nail gun?
Not sure exactly what Bostitch framer model you have, but if it is powered by compressed air, as long as you remove the air hose from the nail gun, there should be no risk of the nail gun firing while you remove the jammed nail. There should be a way to access the driver area from the top of the nail gun, even via a latch or a couple screws. Remove the top part of the driver area and that should give you access to the jammed nail, which you can remove. Use long nose pliers or something similar if the nails are really stuck.
Posted on May 31, 2009
Proper nails for a SENCO SN IV
2" to 3 1/2" 2" for sheathing and 3 1/2" for stud framing.
Apr 09, 2015 | Senco Air Tools & Compressors
Why does my Senco SN 901 XP frame nailers driver stay forward?
not sure what powers the senco if it works on combustion or air could be damage O rings. Another possibility is a trapped nail under the blade. Have seen where a nail has not been driven out of the magazine but has bent and points down the magazine close to end of gun. What happens is the blade drives over the nail but becomes trapped between nail and roof of the nose assy. Probably need to strip the gun a little.
Mar 24, 2014 | Tools & Hardware - Others
I have a Senco SN70 framing nail gun. The gun
One question is do you regularly put oil in the gun? Also you need to make sure that the screw holding the 'clip' near the barrel is tight and not loose. These are the 2 main problems when a gun is misfiring.
Oct 02, 2013 | Senco Air Tools & Compressors
Senco fram pro 602 nail gun firers but no nail just a hole from firing pin
First, check that you are using the proper nails. The FP602 needs Full Round Head nails with plastic collation. If you are using Clipped Head nails with the paper tape collation the angle of the nails not let the driver catch the next nail and drive it into your work.
If you have the correct nails, check the magazine to make sure the nails are feeding all the way up to the driver. If there is anything blocking the way or if the spring on the feeder isn't taught enough to pull the clip all the way up the driver won't be able to catch the next nail and drive it in.
May 05, 2012 | Senco Tools & Hardware - Others
DOESN'T FEED,IT MIGHT MISS SHOOT A TIME OR TWO THEN GET A NAIL THEN NOT FEED.I'M SHOOTING A 1.5"TECO NAIL. ANOTHER GUN DOESN'T SHOOT EVERY TIME LIKE THE DEPRESSOR ISN'T LETTING THE...
Usually miss feed happens when the driver does not return to top position not allowing the nails to feed into position. Easy to check, point nose of nailer up then down again to see if the driver is loose in the cylinder. If loose, the driver will be in the down position when the side door is opened. If driver is down, replace driver oring. If driver oring is good, look for spring tension on feeder and check feeder spring on the door side. If piston oring good and feeders have good spring tension, suspect lower bumper cracked(remove head and piston to check bumper).
On gun with depressor (safty foot) not actuating trigger, look for worn trigger (trigger inner lever could be worn) or loose or worn firing pin in the trigger valve above the trigger(valve # tva6). Replace as needed. To check for proper gun action, remove the nails, remove the 3mm roll pin holding trigger and dry fire the gun by depressing the tigger pin. Good luck
Sep 21, 2011 | Stanley Bostitch Coil Framing Nailer
Will the 901xp use any brand of papertape 33 degree nails? I have probably 12 cases of collated papertape and would hate for them to just go to waste but the 901 is not listed as compatible.
Most Senco nail guns are great about listing out brands of nails that will work with their guns, they are not particular to using their nails. The 901 does use 33 degree nails but if Senco does not list the brand that you have then I would recommend not using them so you do not damage your gun. Maybe you can sell them on Craigs List?
Hope this helps James
Apr 05, 2011 | Senco SN901XP Clipped Head Framing Nailer
Gun will not drive pins flush with wood. Wood is
What is your air pressure setting. A finish nailer such as this usually requires 70 lbs to drive flush. Adjust air to this value and test fire in scrap. Keep adjusting air presure until nail drives flush.
Nov 23, 2009 | Senco 4N0001N Finishpro 11 23 Gauge Micro...
The Senco SFN-1 gun will drive one nail and then not retract
sounds like time for a rebuild i do this once a year on all of my guns i buy a seal kit and replace them at that time and oil the interior oparts and check for worn or broken parts
Sep 03, 2009 | Senco Tools & Hardware - Others
Senco SN4 misfiring intermittently
This is a discontinued tool by Senco but there are still parts available for it. It sound to me that the o rings and possibly the firing valve need to be replaced. I would recommend going to Senco.com and you will find a complete parts diagram in their discontinued tool section. They also have a toll free number if needed and you can talk to their air pro. I have rebuilt quite a few of these and they are not that hard just make sure to clean all the parts and use lube when replacing O rings.
Jan 01, 2009 | Tools & Hardware - Others
SENCO SN-IV LB3500 Seal leaks air
The old seal was origionally the same as the new one, a white nylon, however over time the seal breaks down and looks like hard wax. The new seal may be installed by heating with hot air gun till plyable and gently streach over lip. While the gun is open, lube with nail gun oil. the piston should not slide down the cylinder under its own weight, if it does, replace the piston oring. Diagram available at senco.com
Nov 25, 2008 | Senco Air Tools & Compressors
Air Tools & Compressors Logo
463 people viewed this question
Top Senco Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Senco Air Tool and Compressor Expert? Answer questions, earn points and help others
