Question about Citizen Watches Citizen CT-S300 - Receipt printer - two-color - - CT-S300-UF120AN-BK
Does the ct-s300 carry any ink? My printer is not printing on the receipts
Printer won't stop feeding paper Citizen CT-S651
if its printing ~@{}{@@ZXXCZ wierd things then its a driver problem and you need to reload it
Oct 11, 2013 | Citizen CT-S300 Printer
Ct-s300 printer is printing a blank spot down the receipt
Sounds like the heating element is covered or broken in that spot.
Feb 14, 2013 | Citizen CT-S300 Printer
Paper keeps feeding after the print of the page
First I would look carefully at the site you are printing from, some will not let you select pages to print.
somesites will have "printer friendly" that you should select otherwise you print ever page fir that website.
next see if you can view PDF before printing then select only the ones you want.
in conclusion the problem appears to be not with your printer but the web pages
Aug 08, 2012 | Citizen CT-S300 Printer
Error light blinking Citizen -S300 printer
  • High-speed (200 mm/s) printing
  • Longer cutter life (2 million cuts) delivers lower maintenance costs
  • Greater reliability delivers longer life & lower maintenance costs
  • Wider paper width allows printing of additional information & larger fonts
  • Interchangeable interfaces
  • 2D barcode (QR-code and PDF417) support allows wider applications
  • Built in buzzer provides audible alert without adding extra cost devices
  • Built in power supply eliminates unsightly "brick" and frees up space
  • Cash drawer kick-out external device port supports 2 cash drawers
  • 2-color printing supported (when specified paper uused)
Aug 16, 2011 | Citizen CT-S300 Printer
How let Lexmark S305 only use black cartridge to print black. Now the color cartridges getting empty by only printing black, and with "only use black ink" selected. (Besides that, the cartridge...
Please follow the steps below on how to print using black ink only on your Lexmark S305 printer:
For Windows:
  1. With your document/file open, click File.
  2. Click Print.
  3. Click Printing Preferences/ Properties.
  4. In the Lexmark S300 Series Printing Preferences window, select print using black ink only.
  5. Click OK to save the settings.
  6. Click Ok again to print your file.
For Mac operating system:
  2. Click Print.
  3. Expand the arrow pointing down beside printer name if you're not able to see other options for printing. Look for Quality and Media in a drop down box and select print in black and white.
If you wish to set this as your default print setting, please follow steps below:
For Windows:
  1. Go to Control Panel.
  2. Open Printers and Faxes.
  3. Right-click on Lexmark S300 Series print object and click on Properties.
  4. In the Lexmark S300 Series Properties window, go to Advanced tab. Click on Printing Defaults.
  5. Under Ink Use, select Print using black ink only. Click OK.
  6. Click OK button in the Lexmark S300 Series Properties window to save the changes.
Your printer will print in black only the next time you send a print job to the printer.
For Mac:
  1. With the file (you wish to print) open, click File.
  2. Click Print.
  4. Save this as your default print setting. Click Presets option and choose Save as. You can personalize the name for this default print setting (e.g. Black and White Draft or My Setting).
Select this Preset name every time you print your files/documents.
Note: The 100 standard cartridges yield around 175 ISO Pages. You can also save on ink and stretch your ink investment if you use only 100XL high yield cartridges. These contain almost 3x as much ink as a standard cartridge for a small increment in price.
Aug 07, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
I replace the receit roll and it doesn't want to print.
Either you do not have the paper threaded correctly and it isn't passing in contact with the printhead or the paper roll is upside-down. That printer uses a thermal printhead and the correct paper for it will be sensitive only on one side.
To check, take a length of that paper, place it on a hard surface and make a line while pressing with a finger nail. The correct side will show a blue or black trace where you did this.
The paper has microscopic bubbles on the printing surface that is sensitive to heat or pressure. Either will cause the bubbles to burst and release the ink trapped in them.
If you find no trace on either side, it isn't the correct paper for this printer.
Sep 11, 2010 | Citizen CT-S300 Printer
Resume not working
Sounds like head failed replace it see below
6 times Print head not-installed error Install print head.
7 times Print head error Replace print head, as it has failed.
8 times Waste ink near-full error Replace printer, as it has failed.
Oct 23, 2009 | Canon BJC S300 InkJet Printer
Error light will not stop blinking on my receipt printer; CT-S300. No manual so do not know any troubleshooting techniques. Help?
Hello
This is the direct link to the manual:
http://www.citizen-systems.com/support/downloads/CT-S300UM5_201.pdf
You will probably find what you need inside
Jun 27, 2009 | Office Equipment & Supplies
Not Printing
clean the head and see what happen
Jun 12, 2009 | Canon BJC S300 InkJet Printer
New black ink wont print
goto printing preferences in printer and faxes. open properties oof printer. change print quality to best or maximum.
Apr 24, 2009 | Office Equipment & Supplies
Citizen Watches Citizen CT-S300 - Receipt printer - two-color - - CT-S300-UF120AN-BK Logo
16 people viewed this question
Top Citizen Watches Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Citizen Watches Office Equipment and Supply Expert? Answer questions, earn points and help others
