Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
LG Tromm WM2277HW OE error message
Was not able to get door to unlocked with load still inside.  Unplugged and waited 30 minutes.  Door opened, but was mid-way through cycle so water poured out.  Not getting an OE error.
What is this?
  • Anonymous Mar 13, 2014
    OE error LG tromm washer
  • Anonymous Mar 30, 2014
    had to replace the circuit board. Then started the cycle up and got an e3 essae error. di what troubleshoot guide said to do then it started again and stopped with error message OE
  • 640 Answers
Unit not drainning..in the but front left hand corner ,,there a panel,,open panel and clean your filter...onthejob...
Posted on Jan 30, 2009
I have the LG TROMM WM2688HWM. Tried to wash a load and keep getting the error message: 'The door is open....'. I have held it closed, pushed it closed, opened and closed many times to no avai
the door actuator may be defective. if ur model has one? other wise sounds like the board is not communicating with the switch
by pass the door switch like this:
Feb 13, 2013 | LG WM2688HWM TROMM SteamWasher
LG WM3431 door won't unlock
did you unplug it,leave it unplugged for 5 minutes and plug it back in,if it's to hard to get to plug flip the breaker and leave the power off for 5 minutes or longer when you power it up again the door should unlock.here's a link to check hope it helps
https://www.google.com/search?q=lg+front+load+washer+how+to+manually+open+a+locked+door&oq=lg+front+load+washer+how+to+manually+open+a+locked+door&aqs=chrome..69i57.21935j0j8&sourceid=chrome&ie=UTF-8#kpvalbx=1
Dec 29, 2017 | LG WM3431 Front Load Washer / Dryer
LG Tromm WM2277HW
Does spin only work well?
Apr 11, 2017 | LG WM-2277HW Front Load Washer
I have a tromm washer (model wm2277hw) that sometimes will drain and sometimes not. when it doesn't i get error message OE. all connections seem to be good. when it doesn't drain there is no noise like...
An OE error presents if the washing machine has not successfully drained the water in ten minutes. Follow this link for step by step instructions for correcting the OE error code.
The FixYa Team
Dec 27, 2010 | LG WM-2277HW Front Load Washer
LG Washer Model #wm2277hw
It is a motor error
• The connector in the LEAD WIRE ASSEMBLY is not connected to the connnector of STATOR ASSEMBLY Reconnect or repair the connector • The hall sensor is out of order/defective. Replace the STATOR ASSEMBLY
Apr 19, 2010 | LG WM-2277HW Front Load Washer
My Tromm washer blinks an OE message, the door will open, but the wash won't finish and there is water still in the washer. Please help
OE error means the water hasn't pumped out. 1st you need to check the filter behind the flap in the bottom corner. This may be blocked a check your outlet hose where it goes into the somethimes they get blocked there sometimes. When the filters out get a torch and shine it into the hole where the filter came from to see if theres a blockage in there. If all is clear will prob require a new pump.
Dec 20, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My front load Tromm LG washer flashes OE message, won't drain or finish wash. Door does open
oe is an error code for pump problem disconnect power cord open small door on lower front of cabinet pull little tube out and plug from tube and drain water in to bucket after water is drained unscrew cap of pump to clear out any obstructions reinstall the cap and plug and give a test run
Dec 20, 2008 | LG WM-2277HW Front Load Washer
Tromm washing machine, front load from LG
Peace,
ngafm at your service!
Lets try this first!
Did you try to open the door when the breaker was off or only when you turned it back on??
How old is the washer?
I'm here all night if you want to write me back!
Bless You,
Please leave me a good rating in this site before you sign off!
Sep 03, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM2277HW trouble
take off the front kick plate on the bottom and there is a pea trap thats conected to the pump twist it off and see if it is cloged thats what usaully makes it not spin
Aug 11, 2008 | LG WM2688HWM TROMM SteamWasher
Washing Machines Logo
1,473 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
