Question about Canon 16x Manual Servo for XL1S
How to conect a lcd to a canon 1lxr's - Canon 16x Manual Servo for XL1S
Hp g70 lid actuator
you pulled your lcd cable and sounds like its arching on a conection remove lcd inspect cable reinsulate with a tape electrical should be fine but suggest checking conection on both lcd and board its a easy fix
Feb 27, 2013 | HP G70-250us Notebook
Canon pixma ip4500 cannot install drivers, 'cause gives the error - "printer not detected", even though it's ON and conected to the PC.
Hello how are you.
If you install windows 7 when you turn on the USB cable to the driver you downloaded from the Internet.If windows finds himself then the problem is the USB turntable.
Call the appropriate Canon printer service.
Dec 16, 2012 | Canon Pixma iP4500 InkJet Printer
DISPLAY LCD~ Canon IXUS 860 ISWhat's your problem?
ldc as gone blank.can not see photos when i take a photo
Oct 28, 2012 | Canon IXUS 860 IS Digital Camera
I have a Canon A560 camera. It takes pictures and I can download them to my computer OK. But the LCD screen is black, I don't see any display at all. Pushing the display button does no good.It got...
If your LCD doesn't light up then it's either the backlight or the LCD, you can open up the camera and check the cables before buying any parts. Some LCD screens come with the backlight, some don't; not sure if this one does or not.
IF it was water damage, you probably have corrosion on the main PCB and won't be able to fix it without replacing the board... open it up and check for corrosion!
Hope this helps.
Thomas
Owner, Darntoothysam.com Digital Camera Repair
Jul 11, 2011 | Canon PowerShot A560 Digital Camera
My screen stopped showing the pictures completely. During playback and when I'm taking pictures. Could it be that the LCD burnt out and can that be fixed?
I'm assuming that the camera still takes and records images as usual and that you can upload them to view successfully from the memory card, and that the camera powers up and the battery charges as usual.
If so, then the most common causes are a failed LCD panel or loose connectors to the panel from the main circuit board, or a failed backlight. Depending on the age of your model, a new LCD panel should be available and the price depends upon the size. A failed backlight or a loose connector is more common though. In some instances, the LCD driver on the main board has failed, and unless under manufacturer's warranty that usually is terminal for the camera.
It's also not uncommon for users to have simply turned off the LCD display. Not all Canon models allow you to do so, but I suggest that you check your owner's manual to eliminate this really simple cause.
Unfortunately I cannot give more specific advice as you haven't stated the exact model of Canon camera which you 're asking about.
Jun 18, 2011 | Canon Cameras
Error code E677
677 error is printer board error.u check conection( lpt port or usb cable loose conection.printer board loose conection.remove all conection and conect all conection i mean reinsert conection ) then this error come u will service u r printer board(re insolve printer softwere).803 error is expouser lamp end side blocked change u r lamp u r 803 problem is ok
Jun 01, 2009 | Canon iR 1600 Laser Photo Printer
E805
J'ai un problème e805 photocopie canon gp 405
Quelle est la solution de détails, s'il vous plaît
Aug 24, 2008 | Canon imageRUNNER 400S Copier
Canon 16x Manual Servo for XL1S Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
